Post by c0rtland on Sept 22, 2017 11:04:14 GMT -6
Pair tele v672 Mint OP-6 Mint all original melodium 42b Sansamp psa 1.1 Dept. of Commerce limiter (we will see how this one turns out). Unidyne 545 a pair of stager sr-1a's from our own rgo gear dealer johnkenn. Thanks for the hook!
Post by joseph on Sept 22, 2017 11:48:28 GMT -6
Ha, I got exact same model and color yesterday! Put La Bella flats on it, adjusted truss. Plays exceptionally well and so light! I got the 58 AV sunburst precision a few weeks ago. it is beautiful and a serious joy to play. ordered some labella 54 originals for it. admittedly, this is my first time buying a new bass. first was squire and then a MIM. Both were craigslist buys and I never changed anything about them. Any tips on adjusting the truss for the labellas? they should be arriving in the next few days. Are those "mediums," at .052 - .110? If so, then those are pretty thick, but will sound real good. The FS flats I got are standard gauge but because flats are higher tension than round wounds of same gauge, I had to adjust the truss. You have to take off the neck and use a phillips head. Be careful lifting it out of the pocket. I had to tighten the truss about 1/5 turn to the right, and surprisingly did not have to re-intonate. I did adjust the pickup heights to get optimal string balance. You will probably have to turn the truss screw a little more given the higher tension and then adjust the saddles, 2nd link below. You might also find you want to adjust the saddle height as well, for comfort. support.fender.com/hc/en-us/articles/214343843-How-do-I-set-up-my-bass-guitar-properly-www.wikihow.com/Adjust-Intonation-on-BassIf it seems like you have to adjust truss a lot, then you're supposed to do it in increments, let it settle overnight the first time. If anything seems wonky and uneven with the neck curvature, then you should take of the strings and go lighter gauge.
Post by jtc111 on Sept 24, 2017 20:43:54 GMT -6
Does a new iMac count? I ordered a 27" Retina 5K with a 4.2 quad processor and 32gb of 2400MHz DDR4 ram. I'm going to hook up an Akitio Thunder3 Quad Mini which will hold 4 ssd drives. I'm also going to pickup a Thunderbolt option card for my Apollo firewire and I'm going to sell my UAD pcie cards and pick up a Thunderbolt Octo Satellite. Anyway, the new iMac should be here on October 8th. I also have a new guitar being built by Adam Buchwald of Circle Strings up in Burlington, Vermont. It's a Bastogne Walnut/Sinker Redwood 00. I'm guessing that will be ready sometime in November. Here's a picture of the top and back...
Post by john on Sept 26, 2017 12:02:44 GMT -6
I got the 58 AV sunburst precision a few weeks ago. it is beautiful and a serious joy to play. ordered some labella 54 originals for it. admittedly, this is my first time buying a new bass. first was squire and then a MIM. Both were craigslist buys and I never changed anything about them. Any tips on adjusting the truss for the labellas? they should be arriving in the next few days. Are those "mediums," at .052 - .110? If so, then those are pretty thick, but will sound real good. The FS flats I got are standard gauge but because flats are higher tension than round wounds of same gauge, I had to adjust the truss. You have to take off the neck and use a phillips head. Be careful lifting it out of the pocket. I had to tighten the truss about 1/5 turn to the right, and surprisingly did not have to re-intonate. I did adjust the pickup heights to get optimal string balance. You will probably have to turn the truss screw a little more given the higher tension and then adjust the saddles, 2nd link below. You might also find you want to adjust the saddle height as well, for comfort. support.fender.com/hc/en-us/articles/214343843-How-do-I-set-up-my-bass-guitar-properly-www.wikihow.com/Adjust-Intonation-on-BassIf it seems like you have to adjust truss a lot, then you're supposed to do it in increments, let it settle overnight the first time. If anything seems wonky and uneven with the neck curvature, then you should take of the strings and go lighter gauge. Thanks Joseph. These are actually the heaviest they make I believe. But I figured if the bass is supposed to be 58 then it should handle strings that are supposed to be from 54. There are many great reviews of them.
Im going to take a stab at it this evening.
Post by joseph on Sept 29, 2017 10:51:27 GMT -6
How did it go?
Post by Deleted on Sept 29, 2017 11:23:06 GMT -6
Just in to say this is a good page, I'm back out again.. Maybe I'll be in later, who knows?
Post by rowmat on Oct 2, 2017 20:45:23 GMT -6
Really more of a DIY post but I did acquire 100x 3300pf polystyrene capacitors to replace the 3.3nf greencaps in the high EQ band of my Neotek Elite. Unfortunately radial polystyrene capacitors are becoming even harder to get than axial electrolytics (first world problem) so I had to settle for N.O.S. axial polystyrenes for 0.35 cents each (about 28 cents US) I'll probably replace the remaining EQ capacitors with Wima Metalised Polypropylenes when I can locate the correct values and maybe experiment with some other opamps. Although the stock Elite EQ isn't too shabby 32 Channels of EQ somewhere in the ballpark of the Kush Electra is what I'm aiming for.
Post by unit7 on Oct 3, 2017 9:17:58 GMT -6
Follow up on the Sonic Farm Beamer I ordered last week. Came yesterday. Very well packed, top notch and beautiful build and some cool options that really affect the sound, for instance the option to switch the output transformer in/out, which you can really hear. When ordering you can even choose Ni or Fe in the o/p transformers. I chose Fe for more colour when wanted. Though at first test today I preferred the output switched to the solid state setting. Zoran and Boris have been nice and easy to deal with. Solid and serious. If you're shopping for a tube pre it's worth checking out: www.sonicfarm.com
Post by Guitar on Oct 4, 2017 20:36:46 GMT -6
Just unboxing these things. I'll show you the full Tower of Shame when the Autocom is plugged in and everything is patched and ready.
Post by winetree on Oct 4, 2017 21:18:41 GMT -6
The tube Rack. 4 channels of Preamp, E.Q., Compression. Getting one more E.Q. to fill the bottom empty space. All wired to the top patchbay with Mogami digital cable. Yea, that's a 4 channel Boulder Jensen Twin Servo Microphone Preamp on top.
Post by mulmany on Oct 4, 2017 21:30:40 GMT -6
The tube Rack. 4 channels of Preamp, E.Q., Compression. Getting one more E.Q. to fill the bottom empty space. All wired to the top patchbay with Mogami digital cable. Yea, that's a 4 channel Boulder Jensen Twin Servo Microphone Preamp on top. View AttachmentIs that an ADL 1000 on top? Hope you have good cooling in that rack! To bad you don't have winter in LA. What is your take on the Warm/KT debate?
Post by ericn on Oct 4, 2017 21:40:43 GMT -6
The tube Rack. 4 channels of Preamp, E.Q., Compression. Getting one more E.Q. to fill the bottom empty space. All wired to the top patchbay with Mogami digital cable. Yea, that's a 4 channel Boulder Jensen Twin Servo Microphone Preamp on top. View AttachmentDamn I'm just going to cuddle up in the back of that rack and stay toasty warm this winter!
Post by winetree on Oct 4, 2017 22:05:08 GMT -6
The tube Rack. 4 channels of Preamp, E.Q., Compression. Getting one more E.Q. to fill the bottom empty space. All wired to the top patchbay with Mogami digital cable. Yea, that's a 4 channel Boulder Jensen Twin Servo Microphone Preamp on top. Is that an ADL 1000 on top? Hope you have good cooling in that rack! To bad you don't have winter in LA. What is your take on the Warm/KT debate? Yes, ADL 1000. It's serial # 9. It has the original UTC transformers. The Stams also have replacement old gray, badged UTC transformers. Just got the KT yesterday with another one one the way. With just getting the rack together and wired I haven't had time to fully heat the room or do comparison tests. All in do time. That room has separate air conditioning.
Post by unit7 on Oct 5, 2017 0:39:49 GMT -6
Love your rack winetree! While talking ADL, for the few members from EU, there's an ADL1500 (b-stock) for a really nice price at KMR right now. I really like Anthony's optos. They hug in a very musical way, me thinks.
Post by Guitar on Oct 5, 2017 6:36:11 GMT -6
Here is my Tower of Shame From top to bottom: Unbuilt Serpent SB4000 stereo compressor 2 Samson TRS patchbays Dantone/WAC Nigel summing mixer slash 4x reamp in 1RU. the "penny compressor" one half of a modified 3630 that still kind of works modified Behringer Composer MDX2100 my main HW stereo bus compressor (pending serpent build most likely) new addition Behringer Autocom MDX1200 still needs to be modified, probably by the end of the week KT-EQP x2 (plugged in, burned in, haven't listened yet) Musician's Friend cheapo power conditioner
Post by notneeson on Oct 5, 2017 10:46:46 GMT -6
Here is my Tower of Shame From top to bottom: Unbuilt Serpent SB4000 stereo compressor 2 Samson TRS patchbays Dantone/WAC Nigel summing mixer slash 4x reamp in 1RU. the "penny compressor" one half of a modified 3630 that still kind of works modified Behringer Composer MDX2100 my main HW stereo bus compressor (pending serpent build most likely) new addition Behringer Autocom MDX1200 still needs to be modified, probably by the end of the week KT-EQP x2 (plugged in, burned in, haven't listened yet) Musician's Friend cheapo power conditioner What did you do to the MDX1200?
Post by notneeson on Oct 5, 2017 10:49:06 GMT -6
I just bought a Tascam DR40 for a remote interview gig. Not so sexy, but makes sense as I get these kind of gigs from time to time.
Post by Guitar on Oct 5, 2017 10:51:18 GMT -6
Here is my Tower of Shame From top to bottom: Unbuilt Serpent SB4000 stereo compressor 2 Samson TRS patchbays Dantone/WAC Nigel summing mixer slash 4x reamp in 1RU. the "penny compressor" one half of a modified 3630 that still kind of works modified Behringer Composer MDX2100 my main HW stereo bus compressor (pending serpent build most likely) new addition Behringer Autocom MDX1200 still needs to be modified, probably by the end of the week KT-EQP x2 (plugged in, burned in, haven't listened yet) Musician's Friend cheapo power conditioner What did you do to the MDX1200? The plan is to replace the op amps, capacitors, do some power supply bypassing, and then see if it's worth any use. If the Composer is any indication, the Autocom should clean up nicely.
Post by johneppstein on Oct 5, 2017 16:39:34 GMT -6
Also purchased an old Gibson Tube Amp - 1961 Gibson Falcon Tube Amp GA 19 RVT. Only 204 of them were ever made, and this one is almost all original, and nicely shit-hauled. See attached. Nice. The rhythm guitarist in my first band had one of those.
Post by winetree on Oct 6, 2017 15:15:24 GMT -6
Found this Fender Venus guitar on Craigslist. Never played and flawless. Owner said it hung on the wall of an antique store for a while and then he put it away. It was the last guitar he sold because the color matched his 1957 Chevy. Came with the original Fender metal badged gig bag and paper work. I paid $200.00
Post by ChaseUTB on Oct 7, 2017 9:55:50 GMT -6
Kush audio subscription
Post by subspace on Oct 8, 2017 9:45:03 GMT -6
Unfortunately I was cash poor when MCM Electronics put their pro audio stock on clearance before merging with Newark. I picked up three of their Club Series 12" monitors before they were gone, $50 each, and sixteen of the 25' XLR to TRS cables, $2.75 each. Wanted a passive monitor rig to use where it'll likely get hit with beers/rain. These came double-boxed with wrap-around foam-backed grills, fly points and a nice finish. Sensitivity is on the low side, RMS rating is double the comparable Yamaha Clubs, we'll see how that holds up in use. The two cardboard boxes behind the center wedge are actually some spare PSD2002 drivers should the answer turn out to be not well... The Neutrik knock-offs on the cables are well done, pretty happy with the lot for $200 shipped!
Post by yotonic on Oct 9, 2017 19:55:28 GMT -6
Mint 2003 Les Paul Standard Heritage Cherry Burst
Post by Guitar on Oct 9, 2017 20:01:05 GMT -6
I have built 8 Fuzz Faces by now... but it's the one in the middle, the big red one, that I just built. I spent the last few nights and afternoons on it and played it today. Very very good. Sun Face circuit from analogman with BC183 transistors as the special sauce. The Volume knob is actually more of a high pass filter than a volume in the last 25% of the turn. Very useful for sculpting the hairy heinous fuzz tone. A little low end here, a little zip here and there, a lot going on for two knobs. Four resistors, 2 transistors, 2 potentiometers, 3 capacitors and a good time, I'd say.
Post by jcoutu1 on Oct 11, 2017 14:30:47 GMT -6
