Post by tasteliketape on Feb 26, 2019 0:18:05 GMT -6
Specifications: Analogue dual channel FET limiter Switchable 456HD® tape simulation with trim control Ultra-wide band hand wound custom ferrite transformer balanced inputs and outputs 21-position stepped Threshold and Output potentiometers Wide range 10 position stepped Attack and Release time constants VU monitoring of Input, Output or Gain Reduction levels Channel link switch with LED indication Channel Bypass switches with LED Indication Front panel access to VU meter calibration Front panel access to gain reduction VU zero set Ultra low noise triple shielding construction using 6 layer PCB Stainless steel construction Gold plated Neutrik XLR connectors 48 Volt DC Meanwell universal world AC power supply supplied Dimensions: 3U 19-inch rack mount, 483x133x220mm (WxHxD) Weight: 4.2kg Hand built in the United Kingdom RRP: £2999 inc VAT (£2499.17 ex-VAT) ETA: Available now Available worldwide exclusively from KMR Audio: Recording Studio Equipment | Best Pro Audio in London - UK - Europe Trade pricing available - please contact sales@kmraudio.com
Post by Deleted on Feb 26, 2019 0:28:28 GMT -6
This new version looks quite different than the original, it seems to be from pictures a 3U unit with added tape simulation.
