Post by drew571 on Nov 28, 2017 15:38:52 GMT -6
I was recently at a conference where the AE forgot to change his music feed to records from pre-fader to post-fader, had the music playing in the entire time, and recorded the music over the presentation spoken word audio for several days.
Anything that can be done about this? iZotope RX plugin maybe?
If the music that was recorded was matched with the music files in a DAW and the phase was flipped, would that work? I'm assuming it would have to be at an identical location and the volume would have to be matched. And what a tedious pain in the ass that would be. But is it possible. We're talking about a multi-million dollar client here.
Would a professional audio cleanup house be able to do this?
Thanks!
Post by EmRR on Nov 28, 2017 19:10:23 GMT -6
mono elements? stereo elements? so much you can do with mid-side processing and phase flipping if it's the right balance of elements.
Post by drew571 on Nov 28, 2017 19:32:55 GMT -6
Stereo file but nothing was panned so it's really just dual mono.
Post by bluegrassdan on Nov 29, 2017 13:23:09 GMT -6
I'm guessing the best results would be the method you described. Match the music and flip phase. Still might require addiontional cleaning.
Post by EmRR on Nov 29, 2017 14:22:30 GMT -6
I haven't tried it, but izotope would probably let you pull a lot out given the probable bandpassed nature of the voice. And that's probably only after doing your best with a polarity reversed file. But a couple of days, wow. You need a forensics or film dialog expert. All depends on the 'recovery budget' too.
