Post by klauth on Nov 19, 2017 22:24:05 GMT -6
Been reworking my patchbays and was curious as to how many TT bays your using in your studio?
Post by c0rtland on Nov 19, 2017 22:57:00 GMT -6
im using 4. pretty much 1 per rack. i have everything wired through it. if it's not plugged into the patchbay it is not easy to use. so i plug EVERYTHING into a patch point
Post by ericn on Nov 19, 2017 22:57:58 GMT -6
14 every jack to the bay!
Post by drbill on Nov 19, 2017 23:54:39 GMT -6
6 in my hybrid studio, 10 for my console setup.
Post by subspace on Nov 20, 2017 8:13:05 GMT -6
None. Seven PO316 B-gauge bays in use plus a spare for expansion.
Post by swurveman on Nov 20, 2017 8:37:11 GMT -6
Two.
Post by ericn on Nov 20, 2017 9:04:16 GMT -6
Been reworking my patchbays and was curious as to how many TT bays your using in your studio? Honestly there are never enough you always have to think about expansion!
Post by NoFilterChuck on Nov 20, 2017 15:20:56 GMT -6
related question. What's your power bill each month lol
Post by mulmany on Nov 20, 2017 15:31:56 GMT -6
3 - but it should have been 4. I split the bays into 32ch/16ch banks.
24 mic in 32 ch mic pre I/o 32 ch ad/da I/o 48 ch outboard/insert i/o
Post by mulmany on Nov 20, 2017 15:38:14 GMT -6
14 every jack to the bay! That's a lot of Bay!
Post by svart on Nov 20, 2017 15:48:54 GMT -6
2x TT patchbays, one with 96points, one with 192 points. The 96 point one covers 24 lines from the soundproof room normalled to the console preamps, 24 lines to external preamps, 24 from the external preamps, 24 lines to the line-ins on the console.
The 192 patchbay covers all the inserts from/to the console with the send/return broken out to separate connectors (so 48 dedicated just to console inserts), the rest are to/from external gear with the I/O broken out to separate connectors. I think I only use about half of this one right now.
I'm thinking of adding another one for the effects sends/returns to make it easier to patch them.
Post by svart on Nov 21, 2017 16:43:40 GMT -6
I thought about it and went ahead and bought another 96 TT patchbay for the effect sends/returns. They've gotten pretty cheap on ebay, 50$ shipped.
Post by NoFilterChuck on Nov 21, 2017 19:58:23 GMT -6
I thought about it and went ahead and bought another 96 TT patchbay for the effect sends/returns. They've gotten pretty cheap on ebay, 50$ shipped. is that with dsubs on the back or some other format?
Post by Quint on Nov 21, 2017 20:20:58 GMT -6
Four 96 pointers here.
Post by svart on Nov 21, 2017 20:35:36 GMT -6
I thought about it and went ahead and bought another 96 TT patchbay for the effect sends/returns. They've gotten pretty cheap on ebay, 50$ shipped. is that with dsubs on the back or some other format? I think it's dsub, but I'm going to rip that off and solder it.
Post by Ward on Nov 21, 2017 20:51:30 GMT -6
Eight 96 pointers. Most of them are Swtchcraft 9625
Post by drumhead57 on Nov 22, 2017 2:21:18 GMT -6
2 - one Switchcraft 96, one Redco 96, both dsub. I think I need one more though.
Post by Ward on Nov 22, 2017 6:40:46 GMT -6
2 - one Switchcraft 96, one Redco 96, both dsub. I think I need one more though. There's always that unexpected need!!
Post by ericn on Nov 22, 2017 8:27:31 GMT -6
2 - one Switchcraft 96, one Redco 96, both dsub. I think I need one more though. There's always that unexpected need!! Yup! One of the best investments you can make is a bay or 2 or 3, wired to provide, polarity flip, pads, mults, Transformer splits, isolation Transformers. Plus have all your adaptor cables setup so you adapt to what's in the bays. You then simply use a mult as the adapter, less clutter and speeds things up ! Having every audio jack wired to the bays sure saves time when somebody shows up with something new to play with!
Post by klauth on Nov 22, 2017 20:01:51 GMT -6
How are the switchcraft 9625’s are they a robust build quality, because they seem kinda fid’ly with those switchable normaling screws, maybe it’s just the way they look in the pics?
Post by ericn on Nov 22, 2017 22:30:42 GMT -6
How are the switchcraft 9625’s are they a robust build quality, because they seem kinda fid’ly with those switchable normaling screws, maybe it’s just the way they look in the pics? If my memory is correct the screw is a rotary switch that can't be easily bumped, high quality, not cheap in any way and hard to beat at the price!
Post by drumhead57 on Nov 23, 2017 3:24:46 GMT -6
I agree that the Switchcraft 9625 is very high quality, and the rotary normaling switches are sturdy and easily adjusted with a small flat head screwdriver. Not fid'ly at all. The Redco bay is also high quality, but if I want to change the normaling, I have to pull it out of the rack, as the sliders are on top of the unit.
Post by svart on Nov 29, 2017 12:31:42 GMT -6
So I spent a few hours over a couple nights this week stripping the old connections and then hooking up some snakes and cables to the patchbay I'm going to use for my effects sends/returns.
Post by tasteliketape on Nov 29, 2017 19:01:04 GMT -6
Post by Quint on Nov 29, 2017 19:27:27 GMT -6
There must be a shit ton of relays inside that thing. I'd like to see the internal routing on that thing. I also don't imagine this will be cheap. But it's a cool idea. I wish I could afford six of them.
