HD vinyl
Apr 11, 2018 14:52:12 GMT -6
via mobile
Post by c0rtland on Apr 11, 2018 14:52:12 GMT -6
Post by ericn on Apr 11, 2018 15:22:43 GMT -6
Yep it’s why I don’t buy new vinyl I hear the sound of protools! Damnit if I’m going to buy a new turntable the sound of PT is what I’m try to escape!
Post by c0rtland on Apr 11, 2018 15:50:11 GMT -6
I'm all for it if it keeps people paying for music.
HD vinyl
Apr 12, 2018 7:53:44 GMT -6
via mobile
Post by ericn on Apr 12, 2018 7:53:44 GMT -6
I'm all for it if it keeps people paying for music. Manager at Barnes and Noble 2 weeks ago “ I don’t get it why are people always steeling the vinyl” It was so ironic I did a spit take with my Frappacino 😳
Post by Deleted on Apr 12, 2018 9:28:34 GMT -6
My vinyl chain already sounds pretty HD to me...
Post by EmRR on Apr 12, 2018 9:48:42 GMT -6
30% more time should translate to faster wear. I'd avoid that urge until it's quantified.
Post by c0rtland on Apr 12, 2018 11:37:47 GMT -6
I'm not jumping. I don't even listen to my 2,000 deep collection enough as it is. My neighbor gave me a nitty gritty vinyl cleaning machine that works pretty darn well. That has spurned more listening than anything else. I love cleaning a record before listening. It takes 30 seconds and sounds significantly better without the dust.
Post by EmRR on Apr 14, 2018 8:03:30 GMT -6
Quoting Paul Gold of Salt Mastering:
HD vinyl
Apr 20, 2018 19:15:56 GMT -6
via mobile
Post by c0rtland on Apr 20, 2018 19:15:56 GMT -6
Post by johneppstein on Apr 24, 2018 13:59:36 GMT -6
Well, that IS Gizmodo and as such shouldn't be considered really authoritative, but if I understand what they're saying this is mainly a process for creating a ceramic stamper that won't wear and doesn't requiire the toxic electroplating process and all the "HD" malarky is primarily sales-speak, as is the talk about additional dynamic range and playing time because, as we know, those are limitations imposed by the physics of playback. Unanswered is the question of compatibility with conventional pressing machines. They're touting an end to manufacturing bottlenecks but that won't do a whole lot of good if the stampers won't work in existing plants.
Post by jimwilliams on Apr 25, 2018 12:12:04 GMT -6
The problem is vinyl. It's too soft and wears quickly. A new release sounds different on the second play. I used to give away records I did after one play because they never sounded as good the next time. Yes, it was played with good decks and carts.
I used to cut discs. They trained me well to find/locate the errors. That ruined my enjoyment of it because all I hear and focus on is the groove modulation, pops, crackles and inner groove distortions, etc. Plus the stereo crosstalk sucks next to my better DAC's.
Post by Bob Olhsson on Apr 25, 2018 12:41:45 GMT -6
This is basically B.S. It's probably cheaper than a lathe which is a financial advantage. The limitations are in the playback system and the best sound comes from tweaking the system for what sounds best with conventional playback of a test lacquer.
Post by johneppstein on Apr 25, 2018 14:04:15 GMT -6
This is basically B.S. It's probably cheaper than a lathe which is a financial advantage. The limitations are in the playback system and the best sound comes from tweaking the system for what sounds best with conventional playback of a test lacquer. I was thinking about that - with this system you'd need to do a new stamper for each test pressing. That doesn't seem economical unless that ceramic process is really cheap, which I somehow doubt very much.
