Post by tonycamphd on Jul 19, 2015 13:43:59 GMT -6
thats cool, but i believe you are misinterpreting what's being said, nobody here is stuck in the past, i would love for more new stuff to come out that's just "good" imv. But one thing will never change, the laws of physics and nature, this is inherent to the fundamentals of recording sound, so the old way is generally the only way.
Post by drbill on Jul 19, 2015 14:13:47 GMT -6
Distortion IS good.
Distortion IS bad.
Distortion IS what you make it. Good or Bad.
This back and forth cracks me up. Who doesn't dig "back in black" or a favorite EVH solo. TONS of distortion there. LOTS of distortion on classic tape based Zep recordings.
At the same time, there are some FANTASTIC direct to disc 2 track recordings from the same era that are so clean they are jaw dropingly stunning.
There's room in the world for both. No?
What's up with all the "absolutes"?? The only absolute I believe in is that there is no room for absolutes in ANY creative occupation.....
Post by mrholmes on Jul 19, 2015 15:07:15 GMT -6
thats cool, but i believe you are misinterpreting what's being said, nobody here is stuck in the past, i would love for more new stuff to come out that's just "good" imv. But one thing will never change, the laws of physics and nature, this is inherent to the fundamentals of recording sound, so the old way is generally the only way. Maybe our point of view is diffrent. Anyway I think everything is said.....
Post by EmRR on Jul 19, 2015 15:15:18 GMT -6
I seem to remember the advent of modular digital multi-tracks prompting much greater desire for comps and limiters to allow hotter recording in a 16 bit world, as well as somewhat mimic the smush of tape on drums. I gotta think if digital had actually delivered all it promised in 1985 then we might not have gotten accustomed to the band-aid effect so many wanted in 1995.
As has been said, if you have a good enough source, all these otherwise fun color boxes (pre's or comps) can seem to just get in the way, and you want the cleanest possible signal path. In my world of recording 'talent' in the styx, the color frequently masks AND enhances substandard 'talent' and equipment, soft focus if you will.
It all depends on the type of music; also been said already. The right type of music and the right ancient preamp, the preamp can be the compression without needing another, but most people don't want to go there.
Close mics on drums, bass, and vocals usually get light compression on the way in here. Most acoustic guitars too, rarely ever an electric. Usually set conservatively enough that more can be added later if desired or needed, nearly nothing to a few dB. Usually dbx/THAT RMS type with higher crest factor and less effect on transients. Rarely anything over 3:1-4:1. Sometimes (frequently) the talent plays 3 times louder on the real take, or on the 2nd song after the levels were initially set. The conservative settings mean the overload might translate into 6dB or so on any levels varying the most wildly; usually still OK unless it's a tom you were hoping to gate later.
Fitting into this logic is the awareness that the talent will likely change dynamic drastically with no warning, and no matter how often they practice or play gigs, they are still amateurs in that the concept of playing a song more than once in a row is somewhat foreign, so a good many first takes will have the best feel, subsequent takes going into the toilet in regards to energy, excitement, intimacy, and engagement. I'll probably have to do some comping from various multitrack takes, so you can't really adjust signal path settings without potentially sacrificing the ability to do that comping. At least not without pulling a lot of time consuming 'fix tricks', which I know, but are not in the budget.
A real powerhouse singer might start pushing and hit the comp 10+dB, so the comp has to be one that'll still sound ok at that level of push. Many don't. If the vocal is going to need so much, it may sound better being hit lightly multiple times than all at once.
I've done a ton of corporate event and sports press broadcast work too, which is all about manual riding of the spoken word, frequently not knowing who is going to speak out of a group of 6-10, feedback not far away. You develop a technique out of necessity, and it's hard to describe outside of noting that different people have varying speaking patterns and dynamics. You hear enough of them and see what the vocal rides are like, you start noticing the people who sound 'pre-compressed' in open air; they get on mic and you don't have to touch a thing. They just cut through with what sounds like perfect frequency response (on ANY mic) and unvarying dynamic range that can just sit at unity for a half hour in front of a crowd. Those people with those voices are the ones they used to hire for radio and TV because they were born 'pre-conditioned'. Many of the great singers fall into this category. Singers are sometimes easy to ride, but back to aforementioned talent, usually can't be looked directly at without making them overly self-conscious. They are easier to ride too when you actually get preproduction, or lyric sheets, or more than 2 takes...otherwise it's likely it's already over and under budget before you really learn the parts.
Post by b1 on Jul 19, 2015 15:20:18 GMT -6
I figured it would get to this point, which is why I avoid threads like this... There is a current absolute; being: *there is an absolute waste land in the mainstream today* - as mentioned. It seems like it has spawned from relying on the wrong equipment to fix a poor performance or mix. Then that's taken as a nod to open a flood gate for the guys who think they've found a magic bullet for the paycheck. A time is money, everyone's doing it, it will sell, type of thing. So the feet prop up on the console and everyone starts playing along at home. I hear a lot of nice songs, and the real mix in the background of the smear. It could have been so much better Leaving out AC-DC, EVH, & Zeppelin, I figure there are more older recordings/mixes which are better overall, and more of the newer ones being worse overall - in all genres and medium. I gave a 80-90% number for the unlistenable material today, as I see it. With the mention of "generations", a new crop of engineers are ruining people's taste for music, in general. Again, in general, people will have to take what's given them. Most don't know the difference between the good or bad use of equipment in practice, but it still translates as a fatiguing mess after awhile of listening. AC-DC, EVH, & Zeppelin are what they are and did what they did; as well as those who engineered it. We can learn from some of those things - good & bad, though we don't have to be those things every time the lights go on and the switches are flipped. Though not a fan of the first two, I don't wish away what they did. I don't buy into the droning on of the first one, but dig short vibes from it before I'm ready to move on. I think Zeppelin sounded better in recorded performances. I'm glad the albums are there, because the writing, arranging, and mixing genius of it outperforms any negative aspect. I don't see a crossroads on the horizon, at this point, until people start learning about the art of it all. It's more of an A, B, C process taken from someone else's book that should have been a chapter in the pages of history, and not the end all conclusion. But no doubt, it's wildfire. ![:)](//storage.proboards.com/forum/images/smiley/smiley.png) AsISeeIt...
Post by Bob Olhsson on Jul 19, 2015 15:43:12 GMT -6
I don't think there is a lack of talent but I do think there is a serious lack of stage experience and attention paid to the sound of instruments and "touch" compared with the '60s and '70s. Technology has made developing super chops less necessary. I also think the lack of paying work for musicians relative to the past has kept a lot of very talented people from taking a music career seriously. When I started my career in the mid '60s most of us were under 20-25 years old!
Post by mrholmes on Jul 19, 2015 16:13:12 GMT -6
Bob I just wanted to say if someone creats something creative, in his fucked up bed room studio, I will pay attention to it. And if it sounds good I dont care if he or she broke all rules of the high art of recording.
Do you had similar discussions when synth pop became popular?
Post by EmRR on Jul 19, 2015 16:24:28 GMT -6
25 is now about the age you might be expected to leave an internship....maybe.....
Post by EmRR on Jul 19, 2015 16:25:15 GMT -6
synth pop always made me want to kill myself.....
Post by Bob Olhsson on Jul 19, 2015 21:17:07 GMT -6
I don't worry that much about rules but I prefer honest music making to clichés. I've done a lot of work with really abstract electronic music that sounds like what it is but would much rather hear a funky upright piano than piano samples.
Post by EmRR on Jul 20, 2015 8:15:08 GMT -6
Oh man, the piano. My Kimball upright virtually always wins over any sample, but it's hard to convince people to use it at times.
Post by mrholmes on Jul 20, 2015 9:12:47 GMT -6
synth pop always made me want to kill myself..... but you are still alive ... what went wrong ![:)](//storage.proboards.com/forum/images/smiley/smiley.png)
Post by jimwilliams on Jul 20, 2015 9:26:36 GMT -6
When the 3M digital multitrack first came to Wonderland, it changed the way stuff was tracked. Nate Watt's P-bass was now cut flat, no EQ, no compression. The large dynamic range allowed Gary O to EQ and compress during mixdown.
Post by swurveman on Jul 20, 2015 12:07:52 GMT -6
After reading this thread, I think there's a dissonance between compression and fader riding, which are not mutually exclusive. So, I give you (a) a quote from Michael Brauer, (b) one of his typical routing methods, and a song he mixed to ponder. He's a master imo, because he has a flexible approach to compression. It's not a hammer, unless he wants it to be. It's a feather if he wants it to be, or not. It's not good or bad. It's a tool among all his other tools. Quote: "Use movement. I move faders a lot. There has to be movement. I don’t know quite how you do movement with a little mouse, but I didn’t grow up with a mouse. A lot of people have D-Commands with faders. How you do it, I don’t care. What I care about is that there’s movement in the song. Don’t compress one sound and leave it that way for the entire record, because bands don’t do that onstage — they move around. So make the mix move. Listen to most of my mixes: They’re rarely static." -Michael Brauer ![](http://i380.photobucket.com/albums/oo249/Domer81/Brauerize.png~original)
Post by Deleted on Jul 20, 2015 13:53:12 GMT -6
synth pop always made me want to kill myself..... This is very funny in an evil way. LOL. But exactly how i remember the times when it came up. Not talking about musical quality. Actually, and i an not ashamed of it, i had a Depeche Mode album that got quite some play. And i was a heavy rocker that time. Well, one with suicidal tendencies....
Post by Deleted on Jul 20, 2015 14:04:08 GMT -6
This is an incredibly informative thread. Many different views on the topic, and even more fascinating, quite great variety of philosophies, tips, strategies and approaches in a very condensed form. Thanks alot, guys!
Post by mrholmes on Jul 21, 2015 3:31:54 GMT -6
Am I stupid or isn't that a good way to run into phase problems???
Post by EmRR on Jul 21, 2015 8:01:19 GMT -6
You'd get the phase differences which reflect differences in frequency response between various parallel elements, but that's all. Minimal.
Post by Guitar on Jul 21, 2015 20:26:39 GMT -6
I think it's funny how discussion threads get after 5+ pages, there is a certain kind of entropy in effect. So I'll just cast my stone in the well...
Great thread, great wisdom and opposite views.
I love how the 1176 got mentioned as a rock and roll drum compressor, I think it's just perfect for that. And yes, it's a sound just as much as anything, as much as a dynamics control or whatever. Makes a great peak limiter too at high ratios. Oops I've only used plugin versions to date. But when I think of the 1176 sound, it evokes a certain mystique in my mind, not as a tool, but as a specific sonic characteristic. This is true for a lot of compressors and limiters. Sometimes it's, "I need a compressor," and other times, "what specific compressor do I want to hear."
I agree with those who said it's best to apply compression in stages. Maybe tracking, individual tracks, possibly busses, then the mix buss, then the master. It feels a little strange to clamp down the limiter on naked acoustic tracks, and go to -20 dB or however far. When the tracks are all pumping the right way you barely need the limiter at all, it goes too far very quickly. It's nice to build it up in stages to the final product.
It also seems that different styles require completely different mix treatments. And compression is one of the biggest differences between them. It almost seems to define certain styles and eras, which may account for some of the different advice given here. Yes I am referring to mastering dynamics as well. And the best players and groups do seem to have a masterful control of their own dynamics in the room, or to tape, so you can just back off and preserve the natural sound. But there is other music that wants to be blunt or immediate in a certain way, or maybe just smoothed over.
In electronic music you've got the filter. In rock and roll, it's the compressor. It's like one knob with all the attitude. Something to push against. It's about vibe and excitement and volume. Or sometimes just control. When it wears me out I'll just pull up some classical music and go to a totally different place. I certainly don't believe in wrong and right, or absolutes. In fact I enjoy the variety. There has been so much great music in the history of recording and it's all over the place. I think it's something to cherish, not a place for contention. Viva compression.
Post by Ward on Jul 21, 2015 20:44:59 GMT -6
I love 1176s for all sorts of things. Drum overheads, room mics, snare drums, acoustic guitars, accordions, mandolins... and I'm a hard rock/country kind of guy! I also love what a Rev D does to a well placed pair of LDCs on a grand piano... just kissing the attack to bring out the transients for that "hard piano" sound.
