Post by Mister Chase on Sept 9, 2018 14:06:39 GMT -6
People have already proven with the 8p that you can run 8 73 unison pres while tracking: that’s a fact not a supposition. But that was about it as in board dsp including console load was pretty well maxed. Now, with X you still have 2 more sharc chips per apollo. So, I was hoping Drew would say, yes , in addition to the 16 instances of 73 unison pres,you could add , say 1176’s and 2a’s in the daw and or run your aux verbs in console ? Right. I am not challenging that fact, rather trying to estimate what I would be able to run in Unison. For instance, a 1073 and Studer, how about an 1176, too? That sort of thing matters as someone who's never used an Apollo needs to know if I am considering buying one. So I was just checking to see if I was interpreting the instance chart correctly to add up what I may be able to run or not in a Unison situation.
As far as the 1176s and 2as in the DAW, that could be useful.
Post by Drew @ UA on Sept 9, 2018 15:02:05 GMT -6
People have already proven with the 8p that you can run 8 73 unison pres while tracking: that’s a fact not a supposition. But that was about it as in board dsp including console load was pretty well maxed. Now, with X you still have 2 more sharc chips per apollo. So, I was hoping Drew would say, yes , in addition to the 16 instances of 73 unison pres,you could add , say 1176’s and 2a’s in the daw and or run your aux verbs in console ? So I just did a test with 1 x8P. In Console: I got eight 1073s in Unison slots, 6 of them with LA2 Silvers in slot 1, 2 with DBX 160s in slot1. Lex 224 and Galaxy on the two auxes. This got me to 80% DSP usage. I then opened Pro Tools and inserted two 1176 rev As in stereo, one rev a in mono and a mono Distressor. DSP @ 93%. Is this helpful? If not, let me know a test you'd like me to do.
Post by kcatthedog on Sept 9, 2018 15:14:14 GMT -6
Oh ya, so everything after the 8 73’s is because of X’s new typology and the extra sharc chips.
Seriously hat’s off to the UA design team for doubling down: that is very impressive!
UAD X
Sept 12, 2018 5:10:39 GMT -6
Post by allbuttonmode on Sept 12, 2018 5:10:39 GMT -6
So I just did a test with 1 x8P. In Console: I got eight 1073s in Unison slots, 6 of them with LA2 Silvers in slot 1, 2 with DBX 160s in slot1. Lex 224 and Galaxy on the two auxes. This got me to 80% DSP usage. Hi Drew. A question regarding DSP and the Apollos: Why can't external Satellites be used towards running plugins on the channels being recorded? Thanks, Kai
UAD X
Sept 12, 2018 5:19:10 GMT -6
Post by Drew @ UA on Sept 12, 2018 5:19:10 GMT -6
So I just did a test with 1 x8P. In Console: I got eight 1073s in Unison slots, 6 of them with LA2 Silvers in slot 1, 2 with DBX 160s in slot1. Lex 224 and Galaxy on the two auxes. This got me to 80% DSP usage. Hi Drew. A question regarding DSP and the Apollos: Why can't external Satellites be used towards running plugins on the channels being recorded? Thanks, Kai DSP must remain "local" so that your signal doesn't need to go out on the TB buss and through the routing chip etc.
UAD X
Sept 12, 2018 6:08:57 GMT -6
Post by allbuttonmode on Sept 12, 2018 6:08:57 GMT -6
DSP must remain "local" so that your signal doesn't need to go out on the TB buss and through the routing chip etc. Thank you for the reply, Drew. So, it's a bandwith issue? Even over Thunderbolt?
Post by drsax on Sept 12, 2018 6:13:52 GMT -6
DSP must remain "local" so that your signal doesn't need to go out on the TB buss and through the routing chip etc. Thank you for the reply, Drew. So, it's a bandwith issue? Even over Thunderbolt? I don’t think it’s a bandwidth issue. I’m pretty sure it’s to keep latency down when Recording with UAD plug-ins
Post by Drew @ UA on Sept 12, 2018 6:41:40 GMT -6
Correct. Even TB1 has WAYYY more bandwidth than our entire system needs.
Post by Drew @ UA on Oct 9, 2018 13:13:40 GMT -6
Post by Drew @ UA on Dec 7, 2018 17:43:10 GMT -6
UAD X
Dec 10, 2018 11:26:51 GMT -6
Post by sirthought on Dec 10, 2018 11:26:51 GMT -6
Still no fix on saving the console channel names?
UAD X
Dec 10, 2018 19:42:41 GMT -6
Post by Drew @ UA on Dec 10, 2018 19:42:41 GMT -6
Not yet. On the list for sure.
