Post by reddirt on May 30, 2018 10:06:23 GMT -6
G'day guys, my newest desire is for a stereo (blumlein) mic to get sources in an easy, no fuss, phase coherent way. Pianos, acoustics , overheads etc ,as much as possible keeping it real; less edge but enjoying the space as well. Thinking of the AEA ;is that in your experience an excellent option and are there others I should consider?
Cheers, Ross
Post by Omicron9 on May 30, 2018 10:32:09 GMT -6
About a year ago, I had the AEA stereo ribbon, a Royer SF-12, and the Mesanovic stereo ribbon side-by-side in my studio for a few days. The AEA was far too dark and muddy for me. The Royer had many fine qualities, but the bass response falls off sharply around 30Hz, and for some bass-register instruments I record, that was an audible issue. The Mesanovic (for me) had it all: massive and extended bass response, clear, full top end, rich mids, and incredible stereo imaging; I daresay the imaging was better than the AEA or Royer. I bought the Mesanovic, and keep thinking of buying a 2nd one. However, the schools of ribbons (vintage (AEA) vs. modern (Mesanovic)) are very much a personal thing. They were all exceedingly fine mics, but the Mesanovic totally and entirely blew me away, based on my aesthetics and application and personal taste. You may owe it to yourself to check it out: www.mesanovicmicrophones.com/model-2sDisclaimer: I am not affiliated with the company; I know I sound like an ad, but seriously I find it stunning. I also have a Cascade X-15. Far less $ than the Mesanovic, but I really like it. More in the modern camp instead of vintage. www.cascademicrophones.com/cascade_x15-stereo-ribbon.htmlRegards, -09
Post by Tbone81 on May 30, 2018 10:40:36 GMT -6
I absolutely love the royer sf-12, definitely worth checking out.
In the low end catagory I Always wondered how the cascade x15 and rm biv sounded
Post by EmRR on May 30, 2018 11:00:23 GMT -6
The Samar is very good. VL373A is the dedicated stereo version. I have the MF65's with the Blumlein mount.
Post by nick8801 on May 30, 2018 14:51:37 GMT -6
I have the aea and love it. It can be dark, but with the right preamp I find it is incredibly natural and full. It’s important to remember how sensitive passive ribbons are to impedance. Never tried the royer, but I know some people just love those as well. It’s really all about taste. If you want a slightly more vintage vibe, the aea stuff is hard to beat.
Post by Guitar on May 30, 2018 16:38:16 GMT -6
It's on my bucket list, haha. Nice thread.
Post by rob61 on May 30, 2018 16:48:20 GMT -6
I have an AEA R-88 (along with several other ribbon mics). It is very open and and natural sounding, but the preamp is very important. I use the R-88 with the AEA TRP mic preamp for best results. The large ribbon design is close to the RCA 44, but in stereo. It uses the same foil (ribbon material) as the 44. The Mesanovic I believe uses a thinner ribbon material, so it should be a bit more "modern" sounding.
Post by ulriggribbons on May 30, 2018 17:43:05 GMT -6
Stated geometry of the Mesanovic mic, as well as the ribbon thickness, is roughly the same as the R88. He appears to be using a higher turns ratio output transformer(1:36 stated on the website), which wouldn't set the output impedence to 250 ohms as stated, but that's just geekin on the numbers. Realistically it would be more like 330 ohms.
Ribbon thickness won't have much to do with how modern a ribbon mic sounds. The 4038 uses a ribbon 3 times thinner than these two mics, so that would make it "futuristic sounding" =)
That said, all of the microphones listed certainly sound good, and are worthy of consideration.
I don't make a stereo ribbon mic, so I get to say these things, right? =P
Post by Guitar on May 30, 2018 17:46:30 GMT -6
Stated geometry of the Mesanovic mic, as well as the ribbon thickness, is roughly the same as the R88. He appears to be using a higher turns ratio output transformer(1:36 stated on the website), which wouldn't set the output impedence to 250 ohms as stated, but that's just geekin on the numbers. Realistically it would be more like 600 ohms. Ribbon thickness won't have much to do with how modern a ribbon mic sounds. The 4038 uses a ribbon 3 times thinner than these two mics, so that would make it "futuristic sounding" =) That said, all of the microphones listed certainly sound good, and are worthy of consideration. I don't make a stereo ribbon mic, so I get to say these things, right? =P I'm just glad you're posting here, Jon!
Post by ulriggribbons on May 30, 2018 18:04:15 GMT -6
Hey Thanks Monkeyxx,
I love me some ribbon mics
I should also note that the X15 (PPA R-2) often suffers from ribbon sag, and sounds a lot better with a higher quality ribbon installed. I've done a bunch of them over the years (PPA was local to me, so a lot of local people had me repair/reribbon them). That said, for the money they sound pretty good. New ribbons and better output transformers makes them more respectable.
I've also worked on several of the B&O stereo ribbons (BM6). Personally, I'd steer away from them. The magnets they use were of low quality, and lose their magnetism over time, so they often suffer from extremely anemic output. I think that Stewart in the UK (xaudia.com) rebuilds them with new magnets, so if you land a deal on one, they can be brought up to snuff again. That said (I have one in for repair right now), other people like the sound of them.
Coles make a stereo ribbon, the 4050. Has a super cool magnetic mounting system, but I don't see a lot of mention of it, and haven't worked with them personally.
That covers all the stereo ribbons I can think of, are there others?
Post by rob61 on May 30, 2018 18:08:03 GMT -6
Yes, Joh has a point. The Coles 4038 (I have a pair of those as well) has I believe a .8 micron ribbon, whereas the AEA uses the original 2.5 micron foil, or so I was told. I believe the Mesanovic uses 1.8 micron, but I could be mistaken. I find the transient response is somewhat affected by the ribbon thickness, and thus my mention of a more "modern" sound in the Mesanovic. Perhaps that was the wrong description. But it does handle transients a bit differently. As Jon pointed out, I'm sure the transformers play a part in that as well.
Post by nick8801 on May 30, 2018 18:10:49 GMT -6
Peluso makes one too, right?
Post by ulriggribbons on May 30, 2018 18:33:09 GMT -6
Hey Rob,
Here's what I know from my experience:
The Coles is a .6 um ribbon.
The RCA ( I bought a book of original foil for repairing RCA mics) responds closer to 1.8 um than the 2.5um, when making comparisons to the foil I use.
AEA and Mesanovic both state 1.8 um thickness on the datasheet for the their respective microphones.
I'm not in any way saying your description is wrong or commenting on what you are hearing, and in fact appreciate you sharing that part. I'm just trying to make clear the technical similarities and differences, which can lead more to what aspects of the design are impacting what you hear.
Nick, you are right, Peluso also make a stereo ribbon mic. I've yet to see any of their microphones, so don't have any perspective on it. Has anyone else used one?
Regards
Jon
Post by jeromemason on May 30, 2018 23:28:24 GMT -6
I'm endorsed by them, but any of Royer's SF stereo ribbons are amazing.
Now, if you want and are able to make a solid investment the SF-24v is probably one of the most impressive mic's I've ever heard. It can pull out things in instruments and voice like none other, and what it does just brings you to an awe. They are in the $5k range, but you can put that mic in front of anything and it's going to sound incredible. Plus, just seeing first hand how much love those guys put into building each mic that goes out is impressive in itself, they really care about what goes out of their shop, a pretty big company that operates like a little boutique one. Some amazing gentleman that head it up too.
Post by rob61 on May 31, 2018 3:29:08 GMT -6
Thanks Jon for the corrections on the exact numbers, should have checked data sheets before posting. Do you happen to know the foil thickness originally used in the RCA 77DX? Still love that mic!
Post by rowmat on May 31, 2018 4:23:24 GMT -6
We have a Cascade X15 stereo ribbon fitted with Lundahl transformers which is our go-to mic for our 100 year old pump organ. We use it in M/S mode.
Post by Ward on May 31, 2018 6:20:57 GMT -6
Totally agree with this. I have an AEA R-88 (along with several other ribbon mics). It is very open and and natural sounding, but the preamp is very important. I use the R-88 with the AEA TRP mic preamp for best results. The large ribbon design is close to the RCA 44, but in stereo. It uses the same foil (ribbon material) as the 44. The Mesanovic I believe uses a thinner ribbon material, so it should be a bit more "modern" sounding. Can't agree with this. I have a load of ribbons, including ones mentioned, but the Samar is hifi whereas the AEA sounds really vintage
Post by Omicron9 on May 31, 2018 8:17:57 GMT -6
...snip.... I don't make a stereo ribbon mic, so I get to say these things, right? =P Maybe you should make a stereo ribbon!
Post by ulriggribbons on May 31, 2018 9:58:34 GMT -6
Thanks Jon for the corrections on the exact numbers, should have checked data sheets before posting. Do you happen to know the foil thickness originally used in the RCA 77DX? Still love that mic! To my knowledge, it uses the same foil that was used in the other RCA mics, just a much smaller geometry ( .6" X 1" ) Regards Jon
Post by svart on May 31, 2018 12:24:20 GMT -6
SF12 is probably the best of the bunch IMHO.
Post by reddirt on May 31, 2018 13:47:08 GMT -6
Wow, what a great lot of replies; not sure where its left me but there's sure heaps to chew over. I appreciate your efforts fellas. Cheers, Ross
Post by Tbone81 on May 31, 2018 14:05:25 GMT -6
...snip.... I don't make a stereo ribbon mic, so I get to say these things, right? =P Maybe you should make a stereo ribbon! I second that notion, could always use another stereo ribbon option. BTW Jon - just got the two shiny box ribbons you sent me...can't wait to try them out. If I have time I'll record a few things with them and post them hear.
Post by guitfiddler on May 31, 2018 16:29:00 GMT -6
Maybe you should make a stereo ribbon! I second that notion, could always use another stereo ribbon option. BTW Jon - just got the two shiny box ribbons you sent me...can't wait to try them out. If I have time I'll record a few things with them and post them hear. Still waiting on my shinyness! Shiny happy people...sorry, couldn’t help it.
Post by ariel on Jun 6, 2018 2:42:00 GMT -6
I am also thinking about picking up a Mesanovic model 2S possibly. Not too many demos of it out there on drums. But the one I heard on their site sounded perfect.
Post by Omicron9 on Jun 6, 2018 7:26:19 GMT -6
I amalso thinking about picking up a Mesanovic model 2S possibly. Not too many demos of it out there on drums. But the one I heard on their site sounded perfect. I totally love mine. So much that I keep arguing with myself about buying a 2nd one. This time, it's love. -09
