Post by drbill on Apr 17, 2019 0:45:59 GMT -6
That's the sole reason I've felt that EchoFarm has been the best delay for me. Must try this one out.... Soon....
Post by Deleted on Apr 17, 2019 0:50:27 GMT -6
Just checked my emails, this is exactly what he said, regarding BBD Mode:
"We dialed it in from a Boss DM-2 (Past ERA) and Memory Man 1100-TT (Present), and then extrapolated the frequency response of those two for a brighter Future."
Post by drbill on Apr 17, 2019 9:17:47 GMT -6
Just checked my emails, this is exactly what he said, regarding BBD Mode: "We dialed it in from a Boss DM-2 (Past ERA) and Memory Man 1100-TT (Present), and then extrapolated the frequency response of those two for a brighter Future." Hmmm...Sounds like I'll still be using EchoFarm then. That's OK. I don't mind having both..,
Post by sean on Apr 17, 2019 12:11:45 GMT -6
The stock Pro Tools BBD isn’t (terrible) for that DMM sound
You can demo Valhalla stuff for free
Post by johneppstein on Apr 17, 2019 14:41:31 GMT -6
johneppstein Wack it in Tape Mode, Quad Style, Past Era, 6dB Drive, 50% Age, 50% Wow, 50% Flutter etc. I am hoping it's what you have been looking for. You can turn the taps on and off individually in real time. I mentioned your wishes to Sean while he was still developing it. It would appear that you don't remember what my exact beef with digital tape delay sims, is, but as far as I can see this one is no different,
It sure does a lot of stuff and I'm sure it does a bunch of neat stuff that you can't do with a real tape delay. But it still does not appear to do trhe one thing that I'm looking for. I know for damn sure that it's stuffed with "features" that I'm not particularly interested in or flat out don 't want.. I'm not interested in any of the "features" that claim to give an so-called "analog" sound by imitating a broken or badly out of adjustment tape echo. Wow and flutter? Not interested. Worn out tape? Throw it in the trash. Added noise? Definitely not interested.
What I want is a "motor speed" control that is unaffected by changing the "head selector". This is something that a person who hasw not put in a lot of hours using a Space Echo live at the console would probably never even think about. This allows using a long repeat synced to the tempo of the song on one sectiion, switchinbg to a fast slapback on another section, and returning to the initial timed repeat without having to retweak the "motor speed" after changing head selection. This is natural on a real Space Echo because the two timing settings are totally autonomous and do not affect each other in any way - they're different mechanical systems, one affecting tape speed, one affecting head spacing.
Post by Johnkenn on Apr 17, 2019 14:55:11 GMT -6
You can do all of that easily with automation.
Post by BradM on Apr 17, 2019 21:05:36 GMT -6
I'm assuming you didn't have to purchase Chop Shop... I think technically I paid many thousands of dollars for that one. Brad
Post by the other mark williams on Apr 17, 2019 21:14:30 GMT -6
I'm assuming you didn't have to purchase Chop Shop... I think technically I paid many thousands of dollars for that one. Brad I’m absolutely, positively sure you did.
Post by drbill on Apr 17, 2019 21:26:26 GMT -6
I think technically I paid many thousands of dollars for that one. Brad I’m absolutely, positively sure you did. I can verify that. I can also remember how Brad felt 24 hours after the release and it was already Kracked.....
Post by the other mark williams on Apr 17, 2019 23:58:34 GMT -6
I’m absolutely, positively sure you did. I can verify that. I can also remember how Brad felt 24 hours after the release and it was already Kracked..... Ugh, that's awful to hear. It has to be so demoralizing.
Post by BradM on Apr 18, 2019 10:02:58 GMT -6
Oh well. That's software for you. The next time I'm doing a hardware dongle. Brad
Post by ericn on Apr 18, 2019 10:10:29 GMT -6
Oh well. That's software for you. The next time I'm doing a hardware dongle. Brad The best hardware dongle is hardware its self!
Post by Mister Chase on Apr 18, 2019 13:12:06 GMT -6
Oh well. That's software for you. The next time I'm doing a hardware dongle. Brad The best hardware dongle is hardware its self! And when someone tries to take that, you give em the ole scatter gun treatment.
Post by joseph on Apr 18, 2019 16:48:52 GMT -6
I like how Sean's plugins are each like a curated exhibit of different sounds with various bandwidths, rather than the same engine used for different fx.
Post by viciousbliss on Apr 19, 2019 0:50:59 GMT -6
With some brief testing, I'd say this is up there with EC-300 and Echo Farm.
Post by kcatthedog on Apr 19, 2019 4:42:57 GMT -6
I am running one of the vocal presets on s current ruff mix and really liking it as it is somehow both very clean and precise and adding that desirable delay texture, mysterious coding but very well done !
Post by johneppstein on Apr 19, 2019 14:32:48 GMT -6
You can do all of that easily with automation. No, you can't. Not live, with the band playing live.
You could fake it on a studio recording but that's not the same thing.
As near as I can figure it out the problem is caused b y the fact that to a programmer changing bthe delay time is changing the delay time, while on a real mechanical tape box with multiple heads they are two separate and distinct operations that create similar (but not entirely identical) results but arrive at the result through different operations. In order to actually recreate the effect I want you'd need to have seperate delay lines for each individual "head" setting. Since the programmers creating the software (or hardware instantiations of it) have never used a Space Echo at the console during a live performance it doesn't make sense to them to use individual delay lines because they don't understand the effect.
The point is that you set up the motor speed control so that the delay is synced to the tempo. Them you can use the head select to switch instantly between short, mediuim, and long multiples of the delay timing whithout destroying the ability to return to the original synced setting. Every digital emulation of a Space Echo that I've seen to date autopmatically resets the "motor speed" to a permanently set default when you change the head select - because all it's doing is manipulating the timing of a single tapped delay line.
Even the Boss RE-20 Space Echo pedal gets it wrong - which really pissed me off when I discovereed that I'd just spent $250 on an "emulation" that can't do my favorite Space Echo trick.
You can almost pull it off with the Tap Tempo, but in this case "almost" doesn't cut it because there's still a very audible gap while you're tapping in a new tempo each time you change the "head" selector.
My typical use for this would be changing from a synced slapback during (for example) and uptempo verse section of a song to a slower, spacy multi head setting during a slower, more dramatic chorus section and then immediately popping back to the slap on sync at the next verse. Think of the kind of echo effects used in Dio-era Sabbath and similar stuff.
Yes, I'm talking about using it live.
I got the trick from the late Gordon "Gunji" Patterson, who was Sabbath's FOH guy on the 1980 Black And Blue Tour.
Post by johneppstein on Apr 19, 2019 17:06:32 GMT -6
johneppstein Wack it in Tape Mode, Quad Style, Past Era, 6dB Drive, 50% Age, 50% Wow, 50% Flutter etc. I am hoping it's what you have been looking for. You can turn the taps on and off individually in real time. I mentioned your wishes to Sean while he was still developing it. I'd like to discuss this with Sean if possible. It could be that I'm not understanding something about the user interface.
Post by adamjbrass on Apr 19, 2019 17:54:31 GMT -6
Valhalla 1, Wallet 0
Post by WKG on Apr 20, 2019 21:03:05 GMT -6
Just checked my emails, this is exactly what he said, regarding BBD Mode: "We dialed it in from a Boss DM-2 (Past ERA) and Memory Man 1100-TT (Present), and then extrapolated the frequency response of those two for a brighter Future." I used to use a DM-2 years ago and BBD mode certainly has that vibe to it.
Post by Deleted on Apr 21, 2019 0:01:18 GMT -6
Same, regret selling it, been thinking about getting the new Waza version.
Post by Mister Chase on Apr 21, 2019 0:38:03 GMT -6
Flawless victory. Fatality.
Post by drsax on Apr 21, 2019 9:39:15 GMT -6
Post by Johnkenn on Apr 25, 2019 13:05:23 GMT -6
Was playing with the Dirty Buckets preset in Guitars...is there a way to turn off the noise?
Post by kcatthedog on Apr 25, 2019 13:19:06 GMT -6
Haven’t found it yet either !
