Post by ericn on May 25, 2017 15:24:36 GMT -6
The mic pre one is the A-Range circuit only with a Jensen input transformer and a THAT balanced output driver. I am still very impressed. I understand the consoles also didn't use output transformers. I thought the old version of the console had the Transformer & the new console used the THAT / Jensen driver.
Post by Bob Olhsson on May 25, 2017 16:51:41 GMT -6
I forget who told me that the Trident A-Range console didn't use output transformers. I think they were even unbalanced. It made sense because in the early '70s many studios were removing transformers and the distance between the console and tape recorder was minimal.
THAT is the successor to DBX. They make VCA, mike preamp and line driver chips.
Post by ericn on May 25, 2017 17:09:41 GMT -6
I forget who told me that the Trident A-Range console didn't use output transformers. I think they were even unbalanced. It made sense because in the early '70s many studios were removing transformers and the distance between the console and tape recorder was minimal. THAT is the successor to DBX. They make VCA, mike preamp and line driver chips. I' ll try and get a hold of Lonya who kept the A Range at Smart and see .
Post by nobtwiddler on May 25, 2017 19:16:32 GMT -6
I commissioned, Geoff to design and build the first Daking 52270 Console.
It had transformers on the Mic & Line inputs as well as the outputs. I think I also was the only one with a fully transformer balanced monitor section... He later changed the monitor section to "THAT" chips, for the following consoles.
Post by roundbadge on May 26, 2017 1:15:38 GMT -6
And for what its worth imo the whole A Range thing is waay overhyped.they were good but not holy grail etc. still preferred my vintage 1084's over the vintage A Ranges.
Post by Deleted on May 26, 2017 12:23:37 GMT -6
The mic pre one is the A-Range circuit only with a Jensen input transformer and a THAT balanced output driver. I am still very impressed. I understand the consoles also didn't use output transformers. Like mine a lot. I didn't realise how coloured my Audient pre's were until I used the Daking. Bit of a qc issue in the earlier ones ( gain light pcb )but they did resolve it. Loads of headroom and clear gain - it loves ribbon mics. Not a classic studio shape tho' if that's important to you?
Post by Bob Olhsson on May 26, 2017 12:43:38 GMT -6
I hung an old blue iPad cover over mine.
Post by Deleted on May 26, 2017 14:11:56 GMT -6
I hung an old blue iPad cover over mine. to stop the artefacts at high gain?
Post by Bob Olhsson on May 26, 2017 15:46:47 GMT -6
The paint job was too loud for my taste.
Post by Deleted on May 26, 2017 16:29:38 GMT -6
ok, it's you're turn to play the straight man
Post by Bob Olhsson on Jun 24, 2017 11:18:34 GMT -6
Key parts may no longer be made. That's a problem with lots of early solid state gear.
Post by guitfiddler on Jun 26, 2017 20:15:39 GMT -6
I'm looking at RTZ 9672 and Great River mp2nv.. the latter I can find used which would be cheaper. Both Neve - esque flavors .. They both rock!!!! Can't go wrong with either...I say get both if you can!!!
