Post by indiehouse on Nov 22, 2018 21:02:48 GMT -6
So, I had planned to demo Sonarworks because they have a good sale going on right now. BUT, I just found out that I can't use my miniDSP USB calibration mic with Sonarworks. Damnit. Now I can't demo because I don't have another measurement mic.
Is Sonarworks that good? Good enough to warrant going through the hassle of buying a measurement mic?
Post by sirthought on Nov 22, 2018 23:34:16 GMT -6
I'm in the same boat. Considering buying it, but I don't have a measurement mic to test it out.
Post by stormymondays on Nov 23, 2018 1:15:05 GMT -6
In my pro designed and treated room, it provided the final 10% of monitoring accuracy for me. I bought the full package including the calibrated mic.
Post by jin167 on Nov 23, 2018 2:58:12 GMT -6
grab a mic that has a relatively flat frequency response. Not ideal but it does work and gives you an idea of what the software is capable of. I did my measurement with the line audio cm3 and it worked like a charm.
Post by stormymondays on Nov 23, 2018 3:28:26 GMT -6
There's the cheap Behringer measurement microphone which I've heard is pretty decent.
Post by Deleted on Nov 23, 2018 3:36:56 GMT -6
KM84?
Post by avgatzeblouz on Nov 23, 2018 7:30:00 GMT -6
There's the cheap Behringer measurement microphone which I've heard is pretty decent. That's the one Sonarworks is selling. It is just rebranded. To me, Sonarworks is brilliant. I did not notice an improvement by using their own mic, even if you can load its frequency response in the soft, instead of the Behringer ECM8000.
Post by Blackdawg on Nov 23, 2018 7:44:36 GMT -6
So, I had planned to demo Sonarworks because they have a good sale going on right now. BUT, I just found out that I can't use my miniDSP USB calibration mic with Sonarworks. Damnit. Now I can't demo because I don't have another measurement mic. Is Sonarworks that good? Good enough to warrant going through the hassle of buying a measurement mic? Surely you could do some in computer routing trickery with SoundFlower to make it work. That said. Could pick up an earthworks m30 or something relatively cheap. Or I'd go for a DPA4006 if you wanted a super versitile mic at the same time.
Post by rob61 on Nov 23, 2018 8:24:20 GMT -6
I purchased their mic and demo version of software for $50 on sale. Each mic is calibrated with info data to help the program measure correctly. It is not a high quality mic, but since they've calibrated it (with off axis response) it does allow the software to better calibrate your room. That said, I never bought the software. It did help somewhat, but didn't want to deal with the inconvenience. Their software that was to work "system wide" never worked well on my Windows 7 system, but the plug in used with Nuendo worked ok. You just have to remember to turn it off when printing any audio (exporting mixes or running final mix through the buss).
Post by mikec on Nov 23, 2018 8:27:24 GMT -6
I had the old IK Multimedia ARC 2 mic and used that to demo the Sonarworks software. After I bought the Sonarworks package with the mic and the calibrated HD650 headphones I redid the measurements with the mic that came with the Sonarworks package and even though I did not have the calibration code to enter from the ARC 2 mic, the measurements were not that far off from each other. Even though my room is treated pretty well I still have a bump from about 150 to 250 Hz that made it harder to mix the low end. Using Sonarworks has made a huge difference in being able to accurately mix the low end so that mixes translate better for me.
Post by jin167 on Nov 23, 2018 8:50:39 GMT -6
BTW where is the best place to buy the sonarworks + mic package if you are living outside of US?
Post by stormymondays on Nov 23, 2018 9:27:55 GMT -6
BTW where is the best place to buy the sonarworks + mic package if you are living outside of US? Direct from Sonarworks.
Post by avgatzeblouz on Nov 23, 2018 12:15:43 GMT -6
You just have to remember to turn it off when printing any audio (exporting mixes or running final mix through the buss). If I may, let me share my workaround for this : I plug in my soundcard SPDIF out to SPDIF in. Then I use Patchwork standalone, a VST chainer, in which I selct SPDIF in as input, and my analog outs for monitoring as outputs. I use SPDIF out as my DAW main out, and even my Windows default output. That way I always have Sonarworks processing my audio, without using it in my DAW. No fear to forget to bypass it when printing, and it is applied to every audio coming out of the computer.
Post by Bob Olhsson on Nov 23, 2018 16:12:02 GMT -6
The most effective room tuning I ever heard was done with a KM-84. Don Davis was recommending the AKG D224 during the late '80s. The problem with omnis is that the pattern isn't as uniform as an 84 or D224.
Post by Blackdawg on Nov 23, 2018 16:19:14 GMT -6
The most effective room tuning I ever heard was done with a KM-84. Don Davis was recommending the AKG D224 during the late '80s. The problem with omnis is that the pattern isn't as uniform as an 84 or D224. I'd never use a km84 for that. It's no a flat mic at all. A 4006a would be much better for that or other reference mics out there now.
Post by dror520 on Nov 25, 2018 1:56:20 GMT -6
Are you guys using it at 100% wet so it's completely flat?
Post by stormymondays on Nov 25, 2018 3:00:26 GMT -6
Are you guys using it at 100% wet so it's completely flat? Yes
Post by mikec on Nov 25, 2018 8:21:51 GMT -6
Sonarworks
Nov 25, 2018 13:47:00 GMT -6
via mobile
Post by jampa on Nov 25, 2018 13:47:00 GMT -6
Yep 100% wet but only using it with headphones.
Other people have suggested a "range function", so that it only corrects below say, 180Hz. It doesn't exist, but I'd love to try that out
Post by indiehouse on Nov 25, 2018 14:08:05 GMT -6
I'm still wavering on this. I'd love for it to help with my low end, especially after hearing what the Trinnov did for me. I just can't demo the damn thing without a measurement mic. BUT, it's on sale for a great price right now. Urgh.
I hear mixed reviews on it. Some say it's great, others not so much. I do have Dirac, but always found it a pain in the ass to use, so I stopped using it.
Post by Blackdawg on Nov 25, 2018 15:19:18 GMT -6
I'm still wavering on this. I'd love for it to help with my low end, especially after hearing what the Trinnov did for me. I just can't demo the damn thing without a measurement mic. BUT, it's on sale for a great price right now. Urgh. I hear mixed reviews on it. Some say it's great, others not so much. I do have Dirac, but always found it a pain in the ass to use, so I stopped using it. Do you not have the Trinnov anymore? Why not?
Post by indiehouse on Nov 25, 2018 16:19:31 GMT -6
I'm still wavering on this. I'd love for it to help with my low end, especially after hearing what the Trinnov did for me. I just can't demo the damn thing without a measurement mic. BUT, it's on sale for a great price right now. Urgh. I hear mixed reviews on it. Some say it's great, others not so much. I do have Dirac, but always found it a pain in the ass to use, so I stopped using it. Do you not have the Trinnov anymore? Why not? Over 4,000 reasons.
Post by Blackdawg on Nov 25, 2018 18:51:24 GMT -6
Do you not have the Trinnov anymore? Why not? Over 4,000 reasons. Lol okay, fair enough.
Post by Blackdawg on Nov 25, 2018 22:14:54 GMT -6
Im on the fence about this..
I've listened to the online demo with Sony 7506s and AKG702s. Im not sure I like what it does. Its supposed to make them flat which really makes the bass really freaking loud.
I can see it being helpful potentially with monitors in a room but on headphones I don't think this great. It would be better to just learn how your headphones sound and translate I think.
Plus Id have to get osx10.9 to run it haha
Think I'll pass on it for now. Would be cool to try and run the demo at the studio later though. see if it is better than the Genelec GLM software.
Post by stormymondays on Nov 26, 2018 2:37:21 GMT -6
Sounds really great on my Sony 7506.
