Post by NoFilterChuck on Feb 25, 2016 18:36:17 GMT -6
There used to be a thread about changing the tempo of a project, and now it's gone. someone made a comment about how to do it in Logic via Flex time and i'm trying to find it but I can't. Somethin' like set a track to Flex Time, and then set the beginning and end points for the track, then change the track tempo?
if anyone knows, can you reiterate the procedure?
Post by kcatthedog on Feb 25, 2016 19:23:08 GMT -6
That was me and Wiz, its JK first logic project thread.
But you just have to globally set flex time on and then set the new bpm. not certain why but for me sometimes Logic tells me then I have to set the tempo in the tempo map, easy enough to drag the tempo line where you want it.
This seems to work without bothering with start and end times. I have had to adjust the odd break point here and there between comps.
I just moved my project up to 98 bpm from 95 no probs
Post by M57 on Feb 25, 2016 19:55:22 GMT -6
Post by NoFilterChuck on Feb 25, 2016 20:36:48 GMT -6
