Post by kcatthedog on Nov 15, 2018 12:36:34 GMT -6
Post by guitfiddler on Nov 15, 2018 14:22:39 GMT -6
What if you own those plugs already? Then what does the promotion do for you? In the past UA used to give you a voucher for the amount of those plugins, so you could buy the ones you don’t have. At least that’s what I did back when I started this rabbit hole.
Post by kcatthedog on Nov 15, 2018 14:54:18 GMT -6
Yes, that is normal practice, you’d have to check the fine print to confirm ?
Or maybe Drew will chime in ?
Post by sirthought on Nov 15, 2018 20:03:50 GMT -6
What if you own those plugs already? Then what does the promotion do for you? In the past UA used to give you a voucher for the amount of those plugins, so you could buy the ones you don’t have. At least that’s what I did back when I started this rabbit hole. If you actually go to the product page, logged in, it tells you what you already own and the deal you can get.
