Post by kcatthedog on Dec 14, 2019 6:48:49 GMT -6
Is it just me or is Logic automaton a piece of shit ? I almost always find it very inconsistent, even when you are putting auto moves in manually.
Currently I am trying to put tremolo off and on in certain sections of a track and have eh lane open up and can see the green white bypass off line, but the plug in does not correspond, so its not clear what or where on the timeline is actually invoking the plug in on/0ff ?
any tips ?
Post by theshea on Dec 14, 2019 7:21:01 GMT -6
mine works fine.
Post by kcatthedog on Dec 14, 2019 7:57:24 GMT -6
Good to know:), so if you were using the logic tremolo in a guitar track, could you describe briefly what you would do to say off it off in verse and on in chorus ?
Post by stormymondays on Dec 14, 2019 9:26:24 GMT -6
Just put it in Latch mode, press play, make your moves and then switch it back to Read.
Post by kcatthedog on Dec 14, 2019 9:53:00 GMT -6
Roger that: thx!
Post by theshea on Dec 14, 2019 11:26:46 GMT -6
yes, i would use latch mode, too and do it real time. if it doesnt't work - but it should - turn on automation in the arrangement window and look at the automation curve for the track. it should be on, off ... if not try drawing it into the auomation curve.
Post by kcatthedog on Dec 14, 2019 12:55:17 GMT -6
All good here now, thx!
Post by Martin John Butler on Dec 14, 2019 15:56:35 GMT -6
Latch mode is the way. You can perfect where the automation you've written is after you're done "latching". Be sure to go immediately back to "read" mode, otherwise every move you make will still be recorded. How do I know this? I've forgotten too often and then had to fix the mess.
