Post by forgotteng on Oct 16, 2017 13:35:34 GMT -6
My power supply for my Charter Oaks s600 died on me. Anyone have an idea where I could get it repaired or find a replacement for it? Is Charter Oaks even around anymore? I looked at the website but none of the numbers worked. Any ideas? I love my mics and want to use them.
Post by johneppstein on Oct 16, 2017 16:11:12 GMT -6
My power supply for my Charter Oaks s600 died on me. Anyone have an idea where I could get it repaired or find a replacement for it? Is Charter Oaks even around anymore? I looked at the website but none of the numbers worked. Any ideas? I love my mics and want to use them. They're supposed to be at AES and about 3 other shows in various countries this month. Maybe this isn't the best time to get hold of them?
Post by ericn on Oct 16, 2017 17:26:57 GMT -6
My power supply for my Charter Oaks s600 died on me. Anyone have an idea where I could get it repaired or find a replacement for it? Is Charter Oaks even around anymore? I looked at the website but none of the numbers worked. Any ideas? I love my mics and want to use them. They're supposed to be at AES and about 3 other shows in various countries this month. Maybe this isn't the best time to get hold of them? They have always been on shaky ground, so who knows, but give our own Shannon at mic rehab a ring he will lay it all out for you!
Post by johneppstein on Oct 16, 2017 20:34:03 GMT -6
A power supply really shouldn't be a difficult fix.
Post by ericn on Oct 16, 2017 20:40:33 GMT -6
A power supply really shouldn't be a difficult fix. I think it's probably generic made in China but if one can't find tech local for mics Shannon should be first call.
Post by forgotteng on Oct 16, 2017 22:14:32 GMT -6
A power supply really shouldn't be a difficult fix. I'm hoping that is the case. In a moment of weakness(laziness) I plugged my Rode K2 into the power supply and I thought I heard a click or a pop. It didn't work and after that didn't work for either S600. Might be a coincidence but I was wondering if some power supplies were not identical. I did check the fuse and it seams to still meter continuity. Of course I'm no electrical engineer so?..........
Post by johneppstein on Oct 17, 2017 13:37:05 GMT -6
A power supply really shouldn't be a difficult fix. I'm hoping that is the case. In a moment of weakness(laziness) I plugged my Rode K2 into the power supply and I thought I heard a click or a pop. It didn't work and after that didn't work for either S600. Might be a coincidence but I was wondering if some power supplies were not identical. I did check the fuse and it seams to still meter continuity. Of course I'm no electrical engineer so?.......... No, many power supplies are not identical, in a variety of ways. Different voltages, different current capacities, different pinouts, different numbers of voltages supplied, some supplies include pattern control, which means varying voltages to one or both diaphragms, etc, etc. NEVER assume that one mic is compatible with a supply made for another. While many Chinese supplies might be identical, you never know. A click or pop sounds like you blew a semiconductor lke a regulator, transistor, or diode, but it might also be a blown cap. Usually when a cap goes all at once like that it goes "BANG!", though.
Post by forgotteng on Oct 19, 2017 10:24:07 GMT -6
I'm hoping that is the case. In a moment of weakness(laziness) I plugged my Rode K2 into the power supply and I thought I heard a click or a pop. It didn't work and after that didn't work for either S600. Might be a coincidence but I was wondering if some power supplies were not identical. I did check the fuse and it seams to still meter continuity. Of course I'm no electrical engineer so?.......... No, many power supplies are not identical, in a variety of ways. Different voltages, different current capacities, different pinouts, different numbers of voltages supplied, some supplies include pattern control, which means varying voltages to one or both diaphragms, etc, etc. NEVER assume that one mic is compatible with a supply made for another. While many Chinese supplies might be identical, you never know. A click or pop sounds like you blew a semiconductor lke a regulator, transistor, or diode, but it might also be a blown cap. Usually when a cap goes all at once like that it goes "BANG!", though. Thanks johneppstein that's helpful.
Post by forgotteng on Jan 8, 2018 21:08:53 GMT -6
I sent the mics out to Shannon at mic rehab to check the power supply. Now the problem is I have to decide whether to let Shannon redo them. I wanna do it but is it worth it? Choices choices.
Post by ericn on Jan 8, 2018 22:32:29 GMT -6
I sent the mics out to Shannon at mic rehab to check the power supply. Now the problem is I have to decide whether to let Shannon redo them. I wanna do it but is it worth it? Choices choices. Yes, if the quality of a mic tuned to your liking is worth more than resale value. You probably could not get the mic Shannon can give you without spending significantly more elsewhere and spending significantly more makeing wrong choices, but if resale value is the thing you won't get anywhere near what you should be able to get out of a Shannon tuned mic based on Something like a CA as you should, but a Shannon tuned mic should be more valueable to you because it is tuned to what you want!
Post by forgotteng on Jan 9, 2018 19:23:56 GMT -6
Yea ericn, that is my struggle. For my own curiosity I want to pull the trigger but being a big fish in a little pond out here in Pennsylvania, I wonder if my clients and budget can justify it. Of course my quest for the craft will more than likely out way any common sense again. Why should I turn back now?
Post by channelcat on Jan 9, 2018 20:27:35 GMT -6
My first thought for PSU repair/replacement was Hamptone, but if it’s already in Shannon’s very capable hands, I know you’ll be fine.
Post by ericn on Jan 9, 2018 20:42:34 GMT -6
Yea ericn, that is my struggle. For my own curiosity I want to pull the trigger but being a big fish in a little pond out here in Pennsylvania, I wonder if my clients and budget can justify it. Of course my quest for the craft will more than likely out way any common sense again. Why should I turn back now? Oh man I get it, not to sound like Shannon's PR guy, but as a guy who sold a couple of very very large boatloads of mics, I look at Shannon as a shortcut to a great sounding mic, the big exception here is if you have clients who care more about the name on the mic than the sound!
