Post by kcatthedog on Mar 10, 2018 8:48:40 GMT -6
We had a confab last week about gain control in PT but you can do it in logic too:
Post by M57 on Mar 11, 2018 5:03:16 GMT -6
Yeah, I discovered (or found out about this) about a year or so ago, on a thread here if I'm not mistaken. My mic technique isn't too bad, but I still end up using it here and there on my vocal tracks. If I have to push things too much, like more than 4 or 5 db, it doesn't work for me because things like room reflections come into play, and at that point, I just find it's more musical to use compression and automation. Just like everything else, it's about using your ear, right?
Post by NoFilterChuck on Mar 11, 2018 7:34:12 GMT -6
Post by notneeson on Mar 11, 2018 9:20:56 GMT -6
Having the little fader right on each clip is really a sweet workflow. So much less automation/trim automation tail chasing now.
Post by bram on Mar 12, 2018 13:52:28 GMT -6
Chuck - you just changed my world. Didn't know about region automation. Thanks!
Post by kcatthedog on Mar 12, 2018 14:39:03 GMT -6
It is like clip gain in that you have the capacity to increase the gain is specific sections or tracks in your song as opposed to volume automation.
I do a lot of working on parts, section by section. Sometimes I realize afterwards that my relative levels are too different so I can use this function in logic like clip gain as I used to do the same in protools.
Post by mrholmes on Mar 13, 2018 13:56:13 GMT -6
Or someone uses the old sample editor?
Post by kcatthedog on Mar 13, 2018 14:06:14 GMT -6
interesting !
Post by terryrocks on Mar 14, 2018 10:53:37 GMT -6
I use it more often than volume automation. Quick and easy way to get levels right where they need to be
Post by the other mark williams on Apr 14, 2018 23:40:27 GMT -6
I use it more often than volume automation. Quick and easy way to get levels right where they need to be That, and it's pre-insert. So if you do it first, you've got a more consistent level for compressor plugs...
Post by levon on Apr 15, 2018 2:59:01 GMT -6
Or someone uses the old sample editor? Yes, I've used that for years...
Post by saltyjames on Oct 28, 2019 23:16:42 GMT -6
Thank You!
Post by sirthought on Oct 29, 2019 2:17:31 GMT -6
So what if the region is split up for the change??? It's one keystroke away from joining the larger region again once you get in the gain range you like.
Post by kcatthedog on Oct 29, 2019 3:19:10 GMT -6
I use the join command: what’s the one keystroke ?
Post by wiz on Oct 29, 2019 18:07:30 GMT -6
I use the join command: what’s the one keystroke ? "J"
Post by kcatthedog on Oct 29, 2019 20:04:58 GMT -6
Way too complicated !
