Post by Johnkenn on Nov 28, 2018 22:40:52 GMT -6
I think dandeurloo pointed this out, and I didn’t really notice at first, but the Proq2 does need to be run in llinear to be as effective as it should be. I really noticed with the low end. It’s really different when you add the top horsepower.
Post by Deleted on Nov 29, 2018 2:50:46 GMT -6
Nov 29, 2018 5:38:26 GMT 1 Johnkenn said: Is it Thursday yet? Depends where you live. It is here.
Post by kcatthedog on Nov 29, 2018 3:04:42 GMT -6
Yes! 30 day demo and discounted in your account: nice !! Interesting presets
Post by kcatthedog on Nov 29, 2018 3:10:03 GMT -6
Post by kcatthedog on Nov 29, 2018 4:31:24 GMT -6
Just started dropping it into an existing mix and turning off existing eq. In each instance preferred ffq3, cleaner, precise, easy to set: all those normal ff attributes.
i’ll be buying for sure.
Anybody use the ff saturation plug ?
Post by roundbadge on Nov 29, 2018 6:26:22 GMT -6
Bought.. for my upgrade price 60 bucks. done deal my all time favorite software eq is officially off the charts now.
Post by roundbadge on Nov 29, 2018 6:30:35 GMT -6
Anybody use the ff saturation plug ? Every Day..just used it to get a real B3/leslie and Wurli to cut through a dense wall of rock guitars. absolute genius plug in. looove that thing!
Post by roundbadge on Nov 29, 2018 6:43:00 GMT -6
wow.. the new features/operation and graphic response ..and sound..fkkin ay!
Post by Blackdawg on Nov 29, 2018 9:24:23 GMT -6
jesus I just watched the demo. Wow.
Post by brenta on Nov 29, 2018 10:07:36 GMT -6
Anybody use the ff saturation plug ? Saturn? Yep.
Post by brenta on Nov 29, 2018 10:10:19 GMT -6
wow.. the new features/operation and graphic response ..and sound..fkkin ay! Does it sound different, or just new features? I'm not sure if this is a worthwhile upgrade for me even at $65, I've already got a few dynamic EQs.
Post by jcoutu1 on Nov 29, 2018 10:10:28 GMT -6
jesus I just watched the demo. Wow. Bad ass. Their demos are some of the best in the business. FabFilter - Elysia - Thermionic Culture Other companies should take notes.
Post by jcoutu1 on Nov 29, 2018 10:12:04 GMT -6
You guys like Pro L2 better than the original? I haven't upgraded yet, but since I'm going to grab ProQ3, I figure I should make the most of my money.
Post by Blackdawg on Nov 29, 2018 10:15:49 GMT -6
You guys like Pro L2 better than the original? I haven't upgraded yet, but since I'm going to grab ProQ3, I figure I should make the most of my money. Im planning on it. Should have gotten it when it was on sale last week for surround purposes. I think the new loudness metering is a very nice touch too. Haven't heard it though.
Post by ragan on Nov 29, 2018 11:11:51 GMT -6
You guys like Pro L2 better than the original? I haven't upgraded yet, but since I'm going to grab ProQ3, I figure I should make the most of my money. Yes. The “Modern” setting is the best I’ve heard for loudness and I use the “Safe” setting for transparently locking individual tracks in place all the time. Particularly bass and lead vox.
Post by Guitar on Nov 29, 2018 11:49:00 GMT -6
You guys like Pro L2 better than the original? I haven't upgraded yet, but since I'm going to grab ProQ3, I figure I should make the most of my money. Yes, the Pro L2 is an incremental improvement over Pro L1
Post by ragan on Nov 29, 2018 11:53:17 GMT -6
Had I quick play with the ProQ3. I'll be buying it. Dynamic EQ, while probably the same shit under the hood as ProMB, is just really fast and intuitive to use when it's integrating with the EQ. Also per-band m/s is amazing. Was messing with stereo drum OH and it was extremely powerful the way you could manipulate the image.
FabFilter is my favorite plugin company. More and more I just get the 'tone' and weight and size and stuff from hardware and then use FabFilter stuff for the ITB sculpting.
Post by notneeson on Nov 29, 2018 12:13:20 GMT -6
More and more I just get the 'tone' and weight and size and stuff from hardware and then use FabFilter stuff for the ITB sculpting. This, specific tools aside, is my approach as well.
Post by sirthought on Nov 29, 2018 13:18:25 GMT -6
So if this thing has built in compression, are you still using separate compression with it? Before or after?
Post by Guitar on Nov 29, 2018 14:22:59 GMT -6
So if this thing has built in compression, are you still using separate compression with it? Before or after? It's not "compression" in the sense of a channel strip. It's compression or expanding PER-BAND of each individual EQ filter. You can do a ton of cool stuff with it, for example boosting highs on a snare and ducking when the hi hat bleed hits. I just did that the other day. On a vocal you're still going to need your MJUC or whatever you use.
Post by sirthought on Nov 29, 2018 15:39:46 GMT -6
It's not "compression" in the sense of a channel strip. It's compression or expanding PER-BAND of each individual EQ filter. You can do a ton of cool stuff with it, for example boosting highs on a snare and ducking when the hi hat bleed hits. I just did that the other day. On a vocal you're still going to need your MJUC or whatever you use. Thanks for the explanation. It seems a bit to me like how the Newfangled EQuviocate describes their multiband EQ. I own that but haven't really sunk my teeth into learning it yet.
Post by Guitar on Nov 29, 2018 15:41:44 GMT -6
It's not "compression" in the sense of a channel strip. It's compression or expanding PER-BAND of each individual EQ filter. You can do a ton of cool stuff with it, for example boosting highs on a snare and ducking when the hi hat bleed hits. I just did that the other day. On a vocal you're still going to need your MJUC or whatever you use. Thanks for the explanation. It seems a bit to me like how the Newfangled EQuviocate describes their multiband EQ. I own that but haven't really sunk my teeth into learning it yet. Equivocate is pretty cool. It's basically a big graphic EQ but it has a sound to it. I like it for notching out annoying frequencies and maybe some very small boosts on a master.
Post by kcatthedog on Nov 29, 2018 16:16:02 GMT -6
Post by Guitar on Nov 29, 2018 16:23:25 GMT -6
that is the most insane link I have ever seen, and it does not work :-D
Post by Blackdawg on Nov 29, 2018 16:24:01 GMT -6
Its just protools expert's review on it. But he linked it through Facebook...for some reason haha
