Post by Johnkenn on Nov 16, 2017 17:28:41 GMT -6
Anyone here doing this? There are tutorials for Logic...but the Apogee techs were worthless about Cubase? drsax?
Post by NoFilterChuck on Nov 16, 2017 22:42:41 GMT -6
Post by drsax on Nov 17, 2017 0:39:45 GMT -6
Anyone here doing this? There are tutorials for Logic...but the Apogee techs were worthless about Cubase? drsax? Johnkenn - Are you just trying to run external hardware on your FX sends via your Symphony Conversion? (Using External FX) If that’s what you’re trying to do I’d be happy to help you get set up.
Post by NoFilterChuck on Nov 17, 2017 0:47:27 GMT -6
Anyone here doing this? There are tutorials for Logic...but the Apogee techs were worthless about Cubase? drsax? I have not used the Symphony Johnkenn - I have an RME MADI FX card hooked up to an array of Burl, Hilo & Orion Converters. I dig the Symphony samples I’ve heard before. If they were PC compatible I’d seriously think about a Symphony setup over here Are you just trying to run external hardware on your FX sends via your Symphony Conversion? If that’s what you’re trying to do I’d be happy to help you get set up. they're PC compatible in that you can use the lightpipe connector on the back to pump into another converter, as well as Apogee's statement that the MK2 chassis with the Protools card (it comes with either the protools or thunderbolt card installed, your choice) is fully PC compatible.
Post by drsax on Nov 17, 2017 0:49:41 GMT -6
I have not used the Symphony Johnkenn - I have an RME MADI FX card hooked up to an array of Burl, Hilo & Orion Converters. I dig the Symphony samples I’ve heard before. If they were PC compatible I’d seriously think about a Symphony setup over here Are you just trying to run external hardware on your FX sends via your Symphony Conversion? If that’s what you’re trying to do I’d be happy to help you get set up. they're PC compatible in that you can use the lightpipe connector on the back to pump into another converter, as well as Apogee's statement that the MK2 chassis with the Protools card (it comes with either the protools or thunderbolt card installed, your choice) is fully PC compatible. yeah, I’ve thought of trying that. So is the MKII chassis capable of standalone mode now? I know when it was released it would not do standalone
Post by ragan on Nov 17, 2017 0:59:16 GMT -6
they're PC compatible in that you can use the lightpipe connector on the back to pump into another converter, as well as Apogee's statement that the MK2 chassis with the Protools card (it comes with either the protools or thunderbolt card installed, your choice) is fully PC compatible. yeah, I’ve thought of trying that. So is the MKII chassis capable of standalone mode now? I know when it was released it would not do standalone I think they've added that. Or at least I remember reading that.
Post by kcatthedog on Nov 17, 2017 2:49:22 GMT -6
Yes Standalone is a feature, got my new 16x16 yesterday and there was a single page sheet describing running options including standalone.
Post by kcatthedog on Nov 17, 2017 4:35:39 GMT -6
Symphony I/O Mk II Control 1.0 Release Notes What’s New? ● Support of 2 Symphony I/O Mk II Thunderbolt chassis for up to 64 Inputs and Outputs ● New Symphony Control software lets you customize your workflow from the comprehensive Primary window to the simplified Essentials strip ● Save Snapshots that let you save and open your custom session settings ● FX Send lets you use your DAW’s best reverb with Symphony Control low latency mixers ● Main Source Toggle lets you choose any two sources for the Main (Speaker) outputs and toggle between them with the click of a button. Toggle between different Control mixes or between a reference track from iTunes or Spotify. ● Support for Apogee Control Hardware Remote with eight software assignable buttons and adjustment knob ● Innovative Talkback feature allows use of the Mac’s Built in Mic, External Mic, or Digital Input. Talkback may be activated by Symphony Control Software or the Apogee Control Hardware Remote ● Standalone Mode offers use of Symphony I/O Mk II without a computer connected, Sample Rate and Clock Source are now adjustable from the front panel ● Support for Dolby Atmos 7.1.4 or 11.1 Surround mixing Attachment Deleted
Post by Johnkenn on Nov 17, 2017 8:45:34 GMT -6
they're PC compatible in that you can use the lightpipe connector on the back to pump into another converter, as well as Apogee's statement that the MK2 chassis with the Protools card (it comes with either the protools or thunderbolt card installed, your choice) is fully PC compatible. yeah, I’ve thought of trying that. So is the MKII chassis capable of standalone mode now? I know when it was released it would not do standalone Yes...it will default to standalone when not connected via Tbolt.
Post by Johnkenn on Nov 17, 2017 8:49:04 GMT -6
Here is what I'm trying to do...but AUX's are totally different in Cubase. Instead of one "Aux" Cubase has FX Channels and Group Channels. In this video and via chat with Apogee, they were wanting me to change the input of the AUX channel to the FX Sends (or 32-33)...but you can' change the input routing on an FX Channel. So I'm confused.
Post by drsax on Nov 17, 2017 10:03:11 GMT -6
Here is what I'm trying to do...but AUX's are totally different in Cubase. Instead of one "Aux" Cubase has FX Channels and Group Channels. In this video and via chat with Apogee, they were wanting me to change the input of the AUX channel to the FX Sends (or 32-33)...but you can' change the input routing on an FX Channel. So I'm confused. Wow, I can see why you’re confused Johnkenn - If this is Apogee’s solution to no latency effects, then they’ve got a long ways to go before their software interface catches up with the sound of their Converters . That’s ridiculous. Does the symphony software allow you to route a single ad input to multiple da outputs? A la RME total mix. If so, I’d look at a cheap Outboard digital mixer like a behringer x-air 12 for a couple hundred bucks and send your daw stereo mix plus incoming recorded channel and you can create a custom headphone mix with great sounding fx that is not even touching your daw. This is what makes the UA Apollo solution so attractive. Ugh...
Post by Johnkenn on Nov 17, 2017 10:45:23 GMT -6
Yeah...you wonder why they don't just put a damn $12 chip in the box and code a cheap verb on it. (I have no idea what I'm talking about) But I do remember The Steinberg boxes had just that. Yeah, I might just buy a cheap midiverb or something and be done with it.
Post by Johnkenn on Nov 17, 2017 10:46:49 GMT -6
Honestly, I'm hoping UA comes out with another box in the next two years that will be a step up...
Post by popmann on Nov 17, 2017 11:07:14 GMT -6
(For Cubase) You need to use a stereo AUDIO channel with the reverb inserted. You can define the input and output like the aux. Little "I" button makes it input monitor without recording it--so it will continue to pass audio signal "live". If it's not obvious, the reverb set to 100% wet.
Post by drsax on Nov 17, 2017 11:31:48 GMT -6
Yeah...you wonder why they don't just put a damn $12 chip in the box and code a cheap verb on it. (I have no idea what I'm talking about) But I do remember The Steinberg boxes had just that. Yeah, I might just buy a cheap midiverb or something and be done with it. That’s exactly what I was thinking about when I watched this video.
Post by drsax on Nov 17, 2017 11:32:32 GMT -6
(For Cubase) You need to use a stereo AUDIO channel with the reverb inserted. You can define the input and output like the aux. Little "I" button makes it input monitor without recording it--so it will continue to pass audio signal "live". If it's not obvious, the reverb set to 100% wet. Bingo... was getting ready to post this exact thing.
Post by Johnkenn on Nov 18, 2017 9:56:02 GMT -6
(For Cubase) You need to use a stereo AUDIO channel with the reverb inserted. You can define the input and output like the aux. Little "I" button makes it input monitor without recording it--so it will continue to pass audio signal "live". If it's not obvious, the reverb set to 100% wet. I tried that...but it wasn’t working. I’m thinking I must have had something screwy in the Symphony software.
Post by NoFilterChuck on Nov 18, 2017 10:27:30 GMT -6
(For Cubase) You need to use a stereo AUDIO channel with the reverb inserted. You can define the input and output like the aux. Little "I" button makes it input monitor without recording it--so it will continue to pass audio signal "live". If it's not obvious, the reverb set to 100% wet. I tried that...but it wasn’t working. I’m thinking I must have had something screwy in the Symphony software. Why don't you do a screenshare with kcat or someone else with a mk2?
Post by Johnkenn on Nov 18, 2017 10:43:50 GMT -6
None of them use Cubase. But I think it’s solved now.
