Post by c0rtland on Nov 17, 2017 15:28:14 GMT -6
Post by svart on Nov 17, 2017 15:43:13 GMT -6
Looks like a linear-pass or zener follower regulator. I would think it should work fine. Here's a pic of what gefell did, which just by looking at the little board components, looks like it should be similar..
Post by c0rtland on Nov 17, 2017 16:00:36 GMT -6
Gefell has done this?
I wonder if there would be a compromise in performance. lower headroom, less extension.
Maybe I'll get one and compare. If it sounds good I plan on doing all 4.
Post by Ward on Nov 18, 2017 7:57:57 GMT -6
This can't possibly end well...
Post by c0rtland on Nov 18, 2017 12:33:04 GMT -6
Yeah, I think i'm too skeptical.
Post by EmRR on Nov 18, 2017 17:37:55 GMT -6
Not seeing how this works for M582. Though, they appear to ask for 120VDC @ 0.9mA which might be possible with some sort of DC converter, but there's no way to cover filament supply. Should be fine for the SS types.
Post by svart on Nov 18, 2017 19:20:06 GMT -6
This mod is specifically to add phantom capability to their solid state mics.
Post by c0rtland on Nov 18, 2017 19:32:09 GMT -6
This mod is specifically to add phantom capability to their solid state mics. That makes sense. Except he lists m582 as a compatible mic. A bit misleading then.
Post by svart on Nov 18, 2017 21:02:52 GMT -6
This mod is specifically to add phantom capability to their solid state mics. That makes sense. Except he lists m582 as a compatible mic. A bit misleading then. Probably just a mistake. Someone probably cut and pasted all the SDC mic models from that era into the title not realizing that one (or more) were tube mics.
