Post by matt@IAA on Feb 9, 2018 9:34:52 GMT -6
I would think that each channel should be set at the same spot for unity gain...?
Post by kcatthedog on Feb 9, 2018 10:22:52 GMT -6
My modules are like 4 different versions: I have 3 original, and 3 sets of slightly different mods, so there is some natural variation or maybe it is teh gain rotary themselves, but when I compare output signal to input signal on the symph metres there are differences
so I thought might as well get as close to unity as I can ?
Post by drbill on Feb 9, 2018 14:11:21 GMT -6
"so I thought might as well get as close to unity as I can ?" Yes. Doesn't matter if they are modded or you're using another console in addition or a 500 EQ. All should pass unity when "flat". That way you can switch between modules / consoles / outboard and it will come back in at the same volume - allowing you to judge any differences.
Post by kcatthedog on Feb 9, 2018 15:00:42 GMT -6
Well at least I have learned one thing !!
Post by wiz on Feb 9, 2018 15:11:10 GMT -6
Wiz’s method above achieves unity gain. I just need to mark each knob or decide to only use the delta for mixing (ob pres for pres) and set and forget gain x channel ? It only takes a few seconds to reset if you have moved the gain knob. Just whack the test oscillator plug in before the io plugin on the channel. cheers Wiz
