Post by zander on Nov 14, 2017 15:57:48 GMT -6
Hi everyone, First post here. Been reading this forum for a while I have been reading about and testing solutions for an hdmi or kvm extender. I have a 3440x1440 display I need to connect with a mac pro approx. 15m/165ft. away from each other. I have tested an active hdmi cable with no succes (not enough power to feed the booster according to their tech support). I need 4K resolotion for the display at 60Hz uncompressed. Any recommendations? Zander
Post by veggieryan on Nov 14, 2017 17:15:06 GMT -6
Post by winetree on Nov 14, 2017 17:55:24 GMT -6
Monoprice.com
Post by mulmany on Nov 14, 2017 19:29:21 GMT -6
Hi everyone, First post here. Been reading this forum for a while I have been reading about and testing solutions for an hdmi or kvm extender. I have a 3440x1440 display I need to connect with a mac pro approx. 15m/165ft. away from each other. I have tested an active hdmi cable with no succes (not enough power to feed the booster according to their tech support). I need 4K resolotion for the display at 60Hz uncompressed. Any recommendations? Zander By "4k" what do you mean? You could get away with an HDSDI solution, unless you need HDCP compliance. I would look at a balun solution, but you will never pass true video 4K over a Cat5/6 solution. An optical HDMI cable is the only viable solution for over 13G transmission rate over 24'.
Post by zander on Nov 15, 2017 12:18:47 GMT -6
Thanks for the advice! I will get back and post what I find.
Post by zander on Nov 15, 2017 12:51:21 GMT -6
Post by zander on Nov 29, 2017 22:58:18 GMT -6
For the record. I bought an Opticis optical displayport extender. This works fine with 4K @ 60 Hz uncompressed streams over 20m.
