Post by Johnkenn on Jan 30, 2019 15:15:55 GMT -6
Just getting suggestions...I was looking for an i7 Mac Mini...but I don't see any at like Tiger Direct or New Egg...Is there somewhere that bundles something like this for people like us.
Post by Johnkenn on Jan 30, 2019 15:17:03 GMT -6
And I could just buy one and swap my SSDs in, right?
Post by Tbone81 on Jan 30, 2019 15:44:25 GMT -6
Macofalltrades.com has goood deals on refurbished macs. I’ve bought 3 computers form them over the years with no problems
Post by svart on Jan 30, 2019 15:49:39 GMT -6
And I could just buy one and swap my SSDs in, right? I don't know about MAC OS, but windows won't work if you swap hardware like that. it stores a snapshot of your hardware and if it changes too drastically it'll assume you're trying to use that install of windows on a new computer. It's part of how they tried to curtail piracy.. I assume that Apple did the same thing..
Post by kcatthedog on Jan 30, 2019 15:56:04 GMT -6
No, you can normally swap Mac drives ok and load OS
But, although you can diy something’s on the new mini, Ram I don’t think ssd is one.
Also apparently Apple is using an unusual torx screw.
Many are just getting the 512 ssd as a boot drive, everything else on external.
Post by jampa on Jan 30, 2019 16:30:01 GMT -6
What's your interface?
There are some USB audio problems with newest macs. I'm looking at getting a Mac mini and will let you know how it goes
Post by Johnkenn on Jan 30, 2019 18:25:46 GMT -6
What's your interface? There are some USB audio problems with newest macs. I'm looking at getting a Mac mini and will let you know how it goes Tbolt
Post by kcatthedog on Jan 30, 2019 18:37:19 GMT -6
Mac sales has good deals on i7 retina mbp.
Post by stratboy on Jan 30, 2019 18:43:06 GMT -6
Macofalltrades.com has goood deals on refurbished macs. I’ve bought 3 computers form them over the years with no problems I’ve bought several used macs from macofalltrades. Always good experiences.
Post by ericn on Jan 30, 2019 19:09:50 GMT -6
Mac of all trades Mac Sales and local pawn shops have all been very good to me.
Post by bowie on Jan 30, 2019 19:47:28 GMT -6
And I could just buy one and swap my SSDs in, right? I don't know about MAC OS, but windows won't work if you swap hardware like that. it stores a snapshot of your hardware and if it changes too drastically it'll assume you're trying to use that install of windows on a new computer. It's part of how they tried to curtail piracy.. I assume that Apple did the same thing.. Not to side-topic this, what Windows looks for now is the motherboard to be the same. Depending on the type of license and how long you've been running it, Windows will sometimes flag it. If your license allows, you can do a limited number of mobo swaps (I don't believe they ever disclosed how many). I've had times when it went fine, others when it was either too soon or the license did not allow it. Storage drives won't matter, nor will the CPU. I did some heavy swapping in Win 10 recently on two machines and it was ok when the mobo remained the same. Regarding the main topic, if I were going with a new Mac/PC, I'd go for a fresh install for the smoothest possible performance.
Post by sirthought on Jan 30, 2019 23:53:12 GMT -6
Why not buy direct from Apple?
Buy the extra RAM from OWC. I would not attempt to change the hard drive on the Mini.
Post by mitchkricun on Jan 31, 2019 8:36:25 GMT -6
Why not buy direct from Apple? Buy the extra RAM from OWC. I would not attempt to change the hard drive on the Mini. So, what does one do if the hard drive dies? Get a new computer?
Post by sirthought on Jan 31, 2019 8:53:32 GMT -6
Send it for repair first. But the Mini is not designed for modification.
Post by Omicron9 on Feb 1, 2019 9:20:33 GMT -6
Post by jampa on Feb 6, 2019 3:51:20 GMT -6
Mac mini 2018 is everything I need. More money required for peripherals. RAM is user serviceable so I'll whack 32 gb in there
No problem with my DAC although it uses the core audio drivers (other DACs were affected by an apple update)
Post by lcr on Feb 6, 2019 5:50:39 GMT -6
Im patienlty waiting on the new pro...
Post by Ward on Feb 6, 2019 9:36:36 GMT -6
Im patienlty waiting on the new pro... You are not alone! Long live the Mac Server Pro!!
Post by lcr on Feb 6, 2019 9:43:11 GMT -6
I long for T bolt!
Post by ericn on Feb 6, 2019 9:58:46 GMT -6
I’m just waiting to see what “ Pro” means to Apple these days.
Post by ericn on Feb 6, 2019 10:03:59 GMT -6
It would be nice if Tim Cook and the gang would address these constant rumors that Apple is going to dump Intel chips for their own chips.
Post by Ward on Feb 6, 2019 10:16:16 GMT -6
It would be nice if Tim Cook and the gang would address these constant rumors that Apple is going to dump Intel chips for their own chips. It'd be even nicer if Jonathan Ives were in charge
Post by Johnkenn on Feb 6, 2019 11:22:35 GMT -6
Why not buy direct from Apple? Buy the extra RAM from OWC. I would not attempt to change the hard drive on the Mini. I’ve changed several. Not that hard if you just follow online directiona
Post by jcoutu1 on Feb 6, 2019 11:29:18 GMT -6
Why not buy direct from Apple? Buy the extra RAM from OWC. I would not attempt to change the hard drive on the Mini. I’ve changed several. Not that hard if you just follow online directiona On the newest model Mini, the hard drive is soldered to the logic board. It's *NOT* user upgradable (unless you've got a massive set of balls).
Post by ericn on Feb 6, 2019 11:38:02 GMT -6
I’ve changed several. Not that hard if you just follow online directiona On the newest model Mini, the hard drive is soldered to the logic board. It's *NOT* user upgradable (unless you've got a massive set of balls). Apple’s goal is to make it impossible for the user to do any upgrades, of course this means their “ genius’s” can’t do anything either.
