Post by Johnkenn on May 24, 2019 8:24:29 GMT -6
Just wondering if it’s bad enough that I don’t want to deal with it.
Post by Deleted on May 24, 2019 8:31:21 GMT -6
Post by Ward on May 24, 2019 9:34:52 GMT -6
Here's what you'll have to deal with . . . You could buy one or more, and then buy replacement KK84 capsule(s) and have them replaced. Probably costly.
Post by drbill on May 24, 2019 9:35:02 GMT -6
Just wondering if it’s bad enough that I don’t want to deal with it. Why the 85 John? Is there one available, or do you think it might be good for close mic-ing those guitars? If the latter, consider the 83. I've found you can get right up on the guitar, and really dial things in with that capsule/combo.
Post by Johnkenn on May 24, 2019 9:35:14 GMT -6
That actually seems pretty steep
Post by Johnkenn on May 24, 2019 9:35:59 GMT -6
Just wondering if it’s bad enough that I don’t want to deal with it. Why the 85 John? Is there one available, or do you think it might be good for close mic-ing those guitars? If the latter, consider the 83. I've found you can get right up on the guitar, and really dial things in with that capsule/combo. There’s one available for $750
Post by Johnkenn on May 24, 2019 9:37:06 GMT -6
And aren’t the new capsules like $400?
Post by Ward on May 24, 2019 9:46:59 GMT -6
Why the 85 John? Is there one available, or do you think it might be good for close mic-ing those guitars? If the latter, consider the 83. I've found you can get right up on the guitar, and really dial things in with that capsule/combo. There’s one available for $750 Seems a little high
Post by drbill on May 24, 2019 9:59:14 GMT -6
Why the 85 John? Is there one available, or do you think it might be good for close mic-ing those guitars? If the latter, consider the 83. I've found you can get right up on the guitar, and really dial things in with that capsule/combo. There’s one available for $750 Ahhh. Gotcha. Seems like a decent price.
Post by Ward on May 24, 2019 10:06:28 GMT -6
Post by Blackdawg on May 24, 2019 10:24:07 GMT -6
4dB per octave is pretty gentle. That would take care of proximity effect a lot.
Post by ericn on May 24, 2019 11:38:22 GMT -6
It’s gentle but it starts so frickin high that it just feels steep. The thing is if you put it real close thinking you will use the proximity effect to counter the roll off you notice this dip around. 200. The thing was designed for speech an installed sound where they would be mounted on goosenecks and the mics would be just left open. The low end cut kept feedback down and noise from page turns and thumps. Everybody I know who ever bought one ended up with an 84 capsule so I wouldn’t pay more than $500 thinking of it as just the electronics.
Post by Deleted on May 24, 2019 12:07:52 GMT -6
Yeah, if you want to reduce proximity, I second the "better off going for an 83" thang. Not that I have ever tried an 83 or 85 mind...
