Post by christopher on Apr 30, 2020 11:33:00 GMT -6
Hi and welcome! I would say you can rule out the non-stock items, and rule out the wrong packaging (surface mount vs socketed with legs). I always go with the most in-stock item. I assume they are all the same chip just different numbers for manufacturer bulk ordering reasons? I don't own these monitors, so maybe someone else can let you know exact number.
Post by ericn on May 1, 2020 10:06:08 GMT -6
Hi Sirs, Which OPA2134 should i order ? Just did the limiter bypass yesterday and it gave such wonderful result. I came up on Mouser and there are like 8 types of OPA2134 to choose from ? A recommendation is highly appreciated. I live in Vietnam so sending my pair to Zenpro is not a good option so I decided to seek for alternatives to mod my HS8 monitors. Im also seeking for a complete part lists for the mod but seems like it is impossible so. Any help would be awesome. Thank you so much. Welcome! Your best bet is to dive deep in the manufactures data sheets and figure out what you need. Covid-19 time is perfect for this, plus there is no greater cure for insomnia than a chip manufacturers data sheet!
