Post by Johnkenn on Dec 3, 2018 22:15:53 GMT -6
Yeah. Come to think of it, I’ve really liked everything I’ve had with Sowters.
Post by Mister Chase on Dec 3, 2018 22:17:06 GMT -6
Yeah. Come to think of it, I’ve really liked everything I’ve had with Sowters. Exactly. Time for me to get some Sowter gear. Bank says no. Some day.
Post by Blackdawg on Dec 3, 2018 22:58:45 GMT -6
Diode compressor is coming soon!
Post by Mister Chase on Dec 3, 2018 23:09:13 GMT -6
Diode compressor is coming soon! 2254 ish?
Post by Blackdawg on Dec 3, 2018 23:11:14 GMT -6
Diode compressor is coming soon! 2254 ish? Looks like it
Post by pope on Dec 4, 2018 2:38:20 GMT -6
Looks like the chandler limiter to me so I'd guess is that circuit that circulates on the DIY community? So, more similar to the tg compressor than to the 2254 I'd say. Somebody won't be very happy, lol.
Post by Ward on Dec 4, 2018 7:11:17 GMT -6
Diode compressor is coming soon! EDIT... I misspoke and I blame my brain. We often have these misunderstandings, where I have one thing in mind and my central processing unit has something else in mind, and then takes over my fingers.
Post by Blackdawg on Dec 4, 2018 9:39:17 GMT -6
Diode compressor is coming soon! Brings 'ice cold' audio to mind . . . what could be stiffer or colder than a Diode? an LED? (yes I know a diode as well, but using light so a new kind of opto-LED compression?) I'll stick with T4s and Choobs, thanks. Have almost no experience actually with diode bridge compressors. You don't like them?
Post by Blackdawg on Dec 4, 2018 10:01:03 GMT -6
Also they are definitely doing a Sta Level clone.
Post by Johnkenn on Dec 4, 2018 10:35:35 GMT -6
Also they are definitely doing a Sta Level clone. I'm first, damnit.
Post by jtc111 on Dec 4, 2018 11:03:19 GMT -6
Also they are definitely doing a Sta Level clone. I'm first, damnit. I've been standing in that line for a week now.
Post by indiehouse on Dec 4, 2018 11:33:15 GMT -6
Anyone know what transformers Retro is using? It seems Chris from AS likes to use Cinemag. I mean, the tubes alone in the Retro has got to be 300-500 bucks.
Post by Tbone81 on Dec 4, 2018 11:50:59 GMT -6
Diode compressor is coming soon! Brings 'ice cold' audio to mind . . . what could be stiffer or colder than a Diode? an LED? (yes I know a diode as well, but using light so a new kind of opto-LED compression?) I'll stick with T4s and Choobs, thanks. Not sure I follow. The few diode bridge comps I've used (2254, 33609) were very warm and euphonic sounding. You mention opto-LED's, is that what you're referring to?
Post by Mister Chase on Dec 4, 2018 13:50:28 GMT -6
Brings 'ice cold' audio to mind . . . what could be stiffer or colder than a Diode? an LED? (yes I know a diode as well, but using light so a new kind of opto-LED compression?) I'll stick with T4s and Choobs, thanks. Not sure I follow. The few diode bridge comps I've used (2254, 33609) were very warm and euphonic sounding. You mention opto-LED's, is that what you're referring to? Totally.
Post by Blackdawg on Dec 4, 2018 18:31:14 GMT -6
Anyone know what transformers Retro is using? It seems Chris from AS likes to use Cinemag. I mean, the tubes alone in the Retro has got to be 300-500 bucks. Be cool to swap sotwer into it..
Post by Ward on Dec 5, 2018 7:20:49 GMT -6
Brings 'ice cold' audio to mind . . . what could be stiffer or colder than a Diode? an LED? (yes I know a diode as well, but using light so a new kind of opto-LED compression?) I'll stick with T4s and Choobs, thanks. Have almost no experience actually with diode bridge compressors. You don't like them? Again, as per my edit . . . I misspoke and had something else in mind. My apologies. Don't tell the woman this, but I'll admit it here . . . I was wrong.
Post by Guitar on Dec 6, 2018 9:12:20 GMT -6
I hear you BlackDawg, but I still think that at least attack and release times should be dead on. I remember the shootout between an actual LA2A and the IGS one. It was perfect. Don't just consider attack and release times but also recovery time . . . the time it takes the compressor's 'engine' (like a T4 cell) to return to it's resting state. That can really affect the way a comp/limiter operates, sounds and ;rides' the waves, Technically speaking that is a more correct way to characterize and define "attack and release time" people get all bunched up sometimes trying to explain it to each other. But you are right.
Post by cowboycoalminer on Dec 6, 2018 17:06:07 GMT -6
What are you guys wanting, one of these?
Post by Mister Chase on Dec 6, 2018 17:08:30 GMT -6
Post by Johnkenn on Dec 6, 2018 19:26:01 GMT -6
Post by jtc111 on Dec 6, 2018 22:36:18 GMT -6
I'll take an A-S version. His gear doesn't disappoint.
Post by cowboycoalminer on Dec 6, 2018 22:39:22 GMT -6
What are you guys wanting, one of these? Well, a real one... You fargin bastage. This is fargin war!
Post by Mister Chase on Dec 6, 2018 22:49:10 GMT -6
They're real if I can feel 'em.
Post by Ward on Dec 7, 2018 10:42:30 GMT -6
You fargin bastage. This is fargin war! Always the ice-hole, aren't you Johnny?
Post by the other mark williams on Dec 7, 2018 14:06:15 GMT -6
You fargin bastage. This is fargin war! Always the ice-hole, aren't you Johnny? "No, but I know this grapevine."
