Post by henge on Jan 10, 2016 10:34:21 GMT -6
Well this looks killer!!
Post by dandeurloo on Jan 10, 2016 10:40:41 GMT -6
Post by drbill on Jan 10, 2016 15:11:10 GMT -6
Dan - I'll use that as my screen saver too if you tell me when mine is showing up. LOL
Post by RicFoxx on Jan 10, 2016 16:18:47 GMT -6
Website is solid Dan...simple and elegant.
I haven't thought about running out of DAW to the ZOD...pretty cool. For a killer rock tone I like to run it into the CAPI VP28 into the FC 526 or Splice and dial in an aggressive very fat bass tone. I compared it to the Dizengoff D4 and though I think the D4 is very good the ZOD is just awesome. Direct Tele into the same chain and add the LA2A to the end of that chain and it sounds like I mic'ed an amp. The thing is also built like a tank...USPS killed the package literally lost it for 2-3weeks and when it arrived it was beat up so bad that the peanut packing was shredded into tiny pieces but the ZOD worked! Dan has built me the LA2A Clone and the MK-47 and it is all a very clean build.
Post by tonycamphd on Jan 10, 2016 16:39:50 GMT -6
Ask and you shall receive.... Here is my true 1972 Jazz bass through Dan's Zod into a vp28 hard, and through fc526 no compression, I'm using Scott Liebers red dots in the receiver position, and his new 1731's in the output positions, just awesome sounding all the way around! Also using a AD4898 in the side chain pre of the 526, the compressor isn't doing anything, just running through the circuit for a little vibe, i'll do some compressing on some stuff and post it as well, I want to add more files now, but i'm not digging the brand new strings and the buzz that's going with them, so some adjustment is in order.... Stay tuned.... https%3A//soundcloud.com/tonycamp/kneel-before-zod
Post by tonycamphd on Jan 10, 2016 20:10:40 GMT -6
I was getting a little frustrated with the buzzes on my new strung bass, so I started loddy dahh, thumb slapping, i'm not so good at that, but the Zod and Fc526 set to 12:1 fast att/rel, made for a fun sound, so i did it for a bit and then tracked this snippet, the Zod really does make an amp totally less necessary IMO, it's dang fat and punchy, the sample below with a complimentary kick drum sound would just pound a record, and i can't believe how noise free it is for having a tube in it! even when you drive it hard, Dan really thought this thing out, it's beyond just a DI imo, it's more like a pre preamp kinda.
https%3A//soundcloud.com/tonycamp/freddies-dead-2
Post by wiz on Jan 10, 2016 21:04:07 GMT -6
sounds cool
how much?
Post by tasteliketape on Jan 10, 2016 21:21:48 GMT -6
599.00 on his web site same as a used Reddi Dans post5th above yours is the link to Dans website
Post by wiz on Jan 10, 2016 21:29:43 GMT -6
Checked the website... Gonna do a 240v 50 Hz version @danderlou?
That would be cool
Cheers
Post by wiz on Jan 10, 2016 21:30:51 GMT -6
Checked the website... Gonna do a 240v 50 Hz version dandeurloo ? That would be cool Cheers Wiz
Post by henge on Jan 10, 2016 21:36:48 GMT -6
Ask and you shall receive.... Here is my true 1972 Jazz bass through Dan's Zod into a vp28 hard, and through fc526 no compression, I'm using Scott Liebers red dots in the receiver position, and his new 1731's in the output positions, just awesome sounding all the way around! Also using a AD4898 in the side chain pre of the 526, the compressor isn't doing anything, just running through the circuit for a little vibe, i'll do some compressing on some stuff and post it as well, I want to add more files now, but i'm not digging the brand new strings and the buzz that's going with them, so some adjustment is in order.... Stay tuned.... https%3A//soundcloud.com/tonycamp/kneel-before-zodSounds great man! What was the pickup combo you were using. I usually have the neck full on and the bridge backed off a bit or vice versa.
Post by dandeurloo on Jan 10, 2016 21:37:28 GMT -6
I'm pretty sure I can wire the PSU transformer for 240v.
Post by Martin John Butler on Jan 10, 2016 22:04:01 GMT -6
Sounds very full and clean, I like it. Good luck with this Dan.
Post by tonycamphd on Jan 10, 2016 22:05:49 GMT -6
Ask and you shall receive.... Here is my true 1972 Jazz bass through Dan's Zod into a vp28 hard, and through fc526 no compression, I'm using Scott Liebers red dots in the receiver position, and his new 1731's in the output positions, just awesome sounding all the way around! Also using a AD4898 in the side chain pre of the 526, the compressor isn't doing anything, just running through the circuit for a little vibe, i'll do some compressing on some stuff and post it as well, I want to add more files now, but i'm not digging the brand new strings and the buzz that's going with them, so some adjustment is in order.... Stay tuned.... https%3A//soundcloud.com/tonycamp/kneel-before-zodSounds great man! What was the pickup combo you were using. I usually have the neck full on and the bridge backed off a bit or vice versa. Hey Anton, original pups, just set wide open, picking over the neck pup, the Zod really adds some mojo juice to my totally lucky to have jazz bass, it makes it hard to put down, I'll put up some more samples with another DI for comparison in a bit, I'll also put up a couple with the neck pup backed off slightly, while finger picking over the bridge pup, really gets that growly pseudo tuba/fretless Jaco thing going.
Post by noah shain on Jan 10, 2016 22:38:41 GMT -6
I've used the ZOD a lot at this point. I'll relate my experience anecdotally.
Doing a rock album to tape on the Ampex 16, semi-retroish vibe and we're getting decent takes every one is happy. About 10 days in I decide we need to re-cut a couple tracks. Dan sends me the ZOD to check out at the same time we gonna re-cut tracks. I put the ZOD on the bass. So the chain is ZOD, modified 1608 channel with EA transformers and SL red dots, Overstayer MAS, Retro 176...I think that's right. We proceed to re-cut 9 out of 11 songs because the bass sounds so good that everyone is super stoked on the way the tracks are gelling. We decided to change some snares and blah blah too but it was the ZOD. Pretty god damned good sounding DI. My gear budget is way way way in the red this year so I couldn't buy it. But I will the MOMENT the console is wrapped and the wife frees up some green.
I can't post samples but the album will be out this spring/summer. Single may come out soon. I'll post a link when I can.
Edit: it's a 70s Rick
Post by tasteliketape on Jan 10, 2016 22:57:08 GMT -6
I'm going to have one someway I'm starting to round up stuff to sell My main 3 purchase this year will be Zod , Zulu, pueblo audio pre
Post by henge on Jan 11, 2016 8:50:02 GMT -6
I'm going to try to pick one up. The Canadian dollar is shit right now so it just doesn't make sense to get one now. One day a Zod WILL BE MINE!!
Post by Johnkenn on Jan 11, 2016 22:37:32 GMT -6
Yeah - that sounds fantastic. Damnit, GAS...I really need to purchase a better bass. All I've got right now is the Classic Vibe P-Bass. Not bad actually...maybe I should just drop some different PU's in.
Post by Johnkenn on Jan 11, 2016 22:39:31 GMT -6
I'm going to have one someway I'm starting to round up stuff to sell My main 3 purchase this year will be Zod , Zulu, pueblo audio pre That's a good list.
Post by jcoutu1 on Jan 14, 2016 10:28:41 GMT -6
Ask and you shall receive.... Here is my true 1972 Jazz bass through Dan's Zod into a vp28 hard, and through fc526 no compression, I'm using Scott Liebers red dots in the receiver position, and his new 1731's in the output positions, just awesome sounding all the way around! Also using a AD4898 in the side chain pre of the 526, the compressor isn't doing anything, just running through the circuit for a little vibe, i'll do some compressing on some stuff and post it as well, I want to add more files now, but i'm not digging the brand new strings and the buzz that's going with them, so some adjustment is in order.... Stay tuned.... https%3A//soundcloud.com/tonycamp/kneel-before-zodI'd like to hear your jazz into a shitty, cheap, passive DI (Whirlwind IMP 2?) into the VP28 and FC526 for comparison.
Post by tonycamphd on Jan 14, 2016 12:02:31 GMT -6
Ask and you shall receive.... Here is my true 1972 Jazz bass through Dan's Zod into a vp28 hard, and through fc526 no compression, I'm using Scott Liebers red dots in the receiver position, and his new 1731's in the output positions, just awesome sounding all the way around! Also using a AD4898 in the side chain pre of the 526, the compressor isn't doing anything, just running through the circuit for a little vibe, i'll do some compressing on some stuff and post it as well, I want to add more files now, but i'm not digging the brand new strings and the buzz that's going with them, so some adjustment is in order.... Stay tuned.... https%3A//soundcloud.com/tonycamp/kneel-before-zodI'd like to hear your jazz into a shitty, cheap, passive DI (Whirlwind IMP 2?) into the VP28 and FC526 for comparison. well, i'm planning on it, but i don't have a shitty, cheap passive di, I sold all my other di's when i built the bo hansen's, they killed the other stuff, but then the Zod knocked that down from top of the heap with a thud , so i only have a pair of active and not shitty bo hansen's haha, but i will figure something out, the bass is super dope, but i can tell you there is no doubt the Zod takes its greatness to a different level.
Post by jcoutu1 on Jan 14, 2016 12:16:23 GMT -6
I'd like to hear your jazz into a shitty, cheap, passive DI (Whirlwind IMP 2?) into the VP28 and FC526 for comparison. well, i'm planning on it, but i don't have a shitty, cheap passive di, I sold all my other di's when i built the bo hansen's, they killed the other stuff, but then the Zod knocked that down from top of the heap with a thud , so i only have a pair of active and not shitty bo hansen's haha, but i will figure something out, the bass is super dope, but i can tell you there is no doubt the Zod takes its greatness to a different level. Use the Bo Hansen then. That can't be hugely different from any other passive DI and SHOULD be hugely different from the ZOD.
Post by ericn on Jan 14, 2016 12:20:32 GMT -6
I'd like to hear your jazz into a shitty, cheap, passive DI (Whirlwind IMP 2?) into the VP28 and FC526 for comparison. well, i'm planning on it, but i don't have a shitty, cheap passive di, I sold all my other di's when i built the bo hansen's, they killed the other stuff, but then the Zod knocked that down from top of the heap with a thud , so i only have a pair of active and not shitty bo hansen's haha, but i will figure something out, the bass is super dope, but i can tell you there is no doubt the Zod takes its greatness to a different level. Cheap passive DI know that is the one thing I know every GC has in stock, you will find it next to the DJ lights!
Post by tonycamphd on Jan 14, 2016 12:44:44 GMT -6
well, i'm planning on it, but i don't have a shitty, cheap passive di, I sold all my other di's when i built the bo hansen's, they killed the other stuff, but then the Zod knocked that down from top of the heap with a thud , so i only have a pair of active and not shitty bo hansen's haha, but i will figure something out, the bass is super dope, but i can tell you there is no doubt the Zod takes its greatness to a different level. Use the Bo Hansen then. That can't be hugely different from any other passive DI and SHOULD be hugely different from the ZOD. my bo hansen's killed my radial... so? but i will do a mult and get it done pretty soon, i'm working on some other obligations that are beyond due as of right now.
Post by Guitar on Jan 18, 2016 9:42:01 GMT -6
Wow, sounds great, I'm impressed!
