Post by jcoutu1 on Dec 6, 2017 13:30:53 GMT -6
Post by Deleted on Dec 6, 2017 14:25:06 GMT -6
They look great! Did you follow plans or just build by eye? (And can you link if the former?) Love the stain, too. Steel wool/vinegar or a product?
Post by ericn on Dec 6, 2017 15:19:22 GMT -6
Looking good Jesse!
Post by svart on Dec 6, 2017 15:47:49 GMT -6
Those are almost identical to how I built mine!
Good job!
Post by jcoutu1 on Dec 6, 2017 15:54:40 GMT -6
They look great! Did you follow plans or just build by eye? (And can you link if the former?) Love the stain, too. Steel wool/vinegar or a product? Thanks. I slapped together a basic plan in Google Sketchup, but veered off course a bit while building to accommodate for some issues. Basically, I got some sheets of 4x8, 3/4" plywood. Chopped the 8 foot length into 4 x 2' x 23" rectangles. I used 1x3's for the kickplate, so those are 2.5" each and you can see how they are arranged in the pics. We drew a line from the top of the kick plate to 8" back on the top of the box to get the break angle for the slant. I used 1x2 and 1x3's glued and screwed (nail gun on the smaller boxes) as bracing for the boxes and screwed a plywood top and bottom on to match the size. The spacing between the rack rails is 19 3/8" (and that's convenient because there is a triangle on the measuring tape where you need to measure). This is the product that I used to stain/poly. I only put one coat. I'm in a time crunch to get up and running in the new space, so I found the easiest, quickest solution for the finish, but think the results came out pretty well. www.homedepot.com/p/Varathane-1-qt-Ebony-Stain-and-Polyurethane-271464/203946698I'm NOT a carpenter by any means, and I'm surprised by how well the build went. The big rack is 22U x 3, but I should have done 24U. I ordered some 2U rails to add to the bottom. The shorter ones are 14U, but probably should have done 12U for a better height.
Post by Deleted on Dec 6, 2017 18:26:01 GMT -6
They look great! Did you follow plans or just build by eye? (And can you link if the former?) Love the stain, too. Steel wool/vinegar or a product? I'm NOT a carpenter by any means, and I'm surprised by how well the build went. Thanks for the info. Need a stain to match an existing desk and that may be perfect. Forgot to mention space looks great, overall. I'd be happy to work in there!
Post by kcatthedog on Dec 7, 2017 5:45:26 GMT -6
Sweet: classic black, like the height and placement of your patchbay: good thinking !
Post by mikec on Dec 7, 2017 10:27:13 GMT -6
Sure wish I had the skills to build these. I could use at least one more standing rack.
Post by ericn on Dec 7, 2017 22:06:36 GMT -6
Sure wish I had the skills to build these. I could use at least one more standing rack. A rack straight rack is pretty easy, a simple Kreg Pocket screw jig ($30) and Homedepot and Lowes will cut to length, Penn Elcom rails and your done!
Post by mikec on Dec 8, 2017 7:36:53 GMT -6
Sure wish I had the skills to build these. I could use at least one more standing rack. A rack straight rack is pretty easy, a simple Kreg Pocket screw jig ($30) and Homedepot and Lowes will cut to length, Penn Elcom rails and your done! Okay, I admit it, I had to google what a Kreg Pocket screw jig is, and my dad was a shop teacher for over 30 years. I think he was a little embarrassed when I took his class many, many years ago.
Post by ericn on Dec 8, 2017 7:44:42 GMT -6
A rack straight rack is pretty easy, a simple Kreg Pocket screw jig ($30) and Homedepot and Lowes will cut to length, Penn Elcom rails and your done! Okay, I admit it, I had to google what a Kreg Pocket screw jig is, and my dad was a shop teacher for over 30 years. I think he was a little embarrassed when I took his class many, many years ago. Hey I think it was either My neighbor Brian who builds highend speaker cabinets or my old Neigboor Dana who showed me 8-10 years ago, I have been building cabinets for 39 of my 49 years ! Coolest little tool ever, hardly use my biscuit joiner anymore & I give at least one a year as an Xmas present to somebody who looks at like, gee thanks, right. A year later I always hear " best gift ever"!
Post by svart on Dec 8, 2017 7:59:00 GMT -6
There's an IKEA cabinet that a lot of folks use for racks because it's 19" wide on the inside.
Post by ericn on Dec 8, 2017 8:18:00 GMT -6
There's an IKEA cabinet that a lot of folks use for racks because it's 19" wide on the inside. Yeah but no clearance if somebody's front panel is a little wide!
Post by matt@IAA on Dec 8, 2017 8:18:08 GMT -6
Post by keymod on Dec 8, 2017 17:20:19 GMT -6
Nice job, Jesse. Space is looking great
