Post by svart on Mar 21, 2014 20:36:21 GMT -6
Have you opened the converter box to see if there are bit switches inside? Sometimes these types of things will have bit-set switches inside to change. It's a long shot though.
EDIT: I looked up schematics for coax-to-optical SPDIF converters. They are pretty simple. Generally just an input to a CMOS buffer to drive the optical output. Nothing else. Unless this thing is really buggered up, I don't see how it could be causing you issues.
Another silly question.. What are you powering the SPDIF converter box with?
Post by Johnkenn on Mar 22, 2014 8:53:42 GMT -6
it came with a little wall wart power supply...It's definitely a POS. It was $13 on Monoprice. I've got the HOSA ODL-312 coming Monday. I would be shacked if I couldn't get these things to work together.
Post by lolo on Mar 22, 2014 9:41:56 GMT -6
Just a shot in the dark. This was the type of behaviour i had when my RM A/D converter was faulty.
Post by Johnkenn on Mar 22, 2014 10:05:37 GMT -6
You mean the card in the Symphony? It passes audio fine, though...We will find out Monday...
Post by svart on Mar 22, 2014 13:40:02 GMT -6
AES and SPDIF are almost the same thing.. In fact, all you need to adapt AES to coax spdif is a level pad.
