Post by tasteliketape on Apr 3, 2019 19:04:30 GMT -6
I have a snare track with what I thought were bad hits on the snare . Two tracks top and bottom mic bussed together. Seems to be only on the snare top. There’s a annoying hollow ring only on a few hits thru out the song , maybe 6 hits total. Bring up eq and sweep there it is at 262 hz , pull it down it’s gone great. Start mixing again and there is the hollow ring again . I solo one of the offensive hits and loop to listen . It’ will be there one playback and not the next ,maybe gone a whole pass but in the next pass it’s back . WTF . Any ideas on what could be happening? There is only one plugin on the tracks Brainworx console N
Post by nudwig on Apr 3, 2019 19:20:34 GMT -6
Sounds kinda like something with delay compensation not being reported right? I doubt this but possibly the TMT modelling is causing a changing delay time, or maybe if you're on HDX one is running native and that's throwing it off? Have you tried a manual offset instead of the auto PT is doing? I'm curious to know what fixes you find.
Post by damoongo on Apr 3, 2019 19:33:38 GMT -6
What eq plug? Is it a demo? Sometimes the demo limitation is that it stops processing every few seconds for a moment. This exact thing happened to me with a phase alignment plug I was using on snare. Almost lost my mind chasing it down...
Post by tasteliketape on Apr 3, 2019 19:35:37 GMT -6
I’m running native 12.8.1 this just stared today last night when I quit mixing I thought the song was done . Also I haven’t changed anything. But your idea sounds probable Thanks I’ll check that out .
Post by tasteliketape on Apr 3, 2019 19:56:53 GMT -6
ok it’s gone away WTF . Last probably 5 playbacks it’s sounded great without the eq cut.
Post by damoongo on Apr 3, 2019 21:07:05 GMT -6
In that case I recommend going to sleep!
Post by Ward on Apr 6, 2019 17:15:46 GMT -6
25 years ago me wants to blame it on print-through
Post by ericn on Apr 8, 2019 2:03:03 GMT -6
Weird stuff like this is the way PT reminds you back up, back up and back up.
