Post by kcatthedog on Mar 8, 2019 16:09:13 GMT -6
On master buss or elsewhere: comments techniques ? I am experimenting with Fab filter. Go !
Post by Blackdawg on Mar 8, 2019 17:02:43 GMT -6
I use Mid Side stuff on the buss often. But there are other cool places to use it.
Haven't use the ProQ3 yet, but the MS filtering would be super awesome. One thing that can be helpful for some stuff is doing below XYZ Hz is mono only. Take a grungy bass in a hard rock back. 200hz and below is mono only, then say 350 and up goes to the sides. For doing the wall of sound guitar thing this would supplement it a lot.
I would say, use a light touch no matter what though.
Post by kcatthedog on Mar 8, 2019 17:08:33 GMT -6
One demo I saw suggested similar just start with say 500 hz for mid and then put a shelf high up and just experiment shifting things around a little to develop your ear.
Post by Blackdawg on Mar 8, 2019 18:00:47 GMT -6
Yeah can be cool for stuff like that. Just be careful with it
I use MidSide by Goodhertz a lot. Its a great midside plugin.
Post by MorEQsThanAnswers on Mar 8, 2019 19:01:47 GMT -6
Thoughts on Waves S1? I know a lot of people use it on mono sources, but I'm iffy on the idea. For panning stereo instruments and widening busses though... pretty damn useful!
Post by bartacusad on Mar 8, 2019 21:39:14 GMT -6
I use the Bax EQ on M/S mode on my Master all the time in varying amounts. Just gives everything a bit more breathing room.
Post by Deleted on Mar 9, 2019 2:32:57 GMT -6
I also do it fairly often. Whatever the track calls for.
Post by theshea on Mar 9, 2019 2:49:11 GMT -6
since i had my last album printed on vinyl i got into lo cutting the sides up to 150-200hz. i am doing this with klanghelm vumt deluxe.
Post by kcatthedog on Mar 9, 2019 6:29:42 GMT -6
Post by Martin John Butler on Mar 9, 2019 9:00:16 GMT -6
Personally I see drums as one instrument, not a half dozen separate pieces. I like them spaced just how they sound when you look at a drummer, bass drum center, hat and floor toms just a pinch to the side, if at all.
Post by Guitar on Mar 9, 2019 11:17:55 GMT -6
I use the Abbey Road TG mastering, and also sometimes the Brainworx Digital V3 for M/S EQ stuff on the master bus on some of my more in depth mixes.
Post by notneeson on Mar 9, 2019 11:24:58 GMT -6
Personally I see drums as one instrument, not a half dozen separate pieces. I like them spaced just how they sound when you look at a drummer, bass drum center, hat and floor toms just a pinch to the side, if at all. OH placement! OHs really needn’t sound overly wide in hard LR panning.
Post by Martin John Butler on Mar 9, 2019 12:16:22 GMT -6
Cool, thanks notneeson. I use overheads in Superior drummer II to dial in the right distance.
Post by javamad on Mar 9, 2019 13:09:17 GMT -6
I often use FF to do a low cut shelf on the sides and a high shelf boost at 12k or so on the sides.
This adds a bit of sparkle and centres the punch.
All subtle of course
Post by Guitar on Mar 9, 2019 14:03:55 GMT -6
On mixes with a lot of bass I will sometimes Mono-ize the bass up into the 100ish Hz area plus or minus. There's a few plugins that do this but my meter from Klanghelm has this feature built in so I just use that.
Post by notneeson on Mar 9, 2019 17:24:00 GMT -6
Cool, thanks notneeson. I use overheads in Superior drummer II to dial in the right distance. Gotcha, more of a virtual solution. I work with Inferior Drummer all the time. He's not the best, but he's real and he's got a lot of heart!
Post by kcatthedog on Mar 10, 2019 4:44:54 GMT -6
Remixed Created an aux with the MS BAX eq and only sent the guitars, reverbs and non lead vox to it. Lead vox, drums and bass go direct to stereo out, no MS, also narrowed the drum pan. Seems like a happy medium, not so Spacey, but the main mono parts are centred and the mix also has the ms quality. See what you think ? soundcloud.com/kcatthedog/ac...he-heavens-ms2
Post by hio on Mar 10, 2019 6:13:53 GMT -6
I agree with you the second mix is the better of the two and a happier medium ambassador.
