Post by Tbone81 on Jan 20, 2018 13:17:56 GMT -6
So I'm recording a two piece ensemble in a few weeks, acoustic guitar and cello. They'll both be playing live in the same room and the guitar player will be singing too. I've never recorded a cello and I'm searching for insight on the best mic/technique for this situation. I'm planning on using the following: Acoustic - DI Acoustic - SDC Vocals - Stager sr2n ribbon Room Mics - miktek c7 and c5 in M/S Cello - I'll have them positioned so that the cello player is in the null of the singers ribbon mic. And was thinking of using my miktek CV-4 in figure 8 on the cello, also utilizing the null to minimize bleed. Any thoughts? Should I use a dynamic like a re20, 421, m201etc? should I stick with a figure 8 condenser? Ideas for mic placement on the cello? Any and all help is appreciated.
Post by notneeson on Jan 20, 2018 13:42:06 GMT -6
Generally with the cello I would say, don't get in too close— I generally like both ribbons and condensers at least 1.5' off the bridge and soundboard. Your room mics should fill out the cello nicely, it's an instrument that really wants to be heard in a space. So keep that in mind with placement.
Post by Tbone81 on Jan 20, 2018 13:46:37 GMT -6
Generally with the cello I would say, don't get in too close— I generally like both ribbons and condensers at least 1.5' off the bridge and soundboard. Your room mics should fill out the cello nicely, it's an instrument that really wants to be heard in a space. So keep that in mind with placement. Thanks, I heard the cello play last night at a rehearsal and was thinking placing a mic somewhere about 2ft away, bridge level, but off center, pointed between bridge and soundboard. I noticed listening straight on at the bridge that bass notes were a little boomy and not as smooth. Any sweet spots you know of on cello to try out? Would it be worth it to try an Mono OH type configuration with a close mic?
Post by notneeson on Jan 20, 2018 13:53:36 GMT -6
Generally with the cello I would say, don't get in too close— I generally like both ribbons and condensers at least 1.5' off the bridge and soundboard. Your room mics should fill out the cello nicely, it's an instrument that really wants to be heard in a space. So keep that in mind with placement. Thanks, I heard the cello play last night at a rehearsal and was thinking placing a mic somewhere about 2ft away, bridge level, but off center, pointed between bridge and soundboard. I noticed listening straight on at the bridge that bass notes were a little boomy and not as smooth. Any sweet spots you know of on cello to try out? Would it be worth it to try an Mono OH type configuration with a close mic? Yeah that's normal for the cello, it's frequency response is varied directionally, so the further back the more balanced the resulting capture. I usually wind up a few feet back and a tad off center from the bridge. Naturally everything will affect everything else in your live-off-the-floor scenario. I'd be tempted to use something like a SM7B on vocal to min. bleed there. Off course, good sounding bleed is not necessarily a problem at manageable levels.
Post by drbill on Jan 20, 2018 14:16:10 GMT -6
U87 is excellent and usually my first call for solo cello. I wouldn't worry about bleed in regards to the cello. The vocal might be a different story depending on how you get it to sound live, but I'd say let them balance between themselves, and the bleed will be your friend. notneeson's comments about cello mic placement, etc. are good. Not too close is your best bet. Some gentle opto compression (LA2a) on the cello could be excellent if he/she plays expressively.
Post by Tbone81 on Jan 20, 2018 14:53:14 GMT -6
U87 is excellent and usually my first call for solo cello. I wouldn't worry about bleed in regards to the cello. The vocal might be a different story depending on how you get it to sound live, but I'd say let them balance between themselves, and the bleed will be your friend. notneeson's comments about cello mic placement, etc. are good. Not too close is your best bet. Some gentle opto compression (LA2a) on the cello could be excellent if he/she plays expressively. Thanks, yeah I'm trying to use the bleed in a controlled fashion, not fight it per se. The singer is pretty loud and dynamic, he projects very strongly. I'm a little worried about him overpowering things but I think the vocals will be manageable. I'm definitely going for an organic vibe. Maybe I'll put a LDC in Omni between them and start with just getting a great balance in that one mic. Then move on from there...
Post by jeromemason on Jan 20, 2018 15:16:30 GMT -6
I've never been a fan of condensers on stringed orchestral instruments, picking up all that bow scratch is unpleasant for me. A really good ribbon, like an R-121, R-101 or if you want to really get the space and detail captured the SF-24V from Royer is the best I've ever heard. It is a tube based amp with stereo ribbon transducers. Those mics, for spot mic'g, which is what it sound's like you're asking about, truly sound magical.
The best way to set let's say the SF-24V up would be to get yourself a friend in the room, start with the mic above the instrument/player on an axis pointed at the instrument/player. Then as they're playing have the assistant move the mic (same axis) down and back up slowly, maybe have them do this for a little bit until you keep hearing a point in which it sounds as if you're standing in front of the player and tell them to lock it down. Then I would listen for any bow scratch etc. if there is none you're good to go, if there is some then they can slowly adjust the axis both horizontal and vertical, but keep it locked at the height you liked.
Thats how I was taught and it's always worked for me. But, stereo ribbons IMO are best for this type of instrument. The tube version, the SF-24V has so much detail and smoothness it will really blow you away.
Post by EmRR on Jan 20, 2018 15:44:45 GMT -6
So.....what's the DI for?
I usually like a ribbon 18-24" out, but it all depends on the touch.
Post by notneeson on Jan 20, 2018 15:50:20 GMT -6
So.....what's the DI for? I usually like a ribbon 18-24" out, but it all depends on the touch. Piezo DIs are for when you want the listener to feel like their at a free outdoor concert.
Post by Tbone81 on Jan 20, 2018 16:10:01 GMT -6
So.....what's the DI for? I usually like a ribbon 18-24" out, but it all depends on the touch. The DI is there because why not? It takes zero effort and I might be able to use it for something come mix times. (Didn't mean that to sound snarky)
Post by reddirt on Jan 20, 2018 17:42:19 GMT -6
The DI decision is not worth worrying over, as you say; it's easy to do so why not. There are times in a multi mic situation like that where i've actually used the DI (or wished I had one) simply because the perceived wisdom of the mic 'must be better" in fact wasn't - because the player moved or the mic wasn't as good a fit as I thought etc.- the biggest issue to tame on the cello and acoustic as others have alluded to is that potentially uneven bottom end. It can never truly be eq'd after the event IME so mic choice and placement are critical and will come beck to bite you on the backside if you cut corners.
Nulls are good and a well placed 87 style (I use the Stam 87) on the Cello keeping that bow scratch in mind works well. With a cardioid small diaphragm on the acoustic you may find the distance you need it away from the body means it will pick up too much of the bleed, again a fig 8 may or may not be best in the circumstance.
There are no hard and fast rules for getting this right except have options ready to go and experiment as much as the players energy will allow.
Cheers, Ross
Post by reddirt on Jan 20, 2018 17:50:32 GMT -6
Oops, didn't read your original post properly and I now see the guitar player is singing as well so a fig 8 on the guitar is almost mandatory as well as on his vocal. Have them sitting adjacent with a gap between (i.e. not facing each other) to utilise all the nulls and watch out for the ribbon's vocal 'plosives.
Cheers, Ross
Post by Bob Olhsson on Jan 20, 2018 17:52:04 GMT -6
Anything that's good for an acoustic guitar will probably be good for cello. Like all bowed instruments you don't want to be too close. I used a KM-86 about five feet out looking down.
Post by Deleted on Jan 20, 2018 19:53:05 GMT -6
Anything that's good for an acoustic guitar will probably be good for cello. Like all bowed instruments you don't want to be too close. I used a KM-86 about five feet out looking down. A KM-86. My goodness Bob, you sent me off on a web search to look that one up--I'd never heard of it. It's described as a pair of KM84 capsules back-to-back. I'll bet you won't find too many of those lying around. I thought the Figure-8 frequency response was really interesting and almost the opposite of what you'd find in many ribbons. Low frequency response started to fall off below 100Hz and a nice wide boost of about 3dB from 2K on up to 15K or so. Very unusual. I like your use of it. Looking down would let you get sound off the entire top plate of the cello and would give you a much more accurate representation of the overall frequency output of the instrument. Depending on the singer and the nature of the music, you might actually benefit from a 'scratchy' spot mic out front to give a little more articulation if you needed it.
Post by Bob Olhsson on Jan 20, 2018 20:04:10 GMT -6
At Motown we had 20 to 30 in each studio. The only other studios I know of having that many were RCA Victor and EMI London. U87s were about the same price and looked more impressive so the indi studios went that route. I understand Abbey Road still uses them for strings in Studio one.
I was taught that placement by my mentor Cal Harris who began his career at United/Western and also worked as a first engineer at Gold Star before he came to Motown.
Post by Tbone81 on Jan 20, 2018 20:26:12 GMT -6
At Motown we had 20 to 30 in each studio. The only other studios I know of having that many were RCA Victor and EMI London. U87s were about the same price and looked more impressive so the indi studios went that route. I understand Abbey Road still uses them for strings in Studio one. I was taught that placement by my mentor Cal Harris who began his career at United/Western and also worked as a first engineer at Gold Star before he came to Motown. This is the reason I'm in RGO, to read things like that! Much thanks bob. My mic locker is fairly modest but you've all given me some great info to digest.
Post by jazznoise on Jan 20, 2018 21:06:41 GMT -6
For something reasonably dry/close I'd opt for a bright LDC (usually my Oktava MK220) in Omni about 2-3 feet back, placed closed to the point where the neck of the instrument joins the body. If bleed is an issue use it in figure 8 and point the nulls at the other musician, but be aware that strong proximity effect can make a cello or double bass feel uneven from note to note. You'll notice people tending towards more directional mics will take a top-down approach to avoid interference from the F holes.
Post by Vincent R. on Jan 20, 2018 21:31:07 GMT -6
U87 is excellent and usually my first call for solo cello. I wouldn't worry about bleed in regards to the cello. The vocal might be a different story depending on how you get it to sound live, but I'd say let them balance between themselves, and the bleed will be your friend. notneeson's comments about cello mic placement, etc. are good. Not too close is your best bet. Some gentle opto compression (LA2a) on the cello could be excellent if he/she plays expressively. I’ll second the U87 on cello. I used a KSM44 once and had great results too. 1.5-2ft away. I also tried a Peluso 2247se once and the cello ended up sounding huge, which could be good or bad.
Post by Martin John Butler on Jan 20, 2018 22:06:53 GMT -6
It depends on where the focus is. I like SDC's on acoustic instruments in busy mixes, my favorites are the KM-84 and the Soyuz 0-13, which I actually prefer over the 84, which I love. For the big and full sound on acoustic, like a Bluegrass player might want or a solo acoustic/vocal, I like LDC's. So far the two best I've used were the Soyuz 0-19 FET, ( so the U87 would be similar), and the new Chandler REDD, which was the finest sound I've ever heard on acoustic.
Bob and drill know their stuff, so I'd take their recommendations over mine, but if you don't have as many choices as you'd like, a U87 will do nicely.
Post by nnajar on Jan 20, 2018 22:26:41 GMT -6
Many mics will sound good on cello. It has more to do with how everything sounds together in that room. I’ve used schoeps. U87, Coles 4038, aea r84, lots of different things and they’ve all sounded fine. Don’t get too close.....
Post by Ward on Jan 20, 2018 23:01:02 GMT -6
If you want sweetness like a great recording of Vivaldi's Four Seasons, I would consider a good old RCA 44
Post by svart on Jan 20, 2018 23:47:11 GMT -6
I've done a few cellos. Ldc back a couple feet, about halfway up the fingerboard, pointing down slightly towards the bow.
Post by EmRR on Jan 21, 2018 10:02:24 GMT -6
So.....what's the DI for? I usually like a ribbon 18-24" out, but it all depends on the touch. The DI is there because why not? It takes zero effort and I might be able to use it for something come mix times. (Didn't mean that to sound snarky) I don't mean it to sound snarky either. I've just never found any use for the sound of an acoustic DI. If anything, I can see it being a distraction, either the loss of focus that can come from thinking of it as a backup of some sort, or any time spent messing with it later. If I were printing that, I'd not monitor it at all, and I'd tuck it away somewhere that I'd not notice it in the DAW layout. Then it'd be a track for me to find and purge later. If it were a club gig, it might be useful, but I can't see it with a session like you describe. I'd put up 3 more mic options in parallel before I'd ever patch a DI. God luck with the cello!
Post by iamasound on Jan 21, 2018 18:18:37 GMT -6
I remember seeing this a while ago, and though I as yet haven't had the chance to figure this instrument in on a session, thought that this graphic makes lots of sense for when choosing the best microphone in conjunction with optimum placement to fill in the creative space in the sonic spectrum of my sonic rainbow of a mind.
Post by jazznoise on Jan 21, 2018 19:00:05 GMT -6
I have the textbook that comes from originally, it's a german book that describes the dispersion pattern of most Orchestral instruments (including voice) and then the acoustics and the acoustic variability of performances spaces. Really good resource.
+1 on not going for the DI. Ever. They just don't sound good, at best they're for running into FX for when you're doing weirder stuff.
Did another session today with cello, did a Fig 8 about 3 feet above pointing down and it worked well enough. Bass response is lumpier than you'd get from an omni, but the sound was the most appropriate for the type sound we were going with.
