Post by drbill on Dec 8, 2017 14:22:00 GMT -6
Last time I croresponded with Colin, I suggested exactly this - a 1073 pre without the EQ. He mentioned that due to loading of the circuitry, it wouldn't sound the same, and at that point, he didn't seem keen on doing it..... Maybe competition from others forced it? At any rate, great price, and I'm sure it will sound good.
Post by Bender on Dec 8, 2017 16:53:20 GMT -6
I guess we will see, I looked up a post by Geoff Tanner, The man, the legend! Too bad he isn’t on here dropping nuggets!!! I forgot lots of you are way more than capable of diy options... silly me!
Post by kilroyrock on Dec 8, 2017 16:57:07 GMT -6
Maybe he is loading the circuit another way?, maybe you're right..
Post by EmRR on Dec 8, 2017 17:17:30 GMT -6
WWRD?
Post by kilroyrock on Dec 8, 2017 22:01:28 GMT -6
I have a 511 too
Post by miscend on Dec 9, 2017 20:24:11 GMT -6
It’s much cheaper in total than the Don Classics and even the Soundskulptor. I am actually very skeptic about this. It’s possible that’s it’s more of an inspired by the 1073 (like the GAP73) rather a true and accurate clone.
Post by NoFilterChuck on Dec 9, 2017 22:54:54 GMT -6
Post by kilroyrock on Dec 11, 2017 21:24:20 GMT -6
Fastest shipping ever with these kits. These trimmed resistor leads are killing me though, I can't flip it over without spilling them back out and they are too short to bend. What's the secret to soldering these little f'ers?
I feel like I'd be done with one by now if I didn't have to keep searching for one that dropped out when trying to solder it
Post by mulmany on Dec 11, 2017 21:43:59 GMT -6
Fastest shipping ever with these kits. These trimmed resistor leads are killing me though, I can't flip it over without spilling them back out and they are too short to bend. What's the secret to soldering these little f'ers? I feel like I'd be done with one by now if I didn't have to keep searching for one that dropped out when trying to solder it Use blue tape to hold them in place.
Post by kilroyrock on Dec 11, 2017 22:35:15 GMT -6
Yeah that would save time I think i just need to be patient. But doing two at a time is sure trying. 3 hours in, got half the resistors done. 1.5 each you could say. Time for bed!
Post by NoFilterChuck on Dec 11, 2017 22:39:41 GMT -6
whenever I built colin's kits, I always soldered resistors, etc on the side they were installed on. other components with longer leads, I could bend the leads to hold them in place and would then flip the board over. the solder bead would always flow thru to the opposite side of the PCB. I never ran into any problems soldering that way (same side as the component)
Post by kilroyrock on Dec 12, 2017 5:28:56 GMT -6
whenever I built colin's kits, I always soldered resistors, etc on the side they were installed on. other components with longer leads, I could bend the leads to hold them in place and would then flip the board over. the solder bead would always flow thru to the opposite side of the PCB. I never ran into any problems soldering that way (same side as the component) I was afraid of mentioning that is what I did for fear of ridicule, after coming here and asking/venting. It popped in my head to try, and made it way quicker, and I'm not that bad with my pin. I will second your approach, and feel better breaking the #1 PCB soldering rule
Post by NoFilterChuck on Dec 12, 2017 5:32:35 GMT -6
whenever I built colin's kits, I always soldered resistors, etc on the side they were installed on. other components with longer leads, I could bend the leads to hold them in place and would then flip the board over. the solder bead would always flow thru to the opposite side of the PCB. I never ran into any problems soldering that way (same side as the component) I was afraid of mentioning that is what I did for fear of ridicule, after coming here and asking/venting. It popped in my head to try, and made it way quicker, and I'm not that bad with my pin. I will second your approach, and feel better breaking the #1 PCB soldering rule Lol there is a rule saying to not do that? That's what I get for learning to solder via YouTube hahaha
Post by NoFilterChuck on Dec 13, 2017 11:01:10 GMT -6
Colin posted this to Facebook. So, 1073 pre/line and 1081 pre/line. 4 different models for the DIY'er.
Post by terryrocks on Dec 13, 2017 11:34:48 GMT -6
Can’t wait to hear these on drums
Post by kilroyrock on Dec 13, 2017 15:12:04 GMT -6
ah, so these other two can live on my 2 bus!
Post by miscend on Dec 14, 2017 8:00:40 GMT -6
Be sure to post impressions after you have finished your builds!
Post by kilroyrock on Dec 14, 2017 16:20:04 GMT -6
Be sure to post impressions after you have finished your builds! My impression right now, is this build is a monster, and may be worth the 90 pounds to get it built for me 4.5 hours into the pair - i'm on the capacitors I would also recommend the CAPI 500 series extension rig - you're gonna be calibratin' by the time the night is through!
Post by miscend on Dec 17, 2017 1:43:11 GMT -6
I need some help. I was struggling to get the molex connector to fit into the pins on the circuit board. There was something wrong with it so I hard to force it down into position.
Now when I connect a power source I’m getting 26.8 mV when I put probes on the TP1 and TP2 test points. Turning the bias adjuster has no effect on this. So I am unable to get it up to 90 mV as required in the build doc. What’s the next trouble shooting step?
Post by kilroyrock on Dec 17, 2017 12:26:09 GMT -6
I need some help. I was struggling to get the molex connector to fit into the pins on the circuit board. There was something wrong with it so I hard to force it down into position. Now when I connect a power source I’m getting 26.8 mV when I put probes on the TP1 and TP2 test points. Turning the bias adjuster has no effect on this. So I am unable to get it up to 90 mV as required in the build doc. What’s the next trouble shooting step? Reflow your solder joints in the pins involved, one may have gotten loose or coupled? I'm sure Colin would be willing to help? He is very responsive with email
Post by jayson on Dec 25, 2017 14:36:23 GMT -6
Fastest shipping ever with these kits. These trimmed resistor leads are killing me though, I can't flip it over without spilling them back out and they are too short to bend. What's the secret to soldering these little f'ers? I feel like I'd be done with one by now if I didn't have to keep searching for one that dropped out when trying to solder it Yeah, I agree on both counts. Shipping to the East coast US was amazing - almost overnight. But during assembly you have to have some electric tape handy and tape 'em down as you go. That REALLY drove me bonkers doing the 1081 kits. I really enjoy trimming component leads myself, then I can stuff the board and only commit to soldering once I'm sure everything is in the appropriate place. Instead I found myself either taping them down or soldering every component individually as I went along. Either way it was slow going. Gotta say that I was NOT unhappy at the end of the process though; they sound fantastic!
Post by kilroyrock on Dec 25, 2017 16:28:47 GMT -6
Fastest shipping ever with these kits. These trimmed resistor leads are killing me though, I can't flip it over without spilling them back out and they are too short to bend. What's the secret to soldering these little f'ers? I feel like I'd be done with one by now if I didn't have to keep searching for one that dropped out when trying to solder it Yeah, I agree on both counts. Shipping to the East coast US was amazing - almost overnight. But during assembly you have to have some electric tape handy and tape 'em down as you go. That REALLY drove me bonkers doing the 1081 kits. I really enjoy trimming component leads myself, then I can stuff the board and only commit to soldering once I'm sure everything is in the appropriate place. Instead I found myself either taping them down or soldering every component individually as I went along. Either way it was slow going. Gotta say that I was NOT unhappy at the end of the process though; they sound fantastic! Yeah man. Capacitors had long leads though, so I stuffed them all at once I'm curious how it will compare to my gap pre 73 with the carnhills. Now it's a question if I get two more pres, or those line amps!
Post by kilroyrock on Jan 1, 2018 15:07:40 GMT -6
Pending calibration!
Post by kilroyrock on Jan 4, 2018 17:35:04 GMT -6
Last time I croresponded with Colin, I suggested exactly this - a 1073 pre without the EQ. He mentioned that due to loading of the circuitry, it wouldn't sound the same, and at that point, he didn't seem keen on doing it..... Maybe competition from others forced it? At any rate, great price, and I'm sure it will sound good. So you're saying it's possible for this pre amp to sound even better? Because this sounds great! I was expecting that trim screw to be a pain, but I can use my thumb nail easily enough!
Post by drbill on Jan 4, 2018 17:49:26 GMT -6
Last time I croresponded with Colin, I suggested exactly this - a 1073 pre without the EQ. He mentioned that due to loading of the circuitry, it wouldn't sound the same, and at that point, he didn't seem keen on doing it..... Maybe competition from others forced it? At any rate, great price, and I'm sure it will sound good. So you're saying it's possible for this pre amp to sound even better? Because this sounds great! I was expecting that trim screw to be a pain, but I can use my thumb nail easily enough! Better or not is in the ear of the beholder. Bottom line - it won't sound as much like a 1073 as a 1073 with an EQ - which is exactly what a real 1073 IS.
