Post by Guitar on Oct 11, 2018 17:45:51 GMT -6
I think it would be a nice touch on your $1790 model if you could put a few zip ties around the vintage tube. You know, so people know what they are paying for.
Post by stam on Oct 11, 2018 17:49:09 GMT -6
By the way New prices on the 67 from today PRE-ORDER PRICE: $1390.00 (TUNG-SOL EF-806-S) - The best sounding currently made EF86 tube $1590.00 (NOS PHILIPS EF-86) - This is the best sounding NOS tube without breaking the bank $1790.00 (NOS TELEFUNKEN EF-806 TUBE, original U67 tube) - This is the original tube used by Neumann, we only have 50 pieces of them STOCK PRICE: $1590.00 (TUNG-SOL EF-806-S) $1790.00 (NOS PHILIPS EF-86) $1990.00 (NOS TELEFUNKEN EF-806 TUBE, original U67 tube) All units come with the AMI BV12 output transformer (with a zip tie!) Each mic with NOS tubes is burned for 72 hours to ensure proper functionality. We offer a 1 year warranty on the tube as well Josh Hey Josh I know you're having a hard time, I can sell you some zip ties for $12 each. They are not the same size and color. But I think in these times you will find that I have the best deal in zip ties going. What do you mean with a hard time?
Post by stam on Oct 11, 2018 17:49:59 GMT -6
I think it would be a nice touch on your $1790 model if you could put a few zip ties around the vintage tube. You know, so people know what they are paying for. That is something many manufacturers do as well I will indeed if I feel it secures it even better but I can't promise anything yet
Post by EmRR on Oct 11, 2018 18:47:06 GMT -6
I guess y’all forgot to request hot glue instead, which is definitely an industry standard. I have used dry expoy glue on transformers as well successfully in the past, it makes it extremely hard to remove them if they fail though! Very true. It seems people really have forgotten hot glue as an industry standard. IT REALLY IS! It’s holding all sorts of things together inside lots of commercial electronics. I approve of the zip tie! Nothing wrong with it.
Post by Mister Chase on Oct 11, 2018 19:23:36 GMT -6
Ya know, when I first saw the zip, I didn't really thank much. Then I did real-eyes, I don't have a mic nor have I seen one with a zip on the tranny before. I mean, as a guy who been workin' in manufact-urine for a while, I prefer a nice stainless steel screw(phrasing). Countersunk at 82 degree, with some threadlock if need be. That would certainly be stronger, and that's a fact, JACK(sips sweet tea).
But that don't mean a zip ain't ade-quate. I done some zip rigs that are crazy tight if you do a cross pattern.
Then I remembered - my blackout van-plan. Iffin' I ever had to 'nap somebody's for reason of zombie apocolypse and related doins, you know what I'd do? Zip tie em.
Nuff said. Carry on ya'll.
Post by stam on Oct 11, 2018 19:57:02 GMT -6
I am actually proud of it, we even posted a picture of it a few days ago on our Facebook to showcase our hand made products.
I will continue to use it for sure, super safe way to strap those expensive transformers.
Post by jtc111 on Oct 11, 2018 20:09:57 GMT -6
Ya know, when I first saw the zip, I didn't really thank much. Then I did real-eyes, I don't have a mic nor have I seen one with a zip on the tranny before. That's really the point despite the strawmen that are getting set up and mowed down. If I open up a piece of rack gear and find zip ties holding some wires in a bunch to keep things neat, I don't think anything of it. So if someone wants to say that zip ties are the "industry standard" for keeping wires neat inside a gear box, they'll get no argument from me. But this isn't about any other piece of gear except microphones. To call zip ties the "industry standard" for holding transformers in place inside a microphone, we'd have to see it as a common practice employed by at least some of the major players, and that just isn't the case. It's not about whether the zip tie works in this situation. Enough knowledgeable people have weighed and said it will be fine, so that's not the issue. The issue is about the "industry standard" claim which apparently cannot be backed up. I do accept and understand that the phrase "industry standard" is ambiguous and will mean different things to different people. To some it may mean a majority employ this method inside microphones, to other it may mean just a plurality employ the method, and to others it may be as simple as a significant percentage of companies employing the method but falling short of a majority or plurality. I'm certain the use of zip ties in microphones don't meet either the majority or plurality mark. And at this point, since no one has been able to provide a significant list of microphone manufacturers who routinely employ the practice of using zip ties inside mic bodies, I'm doubtful that even the lowest bar can be hurdled. And if that lowest bar cannot be reached, I don't see how anyone can claim that the use of zip ties inside microphones is an "industry standard" when it's done in so few microphones. So if it's short of "industry standard," what is it? I think the term "acceptable practice" gives a truer sense of this method and I don't think that language detracts from the product one iota. I also understand that hyperbole and sales go hand in hand, so the stretching of the truth isn't all that surprising; however, it doesn't make it any more palatable when it happens. Hyperbole is certainly a sales "industry standard," and Josh isn't alone in that. He just happens to be within easy reach right now.
Post by kcatthedog on Oct 11, 2018 23:21:48 GMT -6
and does any of this really matter in terms of the transformer being held securely in place?
Unless, it just wasn’t done properly,everything will be fine. Even if the transformer worked loose from rough handling, it could easily be secured.
I think both of my expensive diy mike kits (c12 and mk-u47), used ties for the transformer or at least one, as I remember cinching it down, zero problems.
Is anybody aware of anyone indicating their sa-67 transformer has worked loose in travel or early use: I doubt it, as cinching a tie securely is very hard to get wrong?
Post by timcampbell on Oct 12, 2018 0:25:34 GMT -6
Wow, that's a lot of discussion about a zip tie. I wouldn't get too hung up on Josh's use of "industry standard". Please remember that english isn't Josh's first language (though he is excellent at english speaking and writing)and so the phrase industry standard may seem interchangeable with acceptable practice as used by others. Is this a great mic at a great price? I think so. Will anyone hear the zip tie in my recordings? I don't think so .
Post by kcatthedog on Oct 12, 2018 6:37:48 GMT -6
If compressors glue my mix, do ties, tie things together ?
Post by EmRR on Oct 12, 2018 6:49:58 GMT -6
With all the hot glue in electronics, no one should need compression at all.
Post by Ward on Oct 12, 2018 7:07:07 GMT -6
I am actually proud of it, we even posted a picture of it a few days ago on our Facebook to showcase our hand made products. I will continue to use it for sure, super safe way to strap those expensive transformers. There's nothing wrong with this practice. I don't see why this is even a debate!! it's ingenious and if it were available in 1955, Neumann would have done it that way too!
Post by jtc111 on Oct 12, 2018 7:59:02 GMT -6
it's ingenious and if it were available in 1955, Neumann would have done it that way too! It's available now. Is Neumann doing it? And again, my issue is not that there's a zip tie in that mic. My issue is with it being called the "industry standard" when no one can seem to find a manufacturer who employs this method.
Post by stam on Oct 12, 2018 8:10:11 GMT -6
Tim could have not said it better, I was actually about to post the same My bad for not speaking perfect English. You are definitely a smart guy Tim
Post by kcatthedog on Oct 12, 2018 8:13:42 GMT -6
You know Tim, he is all about setting new standards, but my c12 cap smells like smoked herring ?
Post by timcampbell on Oct 12, 2018 9:50:02 GMT -6
kcatthedog that's pickled herring with schnapps
Post by jtc111 on Oct 12, 2018 9:57:09 GMT -6
My bad for not speaking perfect English. You are definitely a smart guy Tim You doubled down on the claim when it was it was further explained so this doesn't seem like an English issue. You engaged in a bit of hyperbole and rather than simply admit it, you're digging your heels in.
Post by Martin John Butler on Oct 12, 2018 10:10:28 GMT -6
OK, no need to keep pushing this into the ground, let's just "zip" ahead now.. I'd love to hear some more tracks with the SA67 with a male vocalist. When it arrives, I'll post lots of things with it.
Post by Guitar on Oct 12, 2018 10:17:45 GMT -6
yeah zip your mouth shut! let's hear some zippy up tempo recordings! sit back, relax, have a zip of whine
Post by kcatthedog on Oct 12, 2018 11:11:31 GMT -6
kcatthedog that's pickled herring with schnapps Finally, revealed, the TC secret glue ingredients holding your capsules in place!
Post by timcampbell on Oct 12, 2018 11:20:36 GMT -6
The cat's out of the bag!
Post by stam on Oct 12, 2018 11:23:45 GMT -6
My bad for not speaking perfect English. You are definitely a smart guy Tim You doubled down on the claim when it was it was further explained so this doesn't seem like an English issue. You engaged in a bit of hyperbole and rather than simply admit it, you're digging your heels in. I don't even know what double down means... That should enlighten you a little! We both have better things to do with our time buddy, have a great weekend
Post by Mister Chase on Oct 12, 2018 11:51:27 GMT -6
You doubled down on the claim when it was it was further explained so this doesn't seem like an English issue. You engaged in a bit of hyperbole and rather than simply admit it, you're digging your heels in. I don't even know what double down means... That should enlighten you a little! We both have better things to do with our time buddy, have a great weekend Double down means you have two girlfriends and you are trying your best to keep them from knowing the other exists. At least that's what I think it means.
Post by stam on Oct 12, 2018 11:53:25 GMT -6
I don't even know what double down means... That should enlighten you a little! We both have better things to do with our time buddy, have a great weekend Double down means you have two girlfriends and you are trying your best to keep them from knowing the other exists. At least that's what I think it means. Sounds more stressful than building microphones!
Post by mikec on Oct 12, 2018 12:49:08 GMT -6
Double down means you have two girlfriends and you are trying your best to keep them from knowing the other exists. At least that's what I think it means. Sounds more stressful than building microphones! And way more expensive than buying microphones.
