Post by mrholmes on May 24, 2017 10:00:48 GMT -6
In my Setup all the Outputs don't go to Logics default Output 1+2. Asking the peps in the Apple forum just brought up that I can change default Out 1+2 running the assistant software. You cant change it for the Loop Browser which always goes to 1+2. In the meantime using any Apple-Loops I had to switch to the RME software do get a different routing for pre listening the Loops. Very annoying.The solution is simple but you need the light bulb moment.Go to your midi- environment choose the Channel Strip for Output 1-2 use the I/O plug in and route the output in the plug in -DONE.
Post by ericbradley on Jul 26, 2017 5:27:54 GMT -6
I'm not sure why you don't change the Prelisten channel strip output instead?
Post by NoFilterChuck on Jul 26, 2017 20:03:39 GMT -6
I'm not sure why you don't change the Prelisten channel strip output instead? yeah, if you set the mixer to display "All" you'll see it. He probably hasn't seen that channel, or forgot it exists.
