Post by orphic on Mar 31, 2023 6:35:32 GMT -6
I just ordered a 308 after seeing Darrel Thorp use one on toms/floor. I'll experiment on that application and report back. (I normally use a CAD M179 on figure of 8 for this.) This Darrel Thorpe video? This was posted yesterday. My comment is way older. I was referring to one of his classes on ProMixAcademy.
Post by Quint on Mar 31, 2023 6:44:37 GMT -6
This Darrel Thorpe video? This was posted yesterday. My comment is way older. I was referring to one of his classes on ProMixAcademy. Got it. I didn't realize this video had just posted. In any case, the video I posted did make me want to try the 308.
Post by orphic on Mar 31, 2023 8:39:51 GMT -6
This was posted yesterday. My comment is way older. I was referring to one of his classes on ProMixAcademy. Got it. I didn't realize this video had just posted. In any case, the video I posted did make me want to try the 308. It's really good! It beat my CAD M179 on toms and floors by a large margin.
Post by EmRR on Mar 31, 2023 10:14:48 GMT -6
I still need to try in on toms. Many times it's just too big to fit in the space, and it'll be hard to beat the Oktava MK-102's. Still winning on acoustic bass near drums.
Post by Ward on Jun 11, 2023 17:51:30 GMT -6
Anyhow, I bought 4 of these to replace my old set of Neumann U89s on toms which were occasionally getting beaten and although much better than 421s or Cad M179s, still had a fair bit of cymbal bleed in the capture.
These microphones are THE TITS! Highly recommended!
Listen for yourselves. REcording chains are LS308s -> API 3124 -> Avid HD i/o -> Pro Tools. No editing, Just as is captured/
Post by wiz on Jun 11, 2023 19:21:53 GMT -6
great stuff
Post by ericn on Jun 12, 2023 10:20:36 GMT -6
Anyhow, I bought 4 of these to replace my old set of Neumann U89s on toms which were occasionally getting beaten and although much better than 421s or Cad M179s, still had a fair bit of cymbal bleed in the capture. These microphones are THE TITS! Highly recommended! Listen for yourselves. REcording chains are LS308s -> API 3124 -> Avid HD i/o -> Pro Tools. No editing, Just as is captured/ Your killing me!
Post by Ward on Jun 12, 2023 10:29:33 GMT -6
I think Trent is the one killing it! Someone should have been screaming from the rooftops: HOLY SHEET THERE'S THESE AMAZING TOM MICS YOU NEED! To all of us.
Post by sirthought on Jun 12, 2023 19:14:34 GMT -6
impressive
all the tone you'd want
Post by Ward on Jun 13, 2023 8:25:50 GMT -6
impressive all the tone you'd want Right? Just a regular run of the mill set of Sonor drums. Used the 12 13 and 14 toms, single ply remo heads.
Post by sirthought on Jun 13, 2023 19:20:35 GMT -6
impressive all the tone you'd want Right? Just a regular run of the mill set of Sonor drums. Used the 12 13 and 14 toms, single ply remo heads. I've been going in the direction of figure 8 pattern mics after hearing people like Doug and Craig talk about things like the Oktava 012 figure 8 head or the AEA R-92. I wonder if they somehow modded a bi-directional pattern to achieve this?
Post by Ward on Jun 14, 2023 9:34:28 GMT -6
Right? Just a regular run of the mill set of Sonor drums. Used the 12 13 and 14 toms, single ply remo heads. I've been going in the direction of figure 8 pattern mics after hearing people like Doug and Craig talk about things like the Oktava 012 figure 8 head or the AEA R-92. I wonder if they somehow modded a bi-directional pattern to achieve this? If you have a chance, pick one up (physically, not a euphemism for buying) and examine it. It's got an 'unused' capsule in the 'dead end'. And I suspect the same as you!
Post by ericn on Jun 14, 2023 9:47:47 GMT -6
I've been going in the direction of figure 8 pattern mics after hearing people like Doug and Craig talk about things like the Oktava 012 figure 8 head or the AEA R-92. I wonder if they somehow modded a bi-directional pattern to achieve this? If you have a chance, pick one up (physically, not a euphemism for buying) and examine it. It's got an 'unused' capsule in the 'dead end'. And I suspect the same as you! Yeah from just reading up on them, same phase cancellation idea as used in a shotgun mic to achieve the narrow lobe pattern. It’s really nothing new, others have tried just expense and manufacturing techniques have doomed the results. From all reports Trent seams to have nailed it.
Post by Ward on Jun 14, 2023 10:45:44 GMT -6
SNIP ... same phase cancellation idea as used in a shotgun mic to achieve the narrow lobe pattern. It’s really nothing new, others have tried just expense and manufacturing techniques have doomed the results. From all reports Trent seams to have nailed it. Exactly my thoughts also!
Post by ericn on Jun 14, 2023 11:59:52 GMT -6
SNIP ... same phase cancellation idea as used in a shotgun mic to achieve the narrow lobe pattern. It’s really nothing new, others have tried just expense and manufacturing techniques have doomed the results. From all reports Trent seams to have nailed it. Exactly my thoughts also! OK I’ll be honest here a lot of these early “ attempts “ would walk through our door to demo. The majority were failures or too delicate. These have made me quite jaded, thus I blew the Lauten attempts off, but You Doug and a couple of others have me itching to try these. First very rare used, a very very good sign, second I need to have some cash around because if they work I’m going to want a mic case full.
Post by christophert on Sept 16, 2023 16:15:36 GMT -6
After recording with the Lauten LS-308's on toms for the last week, I can definitely say IMO they are the best tom mics money can buy! Excellent rejection, great sounding, easy to position > no more cymbal bleed issues (thanks Ward for the recommendation)
Post by andersmv on Sept 18, 2023 21:52:07 GMT -6
Anyone try these on Snare? I’ve been tempted to try these, seems like a really interesting design idea.
Post by Ward on Sept 19, 2023 8:34:42 GMT -6
Anyone try these on Snare? I’ve been tempted to try these, seems like a really interesting design idea. See new thread I just started.
Post by andersmv on Sept 19, 2023 9:54:14 GMT -6
Anyone try these on Snare? I’ve been tempted to try these, seems like a really interesting design idea. See new thread I just started. Well shit, it even says "snare" on it...
