Post by spilota on Jan 5, 2018 20:55:05 GMT -6
Just got an email back basically saying that the capsule enclosures are all vented (probably not cost effective to manufacture a different one for Omni), but the Omni caps themselves are not vented; if that makes any sense.
Just thought I’d pass this along in case anyone was also wondering. I would still welcome any recording samples of these mics that anyone wants to post.
I’m definitely looking forward to the upgraded/matched pair, which will hopefully be available at the end of the month!
Post by mulmany on Jan 5, 2018 22:11:09 GMT -6
Just got an email back basically saying that the capsule enclosures are all vented (probably not cost effective to manufacture a different one for Omni), but the Omni caps themselves are not vented; if that makes any sense. Just thought I’d pass this along in case anyone was also wondering. I would still welcome any recording samples of these mics that anyone wants to post. I’m definitely looking forward to the upgraded/matched pair, which will hopefully be available at the end of the month! What's the word on what the AMI tranny brings to the table?
Post by EmRR on Jan 6, 2018 11:09:15 GMT -6
So that's normal to have more gain with lower pre/transformer input impedance, good to know. I heard back from Chandler and indeed, 1200 is out, 300 is in, so that does all seem to add up. Guosheng told me 1200 ohm would be better for the 127, "If you use 300 ohms, the mic will work with lower sensitivity" though, which is still confusing me, cos with 300 ohm it's louder (about 5dB as stated above). The mic loses output level and sensitivity when loaded more heavily, but the transformer has 6dBish more gain with windings in parallel at 300 versus series at 1200. The transformer gain is winning the tug of war there, but response and distortion are also very likely affected for the worse. It all depends on what you like the sound of. 300 in most cases is a bit of a bandpass situation with extra fuzz.
Post by Deleted on Jan 6, 2018 14:55:18 GMT -6
Thanks so much for that explanation EmRR ! It was still bugging me not understanding the reasons behind it. I guess it's a trade-off between gain and linearity, but as it's only a 5dB difference, and the TG2 sounds pretty great wherever it's parked, like you say, you're gonna have to chose based on what sounds best on each source, or for each mix, or mix them up and pan them for a different vibe for each take of a double tracked guitar etc. I've noticed this with my AA CM48T too, tube/transformer mic into the same TG2 pre. On that mic, 1200 sounds great, but I actually prefer the gooey/coloured/saturated/vintage etc. tone with the pre at 300 ohm, on most things. This mic's specs state: which I assume means 1200 is theoretically ideal.
Post by matt@IAA on Jan 10, 2018 20:10:26 GMT -6
Post by ericn on Jan 10, 2018 20:39:23 GMT -6
Just got an email back basically saying that the capsule enclosures are all vented (probably not cost effective to manufacture a different one for Omni), but the Omni caps themselves are not vented; if that makes any sense. Just thought I’d pass this along in case anyone was also wondering. I would still welcome any recording samples of these mics that anyone wants to post. I’m definitely looking forward to the upgraded/matched pair, which will hopefully be available at the end of the month! Simple metal work has vents, something blocks them inside blocks them! Metal work $$ plastic or some kind of caulk pennies!
Post by ragan on Jan 10, 2018 20:47:55 GMT -6
This link is taking me to one of your tube rolling thread samples, FYI.
Post by matt@IAA on Jan 10, 2018 20:50:45 GMT -6
This link is taking me to one of your tube rolling thread samples, FYI. copy paste defeats me ahah. Fixed it thanks.
Post by wiz on Jan 10, 2018 23:27:19 GMT -6
This link is taking me to one of your tube rolling thread samples, FYI. copy paste defeats me ahah. Fixed it thanks. Unless your name is martin....8) .... its someone singing, not a guitar Cheers Wiz
Post by ragan on Jan 11, 2018 0:44:17 GMT -6
This link is taking me to one of your tube rolling thread samples, FYI. copy paste defeats me ahah. Fixed it thanks. Sounds nice. Warm and very balanced.
Post by stormymondays on Jan 19, 2018 9:13:17 GMT -6
After a lot of testing I've decided that I'm selling mine. If anyone in Europe is interested, drop me a message.
It's a nice mic, for sure, and the price is incredible. However, it didn't trump my other SDCs.
Post by mulmany on Jan 19, 2018 11:31:18 GMT -6
After a lot of testing I've decided that I'm selling mine. If anyone in Europe is interested, drop me a message. It's a nice mic, for sure, and the price is incredible. However, it didn't trump my other SDCs. What did you put it up against? MJ 012's?
Post by stormymondays on Jan 19, 2018 12:19:05 GMT -6
What did you put it up against? MJ 012's? Yes, that's correct. They both have their strengths, but I ended up liking the MJ more.
Post by plinker on Jan 27, 2018 8:44:36 GMT -6
Does anyone know if 3U sells their LDC capsules, stand-alone?
I noticed that Barbaric Amplification uses them in their builds.
Thanks.
Post by ragan on Jan 27, 2018 9:33:47 GMT -6
Does anyone know if 3U sells their LDC capsules, stand-alone? I noticed that Barbaric Amplification uses them in their builds. Thanks. They do. You can buy any of them separately.
Post by gouge on Jan 27, 2018 19:46:39 GMT -6
What did you put it up against? MJ 012's? Yes, that's correct. They both have their strengths, but I ended up liking the MJ more. I love the mj pair I use.
