Post by matt on May 18, 2015 20:58:56 GMT -6
I'm not satisfied with what I have for "mains", but here they are:
Dynaudio BM5A x2 Dynaudio BM9S x2
I want to go with something else, but I'm baffled on what to choose. So I'd like to hear from all you RGO-types: what have you got, and what you like and/or dislike about them. Any other details you'd like to share, such as room size and treatment method, would be appreciated.
Post by jeromemason on May 18, 2015 21:00:31 GMT -6
Modded Yamaha HS80m's and a pair of 3-way KRK 10-3's.
Post by ericn on May 18, 2015 21:02:35 GMT -6
House of Quested 308s powered by Bryston 4B F11as
Post by wiz on May 18, 2015 21:06:05 GMT -6
ADAM A7s
Post by Martin John Butler on May 18, 2015 21:11:29 GMT -6
Had Yamaha's, had Adam A7X, sold them two months ago for the Avantone Abbey, and I'm really glad I did.
Post by popmann on May 18, 2015 21:18:22 GMT -6
You will pry my Mackie 624s from cold dead hands.
I have never worked on monitors that translate better. Ever. Anyone who thinks they're "cheaper 824s" is missing it....completely different design--the 824s do not translate as well, IME.
Post by aremos on May 18, 2015 21:25:55 GMT -6
Genelec 1031A's Yamaha NS-10M's
(no longer use my UREI 809's)
Post by aremos on May 18, 2015 21:26:07 GMT -6
Post by gouge on May 18, 2015 21:40:48 GMT -6
B&W matrix 805 with hafler amp cheap pair of small stereo shelf speakers on art sl1
the old krk 7000b still sitting in the room.
Post by formatcyes on May 18, 2015 21:43:38 GMT -6
Event 2030's and a behritone
Post by svart on May 18, 2015 21:43:55 GMT -6
JBL LSR4328P with matching sub NS-10 Auratone 5s
Post by lolo on May 18, 2015 21:48:52 GMT -6
Neumann KH120's. Really like them
Post by Johnkenn on May 18, 2015 22:16:40 GMT -6
Pro Ac Studio 100's with sub
Post by carymiller on May 18, 2015 22:22:49 GMT -6
I use the following:
PSI-A21-M's (Main Near-fields) I also love Equator Q10's, but they're too large for my current setup. Equator D5's (Instead of Yamaha NS10's I strongly prefer D5's; prior to my D5's I used ADAM A7's which I also prefer to NS10's) Vintage ROR A's (Kind of like Auratone's on Steroids, but extremely hard to find. I've been looking for someone to team up with to clone mine and bring them back.)
I use an ADAM SUB 8 (mainly because it has that handy remote.)
And I use a Drawmer MC2.1 Monitor controller currently.
Post by jeromemason on May 18, 2015 23:27:06 GMT -6
I use the following: PSI-A21-M's (Main Near-fields) I also love Equator Q10's, but they're too large for my current setup. Equator D5's (Instead of Yamaha NS10's I strongly prefer D5's; prior to my D5's I used ADAM A7's which I also prefer to NS10's) Vintage ROR A's (Kind of like Auratone's on Steroids, but extremely hard to find. I've been looking for someone to team up with to clone mine and bring them back.) I use an ADAM SUB 8 (mainly because it has that handy remote.) And I use a Drawmer MC2.1 Monitor controller currently. PSI's are some of the most precise monitors I've ever had, they were too technical for me, I found I needed something more "broaband" to mix on if that makes sense. Best way I could describe them was it was like an EQ, a very good one that you could use to notch and find little things, but not so broad. I remember being able to hear all sorts of things on those monitors you couldn't hear on other speakers, I mean like any other speakers. That got me to thinking though, if they really don't fit my ears and you can't hear what they reveal on pretty much any other speaker, can I justify the expense. Definitely a monitor for certain people. The transient response of them is what I miss about them, they had the transient response of NS10's but still gave you accurate and a good amount of low-end. And hit me up on cloning your speakers.... I might be able to help.
Post by levon on May 18, 2015 23:37:05 GMT -6
Adam A77X and Auratones. Very happy with the combination. But, due to my deteriorating hearing, I spend a lot more time with headphones. I have recently discovered the Sonarworks Reference plugin, that gives headphones a flat frequency curve. I'm still evaluating it, but it seems to work very good, could be an ideal solution for headphones mixing. Back on topic...
Post by carymiller on May 19, 2015 0:34:58 GMT -6
I use the following: PSI-A21-M's (Main Near-fields) I also love Equator Q10's, but they're too large for my current setup. Equator D5's (Instead of Yamaha NS10's I strongly prefer D5's; prior to my D5's I used ADAM A7's which I also prefer to NS10's) Vintage ROR A's (Kind of like Auratone's on Steroids, but extremely hard to find. I've been looking for someone to team up with to clone mine and bring them back.) I use an ADAM SUB 8 (mainly because it has that handy remote.) And I use a Drawmer MC2.1 Monitor controller currently. PSI's are some of the most precise monitors I've ever had, they were too technical for me, I found I needed something more "broaband" to mix on if that makes sense. Best way I could describe them was it was like an EQ, a very good one that you could use to notch and find little things, but not so broad. I remember being able to hear all sorts of things on those monitors you couldn't hear on other speakers, I mean like any other speakers. That got me to thinking though, if they really don't fit my ears and you can't hear what they reveal on pretty much any other speaker, can I justify the expense. Definitely a monitor for certain people. The transient response of them is what I miss about them, they had the transient response of NS10's but still gave you accurate and a good amount of low-end. And hit me up on cloning your speakers.... I might be able to help. I mainly mix on the Equator D5's with the ADAM Sub 8 inline. I check my mixes for Cell Phone/Computer Speaker/Flat Screen TV/Laptop Speaker balance on the ROR's because they do that sort of narrow bandwidth the Auratones/Avantones do only much, much better and more articulately. And I check for mistakes, pops, clicks, plosives, reverb and delay tale problems...pumping....phasing, etc. on the PSI's. They're my magnifying glass to make sure I didn't miss something. But 90% of the time I'm on those those cheap ass Equators on the 3rd switch setting (which has the biggest bass response.) And usually I'm monitoring at very low volumes. I feel you on the PSI's...I can't listen to everything on them for too long...it'll drive a man nuts. But I can't seem to work out a faster workflow when it comes to double checking things for stuff that sticks out. I hate mixing on anything bigger than nearfields, and when I go to master I swap to the PSI's...they're just more accurate for that...almost as good as much more expensive monitoring rigs for the job. I use the ROR's during mastering too, but as a reference monitor prior to swapping to cell phones and car speakers. I'll message you sometime tomorrow (I'm heading to bed now...) but if you want to talk shop about cloning my old ROR's I'd love to swap numbers and chat about them. They're something truly special but I spent six years hunting down my pair. =/
Post by Calvin on May 19, 2015 0:46:07 GMT -6
JBL LSR28p here. Like them a lot.
Post by mdmitch2 on May 19, 2015 1:58:57 GMT -6
Love my PSI a21-m's --- blew away everything else I demoed, and very easy on the ears from a fatigue standpoint. As others have said, they're extremely revealing, so I guess you could get lost in details, but I don't find that to be an issue. For me, they are far easier to work on and translate much better than the Rocks, KH120's, and Equator D8's that I compared to. Of those three, the Rocks were the clear standout, but my ears didn't really get along with the ribbon tweeters.
Post by odyssey76 on May 19, 2015 3:42:24 GMT -6
Adam A7X's, Behritones and Sennheiser HD280's
Post by stratboy on May 19, 2015 5:22:18 GMT -6
Pelonis Model 42s with a Tannoy TS-8 sub. KEF Q-10s. Vintage Auratones I bought new in the 70s. I find myself mixing mostly on the 42s at low volume in mono. I do a lot of checking with the sub, KEFs, Auratones and headphones. The 42s are really thick in the mids, with lots of detail. They are about 30 inches away. Works really well.
Post by warrenfirehouse on May 19, 2015 6:15:05 GMT -6
Focal alpha 65's with a krk sub on a switch
Post by ragan on May 19, 2015 6:26:37 GMT -6
Good ol Dynaudio BM5a MKII's here.
Post by tonycamphd on May 19, 2015 7:00:19 GMT -6
the dreaded HR824's, i have a pair of ProAc100 knockoffs about 1/3 the way built...
Post by cowboycoalminer on May 19, 2015 7:22:58 GMT -6
JBL 4328's
