Post by johneppstein on Jul 11, 2019 16:08:18 GMT -6
The fact the climate change is way more about politics than the environment is what turns me off to it. It's hot here today. But 4 months ago we had the biggest snowstorm in close to 100 years. The weather sure has changed since then. Global Climate change? Maybe, but I think it might just be summer. As for the politics....yawn. Wake me up when it's over. Blaming current administrations for all the accumulated problems of decades is so.....boring and disingenuous. Weather is a complicated thing. Overall warming can cause shifts in air circulation that may actually cause some localities to see colder weather because the winds change.
However out here in Cal certain things are very noticeable. Such as the fact that "foggy San Francisco" doesn't exist anymore. I think I've seen one slightly foggy evening in my last five years in the city. The winter/spring rainy season is mostly gone as well. This last winter was rainy in comparison to the last several years but nothing compared to the weather we used to see. And SF, which never used to get hot - people would complain about heat when the temperature got over 70-75 has been seeing regular temperatures in the high 80s. In Fairfield, 60 miles north where I'm living now summer temperatures are reminding me a lot of when I lived in Oklahoma. Maybe not quite as bad, but lots of days over 100 degrees.
Near coastal Northern Cal used to have one of the most moderate climates in the country. That has changed noticeably. And of course wildfires have become a regular summer problem instead of the relatively rare disasters the used to be. I really should try to get insurance before the fires start again this year but I don't know if I can afford it.
Post by ragan on Jul 11, 2019 16:51:42 GMT -6
ragan one thing you said kinda jumps out at me. . You said that this isn’t political but it’s objective reality. That’s a very tough thing to talk about because very few things in science are objective. Let me kinda walk through what I mean. First, there is no such thing as bad data. Anyone that says the phrase bad data is speaking loosely or incorrectly. There’s only bad analysis. Even if your tools are out of calibration the data reflects that. The data just is, it’s just information. So no one is able to gather information and say objectively that the climate is warming due to anthropogenic effects. Not like you could say, there were two apples on my desk and now there is one because I ate one. What we can do is take data and perform analysis. But now, we have to talk about primary, tertiary data and so on. If I take a measurement with a thermometer that’s primary data. If I compile measurements taken all over and post an average, that’s secondary data. Or, if I take that thermometer temperature and say, I know that temperature is a good analog to something else, like, maybe humidity. Now there is an implicit layer of analysis, so we have a secondary layer of data that’s metadata. When you analyze a photo, you take primary data (color of a pixel) and add an analysis layer (1= ice 0= no ice). Then you take that metadata and do something else with it. And tertiary, and that gets fed into another, until at the end on this big pile of meta meta meta analysis you wind up with an equation that says CO2 up, temperature up, and oh by the way it’s unstable. There’s nothing wrong with that at all. There’s no lie or conspiracy. But here’s one thing that gets tough. Every layer of analysis has an error bar. Even the primary measurement has an error bar. And further, every layer of analysis has a sensitivity to error. For example, if my primary error is +/-100 degrees, my humidity sensitivity to error is HUGE even if the accuracy of the data is dead nuts on (not the precision). What gets really murky is how those sensitivity numbers add up - how sensitive is the final model to assumption number 3 in the chain of 4 assumptions? If we take the two extremes of assumption 3s range, do we get wildly divergent outcomes? The truth is this kind of analysis is difficult, costly, and...mostly uninteresting. Maybe impossible. But without it you really don’t know if you final result is useful at all. A lot of the data were using is stochastic, so even if we have rock solid analysis and models our sensitivity to initial measurement error maybe all over the place. In other words, climate is really freakin complicated. That should make us less confident in simple conclusions, not more. Metanalysis of scientific studies really shows that it’s not conspiracies that foul everything up but that humans just have bias and bias strongly affects outcome. Especially when you have multiple layers of analysis separating from the primary data, which probably has the least sensitivity to bias. For fun, read this. It’s pretty amazing. slatestarcodex.com/2014/04/28/the-control-group-is-out-of-control/For that reason, I’m reasonably skeptical of AGW claims. And sometimes I wonder if the proposed medicine is worse than the disease. Only have a sec but just wanted to say, yes, agreed. All good/valid points. What I meant was that, unlike most things political, in this case there *exists* an objective reality. Whether we can get at it and what we do to try involves all the issues you and others point out. But with most things political, there isn’t even an underlying objective reality to begin with. It’s almost purely identity and loyalty and ideological lenses and things. With climate, those things come into play every step of the way but it’s fundamentally different to me because there is an actual answer to a given query. We may not be able to get it at a given moment but it does exist. That’s the “objective” part I meant to be talking about.
Post by matt@IAA on Jul 11, 2019 17:18:11 GMT -6
Yeah I mean, it is either true or false that the earth is warming, and it is true or false that it is significantly anthropogenic, and then it’s either true or false that the system is unstable, and even then further it’s true or false that this is bad for mankind.
The further you get on that chain the more political it gets. Because you can also say - it’s true or false that a certain policy increases GDP or improves public health in an objective way. I’m not so sure that it is in fact different.
Post by matt@IAA on Jul 11, 2019 17:30:16 GMT -6
Man this is why I LOVE not being biased politically. I can actually sit back and look at both sides and understand why something like the climate is even political. One side is saying we need to stop burning fossil fuels. The other is saying we need to keep burning them and actually burn more. The fun part is doing research into who each of these sides of people are tied to. It's sad. All that said. We have a scenario where a TS is steaming for a place that was turned into hell 14 years ago. People are worried about the well being of those residents because they saw what Katrina did. There's even more worry from people because the Mississippi river is twice what it should be and will crest at 19' around the time the thing pulls in. Seems like the thread would've been created to bring awareness to people who havn't seen this yet and to also prompt people to form a mass consciousness of people to pray in whatever way they do that. Hopefully that's what people will do before and hopefully people will contribute after if they can and if there is a need. That's why I'd make this post at least. So, the truth is there is no way to stop using fossil fuels tomorrow no matter what we do. Even if we all wanted to, we’re decades away. I work in turbomachinery. There are *significant* challenges to integrating non-dispatchable, inverter based power sources (ie wind and solar) onto our existing infrastructure. And, even if we had unlimited resources to make as much wind and solar as we need, there are still systematic issues - lack of wind, lack of sun - that prevent 100% renewable from being a reality any time soon. Daily storage is a few hundred megawatt hour scale batteries. Ok, those are beginning to pop up. But seasonal is hundred of terawatt hours. Batteries are never going to fill this gap. Something will, perhaps compressed air, pumped hydro, or even synthetic photosynthesis or hydrolysis to burn hydrogen. But that’s decades away, no matter what side you’re on. The only responsible thing to do is deal with things as they are. And, I think that means recognizing that natural gas and yes even coal in some places of the world are a net good for individual humans and also mankind. Doing a worldwide coal ban would be a bit like climbing up our ladder then kicking it over for those who are just starting up. And that’s just electricity, never mind travel or heating use of fuel. Anyway, yeah, thoughts and prayers for Louisiana. Hurricanes suck. But no one should ever die from one...you get days and days of warning. Get out of dodge, and help the folks who can’t get out on their own. Most of the people who die in these things are either sadly abandoned / incapable elderly or stubborn fools who won’t leave.
Post by ragan on Jul 11, 2019 17:35:16 GMT -6
Yeah I mean, it is either true or false that the earth is warming, and it is true or false that it is significantly anthropogenic, and then it’s either true or false that the system is unstable, and even then further it’s true or false that this is bad for mankind. The further you get on that chain the more political it gets. Because you can also say - it’s true or false that a certain policy increases GDP or improves public health in an objective way. I’m not so sure that it is in fact different. True. I was thinking more along the lines of "raising the retirement age for Medicare is unfair to those who paid into the system under a certain set of terms" or "wealth disparity hurts everyone, even those at the top because x, y and z..." Those things are factually nebulous and/or morally based. Very different to me than "________ is doing ________ to our climate". Maybe not in the way they play out, because the various actors use anything and everything to advance their agendas, but in the epistemological nature of it.
Post by matt@IAA on Jul 11, 2019 17:42:57 GMT -6
Well.. yes... the x then y to climate thing is also fundamentally different from the "therefore we should tax CO2" or "therefore we should inject market distorting subsidies to make it cheaper to install wind turbines and by necessity make it less profitable to operate gas turbines". I mean, even if you say - climate change will kill people in 200 years if we do nothing there's kind of a moral step to answer "...and why should I care?" as I eat a steak and rev the hell out of a diesel truck haha.
Hopefully there is some kind of objective concept behind raising the retirement age for medicare, not just the feelz. And same for wealth disparity, hopefully it is actually objectively true (on some level, even if unknowable) that it is bad for everyone. It's always the "so here's what we should do about it" where things get sticky.
Post by drbill on Jul 11, 2019 17:44:02 GMT -6
The fact the climate change is way more about politics than the environment is what turns me off to it. It's hot here today. But 4 months ago we had the biggest snowstorm in close to 100 years. The weather sure has changed since then. Global Climate change? Maybe, but I think it might just be summer. As for the politics....yawn. Wake me up when it's over. Blaming current administrations for all the accumulated problems of decades is so.....boring and disingenuous. Weather is a complicated thing. Overall warming can cause shift in air sirculation that may actually cause some localities to see colder weather because the winds change.
And you assume that these changes are set forever. I'd be willing to wager that they are not. The pendulum swings both directions,,,,
Post by johneppstein on Jul 11, 2019 20:57:34 GMT -6
ragan one thing you said kinda jumps out at me. . You said that this isn’t political but it’s objective reality. That’s a very tough thing to talk about because very few things in science are objective. Let me kinda walk through what I mean. EVERYTHING in science is objective. That's what makes it science instead of ignorant "opinion". As a result, SCIENCE is constantly being updated, as opposed to dogmatic opinion and propaganda. Which never are, even in the face of demostrable fact.
There absolutetly IS such a thing as bad data. My uncle,Samuel Eppstein was a research chemist in cancer research for Upjohn Pharmaceutical. He wa working on a project in which which another "scientist" posted fudged data w was subsequently proven false. It almost wrecked the entire project when it was exposed. The "scientist" was fired and ev erybody involved with the project had a great deal of work to do in salvaging their careers.
His daughter Debby (my favorite cousin) when on to run her own biotech company in Salt Lake City.
Some of us have access to information beyond the realm of public "information".
Wrong. Scientists, like most people, are often bribeable or if not bribeable not above faking data for their own purposes. In this modern era it is necessary to follow the money to find out to which special interests they are beholden.
Scientists are human. And some humans are crooks.
Bullshit.
Post by johneppstein on Jul 11, 2019 21:01:35 GMT -6
Yeah I mean, it is either true or false that the earth is warming, and it is true or false that it is significantly anthropogenic, and then it’s either true or false that the system is unstable, and even then further it’s true or false that this is bad for mankind. The further you get on that chain the more political it gets. Because you can also say - it’s true or false that a certain policy increases GDP or improves public health in an objective way. I’m not so sure that it is in fact different. That's what the special interest want you to believe.
True science is objecvtive, it is not political.
Post by johneppstein on Jul 11, 2019 21:13:12 GMT -6
What I meant was that, unlike most things political, in this case there *exists* an objective reality. Whether we can get at it and what we do to try involves all the issues you and others point out. But with most things political, there isn’t even an underlying objective reality to begin with. It’s almost purely identity and loyalty and ideological lenses and things. With climate, those things come into play every step of the way but it’s fundamentally different to me because there is an actual answer to a given query. We may not be able to get it at a given moment but it does exist. That’s the “objective” part I meant to be talking about. That's the problem with the current "politicizing" of everything. And it's all coming from one direction.
You post facts and the oppo sqays "it's all fake news" and puts out a whole pile of BS to confuse people. And very few people are willing to dig into the facts behind the blather, let alone have any idea how to go about it. Even people who really should know better.
Post by johneppstein on Jul 11, 2019 21:24:17 GMT -6
I have requested that this thread be locked. Making a political football of the impending disaster in New Orleans is, well, kinda despicable IMO.
Post by Tbone81 on Jul 11, 2019 21:29:55 GMT -6
You could have done that before your last 3 posts.
Post by drbill on Jul 11, 2019 21:50:45 GMT -6
I have requested that this thread be locked. Making a political football of the impending disaster in New Orleans is, well, kinda despicable IMO. John - you kicked the football into play with your politically tinged first post. Get over it, and do what you can for the people who are going to get hammered. I wish them Godspeed, and a way out of town!
Post by ragan on Jul 11, 2019 22:02:07 GMT -6
I don't think anyone here has been 'making a political football' of anything. Nor do I think the Let Me Get A Couple Jabs In And Then Try And Get The Thread Locked By Claiming Moral High Ground strategy is a valid.
There is no reason to get riled up about any of this. Good points speak for themselves. If you don't let your identity get attached to tribalism, you don't default to viewing everything as a personal affront when it conflicts with what you think.
Post by johneppstein on Jul 11, 2019 22:34:16 GMT -6
I have requested that this thread be locked. Making a political football of the impending disaster in New Orleans is, well, kinda despicable IMO. John - you kicked the football into play with your politically tinged first post. Get over it, and do what you can for the people who are going to get hammered. I wish them Godspeed, and a way out of town! My first post was not politically tinged, unless you think that quoting a major news organization is "political".
Post by johneppstein on Jul 11, 2019 22:34:47 GMT -6
Post by johneppstein on Jul 11, 2019 22:37:17 GMT -6
I don't think anyone here has been 'making a political football' of anything. Nor do I think the Let Me Get A Couple Jabs In And Then Try And Get The Thread Locked By Claiming Moral High Ground strategy is a valid. There is no reason to get riled up about any of this. Good points speak for themselves. If you don't let your identity get attached to tribalism, you don't default to viewing everything as a personal affront when it conflicts with what you think. I am not attached to or interested in "tribalism."
I'm interested in truth. Period.
Mind explaining exactly WHAT is "tribal" or "political" about that?
Post by drbill on Jul 11, 2019 23:46:07 GMT -6
John - you kicked the football into play with your politically tinged first post. Get over it, and do what you can for the people who are going to get hammered. I wish them Godspeed, and a way out of town! My first post was not politically tinged, unless you think that quoting a major news organization is "political". Hahaaa!!! Find me a major news organization that ISN'T political.
