Post by kcatthedog on May 20, 2017 9:44:39 GMT -6
Hey,
I was experimenting this morning using all button mode on my wa76s to drive distortion on a lead vocal.
How do people usually go about this ?
I am running logic so use its utility i/o plug and I do understand it has its on i/o as well.
thx !
Post by ragan on May 20, 2017 9:51:23 GMT -6
Hey, I was experimenting this morning using all button mode on my wa76s to drive distortion on a lead vocal. How do people usually go about this ? I am running logic so use its utility i/o plug and I do understand it has its on i/o as well. thx ! For dirt, I like to leave all the ratio buttons out and just crank the input and attenuate the output.
Post by kcatthedog on May 20, 2017 10:17:23 GMT -6
Interesting Experiment # 2 coming up : thx !
Post by bowie on May 20, 2017 13:14:18 GMT -6
I've never had much overdrive-type distortion from the 4-button trick. Slamming the input of a comp (like Ragan was saying) or preamp tend to be better for that sort of thing. Each piece of gear does it in it's own way. Tip; compress the signal before pushing it into distortion so that you're getting a more even-handed saturation and not just hitting the peaks. It's a more uniform distortion instead of the ugly clipping from the dynamic peaks hitting hard.
Post by kcatthedog on May 20, 2017 14:39:48 GMT -6
Thx Bowie. I was getting some artifacts with 4 button mode, but was curious
Post by kcatthedog on May 21, 2017 10:41:05 GMT -6
Worked great:thx guys !
Post by illacov on May 21, 2017 10:50:02 GMT -6
Hey, I was experimenting this morning using all button mode on my wa76s to drive distortion on a lead vocal. How do people usually go about this ? I am running logic so use its utility i/o plug and I do understand it has its on i/o as well. thx ! Insert a preamp before the 76. Crank some gain. 4 buttons mode works great with hot signal. I use it on punk vocals but make the singer back up from the mic. Sounds really gnarly. Thanks -L.
Post by illacov on May 21, 2017 10:55:17 GMT -6
Featured on this track but really the whole album in varying amounts: FET47 to 1073 to 1176 REVF all buttons in. 1073 dimed on input and output attenuated into 1176 input at 2 o'clock and ouput at 11 o'clock. malvinas.bandcamp.com/track/no-holesThanks -L.
Post by kcatthedog on May 21, 2017 11:07:18 GMT -6
great over the top vocal !! Nicely done !
Post by ChaseUTB on May 21, 2017 23:34:16 GMT -6
Wow that gives me a new definition to distorted vocals 😱😀
Post by illacov on May 21, 2017 23:44:34 GMT -6
Wow that gives me a new definition to distorted vocals 😱😀 Fempunk artcore man! They said they wanted some real cutting distortion for this one record and I wanted to track with it to work it into the performance so..... Microphones set to stun Thanks -L.
Post by iamasound on May 22, 2017 2:58:41 GMT -6
After listening to the track, not only do I now have a hole in my head, but I am bleeding from every orifice of my body. Cool track, heavy vocal, cheers to the ladies from Syracuse.
Post by kcatthedog on May 22, 2017 8:59:41 GMT -6
Since we are sharing tunes: here is what I came up with: my new tune "something new again". thx to Rick, Shane, Martin , Dan and Ragan for getting their ears on this as it developed. oh and to Wiz, this whole tune got started playing my acoustic guitar outside one sunny day and I had the Music memo record app that he recommended on my iphone: otherwise it would probably have been lost: thx Wiz ! soundcloud.com/kcatthedog/something-new-again-27
