Post by lowlou on Nov 25, 2023 13:29:29 GMT -6
Im curious to know which build is the most effective. I'd be interested in building some (many ?), but I want to build the most effective and cost-efficient design ^^'... Not knowing a thing about acoustic isn't helping.
Post by lowlou on Nov 25, 2023 13:46:51 GMT -6
I wish somebody opened their ASC tubetraps and took pictures. But at 1K+ a piece, nobody ever will. They are too pricey. I wanted to buy tubetraps, but no it's just too expensive, sorry ASC !
Post by kcatthedog on Nov 25, 2023 14:45:34 GMT -6
Thx for the detail.
I’ve been thinking about using the sonotubes and using radial cutters ti cut diffrebt sized circular holes in one side of the tube: like you reflective on the other side.
I would cut circular pieces of safe and sound ti stuff inside, cap bottom and top with circular pieces of semi rigid comfort board.
Eric’s analysis suggests capping does little sonically, but would keep insulation in place. i’d make a circular wooden base, a little bigger with a routered counter sunk groove fir tube ti sit in, likely use construction glue there and attach 3 wheels, cover with fabric!
Post by kcatthedog on Nov 25, 2023 14:47:47 GMT -6
Im curious to know which build is the most effective. I'd be interested in building some (many ?), but I want to build the most effective and cost-efficient design ^^'... Not knowing a thing about acoustic isn't helping. Build prototypes and use REW to measure then you’ll know, but eric’s video shiwed his improvement and how he tested for tuning.
Post by rowmat on Nov 25, 2023 16:28:03 GMT -6
Thx for the detail. I’ve been thinking about using the sonotubes and using radial cutters ti cut diffrebt sized circular holes in one side of the tube: like you reflective on the other side. I would cut circular pieces of safe and sound ti stuff inside, cap bottom and top with circular pieces of semi rigid comfort board. Eric’s analysis suggests capping does little sonically, but would keep insulation in place. i’d make a circular wooden base, a little bigger with a routered counter sunk groove fir tube ti sit in, likely use construction glue there and attach 3 wheels, cover with fabric! In order to reduce bass buildup which occurs at the perimeter of walls and in corners the tube traps do require ‘sealing’. By ‘sealing’ I mean they need to provide some resistance to the flow of air through the wall of the trap into the internal air cavity during the positive half cycle (high pressure) and then back out of the tube into the room during the negative half cycle (low pressure). This action is what effectively absorbs the acoustic energy and levels out the bass response. The bigger the air volume of the tube, the lower the frequency it can treat. If you want the traps to be effective especially at lower frequencies they shouldn’t be completely open but rather provide ‘leaky’ resistance to the flow of air in and out of the tube. The trap acts like a smoothing capacitor in an AC to DC power supply. During the positive half cycle where the pressure inside the trap momentarily rises as air moves through the wall of the tube absorbing the positive energy it then, during the negative half cycle when the air in the trap is at higher relative pressure compared to the air in the room adjacent to the trap, moves back through the wall of the tube into the room. Of course you need enough traps of suitable size to be effective in smoothing out the low frequencies. A couple of small traps won’t make much difference in treating the low end.
Post by kcatthedog on Nov 25, 2023 16:59:41 GMT -6
Post by kcatthedog on Nov 25, 2023 17:01:01 GMT -6
Makes sense to me thx.
It was interesting in Eric’s test little difference, but I would lean towards sealing them!
Post by rowmat on Nov 25, 2023 17:08:30 GMT -6
Makes sense to me thx. It was interesting in Eric’s test little difference, but I would lean towards sealing them! To be clear you need quite a number large tube traps to effectively treat the low end. And I am specifically referring to the low end here. Unsealed tubes can indeed improve the acoustics of the middle and higher frequencies but not nearly as much at the low end. Measuring the room low end response between sealed and unsealed traps won’t make a lot of difference unless you have enough traps of suitable size in the first place. And typically most don’t have enough. (My large tube traps are 8” taller than me) By that I mean a pretty large budget that few home studio owners could likely afford or have the time and energy to DIY build unless they were very motivated.
Post by ericn on Nov 27, 2023 16:08:36 GMT -6
Post by Tbone81 on Nov 27, 2023 16:16:14 GMT -6
I wish somebody opened their ASC tubetraps and took pictures. But at 1K+ a piece, nobody ever will. They are too pricey. I wanted to buy tubetraps, but no it's just too expensive, sorry ASC ! Check out GIK's new tube traps. They look to be a variation on the design, but they're lab tested and GIK as a great reputation. Still pretty spendy but more affordable than ASC!
Post by ericn on Nov 27, 2023 16:18:42 GMT -6
Post by drbill on Nov 27, 2023 16:40:06 GMT -6
I wish somebody opened their ASC tubetraps and took pictures. But at 1K+ a piece, nobody ever will. They are too pricey. I wanted to buy tubetraps, but no it's just too expensive, sorry ASC ! Check out GIK's new tube traps. They look to be a variation on the design, but they're lab tested and GIK as a great reputation. Still pretty spendy but more affordable than ASC! Got a Link? I couldn't find them on their website - oops. Nevermind. . Found it : www.gikacoustics.com/product/turbo-trap/
Post by lowlou on Nov 28, 2023 1:20:06 GMT -6
The Gik Turbotrap price is attractive, almost too attractive. We don't know what's happening inside the Turbo traps. From their look, I guess there is a wire mesh just underneath the fabric. I suspect it's a lesser design compared to ASC isoThermal design. I'd like to be wrong. Also, the GIK turbotrap "range" is very minimal compared to ASC. One size only. Well at least it exists and is readily available in Europe.
Post by Quint on Nov 28, 2023 9:55:53 GMT -6
While I framed in a control room I had a giant stack of R13 rolls piled in the back of the room that would be used to fill in the framing. I arranged them in a semi-circle behind where I was experimenting with speaker placement and it sounded amazing in the listening position. Finished out the room and it didn't really compare to the open space with that wall of R13 rolls behind it. "Behind", as in you were facing the insulation and monitors at the same time? Similar to how an attack wall would be placed behind monitors?
Post by Quint on Nov 28, 2023 10:10:31 GMT -6
I know it's not tube traps, but I have an 8ft x 8ft x 2ft bass trap immediately behind my monitors (the monitors almost touch the bass trap), made out of pink fluffy type insulation (R19, if I remember correctly). It made a pretty noticeable difference (at all frequencies) when I installed it.
I only bring this up to say that I think any sort of sufficiently substantial (and properly implemented) treatment, whether it be a more traditional pink fluffy bass absorber or tube traps, really can help. I've never used tube traps, but had considered them before I built my bass trap. In any case, I have no reason to believe that these tube traps, if used in sufficient quantity, and in an attack wall type placement, aren't doing a great job of improving sound at the listening position. There's too many people having success with these tube traps for it to be a fluke, it would seem.
I still might DIY some tube traps one of those days, to use as mobile treatment around various instruments to tame reflections getting into mics.
Post by Tbone81 on Nov 28, 2023 11:38:49 GMT -6
The Gik Turbotrap price is attractive, almost too attractive. We don't know what's happening inside the Turbo traps. From their look, I guess there is a wire mesh just underneath the fabric. I suspect it's a lesser design compared to ASC isoThermal design. I'd like to be wrong. Also, the GIK turbotrap "range" is very minimal compared to ASC. One size only. Well at least it exists and is readily available in Europe. They're for sure not the same exact product, but I’m guessing they perform similar. The one big difference I see is they don’t have any built in diffusion like the ASC
Post by Tbone81 on Nov 28, 2023 11:42:25 GMT -6
I know it's not tube traps, but I have an 8ft x 8ft x 2ft bass trap immediately behind my monitors (the monitors almost touch the bass trap), made out of pink fluffy type insulation (R19, if I remember correctly). It made a pretty noticeable difference (at all frequencies) when I installed it. I only bring this up to say that I think any sort of sufficiently substantial (and properly implemented) treatment, whether it be a more traditional pink fluffy bass absorber or tube traps, really can help. I've never used tube traps, but had considered them before I built my bass trap. In any case, I have no reason to believe that these tube traps, if used in sufficient quantity, and in an attack wall type placement, aren't doing a great job of improving sound at the listening position. There's too many people having success with these tube traps for it to be a fluke, it would seem. I still might DIY some tube traps one of those days, to use as mobile treatment around various instruments to tame reflections getting into mics. I often wonder how much of the effectiveness of the Attack Wall is just that you have a ton of bass traps, with thick insulation, surrounding you. The cylinder shape provides an air gap that, I’m guessing, increases the effectiveness at lower freq too. Not surprised at all that you your DIY traps made a big difference. But also, just like you, I figure too many great AE’s swear by the ASC tube traps, so I have to believe they’re legit.
Post by Quint on Nov 28, 2023 12:13:55 GMT -6
I know it's not tube traps, but I have an 8ft x 8ft x 2ft bass trap immediately behind my monitors (the monitors almost touch the bass trap), made out of pink fluffy type insulation (R19, if I remember correctly). It made a pretty noticeable difference (at all frequencies) when I installed it. I only bring this up to say that I think any sort of sufficiently substantial (and properly implemented) treatment, whether it be a more traditional pink fluffy bass absorber or tube traps, really can help. I've never used tube traps, but had considered them before I built my bass trap. In any case, I have no reason to believe that these tube traps, if used in sufficient quantity, and in an attack wall type placement, aren't doing a great job of improving sound at the listening position. There's too many people having success with these tube traps for it to be a fluke, it would seem. I still might DIY some tube traps one of those days, to use as mobile treatment around various instruments to tame reflections getting into mics. I often wonder how much of the effectiveness of the Attack Wall is just that you have a ton of bass traps, with thick insulation, surrounding you. The cylinder shape provides an air gap that, I’m guessing, increases the effectiveness at lower freq too. Not surprised at all that you your DIY traps made a big difference. But also, just like you, I figure too many great AE’s swear by the ASC tube traps, so I have to believe they’re legit. Yeah, I don't fully understand how tube traps work, and there seems to be some degree of voodoo surrounding them. People get in arguments over how they work and what they actually do. So they're kind of weird in that way. Whereas people generally agree on how a porous absorber bass trap works. Nevertheless, if people like Jeff Hedback are even spec'ing tube traps on some of their projects, I've gotta trust that. They just seem to work.
Post by tkaitkai on Nov 28, 2023 12:21:07 GMT -6
Thomann also have a super cheap tube trap design: www.thomannmusic.com/t.akustik_tube_trap_bk.htmIf you poke around old threads on GS and PSW, Art Noxon (founder of ASC) would occasionally show up and dump tons of info about how ASC tube traps work. Lot of very high-level stuff that goes way over my head, but he seemed pretty transparent about how they’re designed, and I think he even provided a bunch of tips on how to do a DIY build. I definitely wanted to try DIY at one point, but eventually said fuck it and just went with ASC.
Post by Tbone81 on Nov 28, 2023 12:49:18 GMT -6
Blue Tone Acoustics has some affordable tube traps too. Not sure on quality or effectiveness
Post by nudwig on Nov 28, 2023 19:18:52 GMT -6
I wanted to add to the pile of ASC fans. I too didn't want to pay what seemed like a fortune for them but finally relented mid pandemic and got 8 on sale (a touch over $4k in 2020). They work annoyingly well, wish I didn't wait the 10-15 years I knew about them to get them. Completely changed the already decently treated but still problematic cabin we were working in into something I wasn't constantly fixing. Like someone else mentioned, felt like I got new mics. I have no idea how well the DIY tubes would work but the ASC's are awesome! If someone's seriously looking I'd keep an eye on Craigslist, at least here in LA every 6-12 months someone seems to unload their collection, usually for a steal.
Post by ericn on Nov 28, 2023 20:18:46 GMT -6
Thomann also have a super cheap tube trap design: www.thomannmusic.com/t.akustik_tube_trap_bk.htmIf you poke around old threads on GS and PSW, Art Noxon (founder of ASC) would occasionally show up and dump tons of info about how ASC tube traps work. Lot of very high-level stuff that goes way over my head, but he seemed pretty transparent about how they’re designed, and I think he even provided a bunch of tips on how to do a DIY build. I definitely wanted to try DIY at one point, but eventually said fuck it and just went with ASC. They state they are made of foam so probably not nearly as effective.
Post by subspace on Nov 28, 2023 21:04:06 GMT -6
While I framed in a control room I had a giant stack of R13 rolls piled in the back of the room that would be used to fill in the framing. I arranged them in a semi-circle behind where I was experimenting with speaker placement and it sounded amazing in the listening position. Finished out the room and it didn't really compare to the open space with that wall of R13 rolls behind it. "Behind", as in you were facing the insulation and monitors at the same time? Similar to how an attack wall would be placed behind monitors? No, semi-circle behind the listening position, also inspired by those old 'Attack Wall' pictures. I found a pic of that build out from the 90s and the front wall was already stuffed with pink when I did that experiment:
Post by Tbone81 on Nov 29, 2023 17:17:46 GMT -6
Thomann also have a super cheap tube trap design: www.thomannmusic.com/t.akustik_tube_trap_bk.htmIf you poke around old threads on GS and PSW, Art Noxon (founder of ASC) would occasionally show up and dump tons of info about how ASC tube traps work. Lot of very high-level stuff that goes way over my head, but he seemed pretty transparent about how they’re designed, and I think he even provided a bunch of tips on how to do a DIY build. I definitely wanted to try DIY at one point, but eventually said fuck it and just went with ASC. They state they are made of foam so probably not nearly as effective. I saw that after I posted and thought the same thing. Although I bet there’s a foam product out there somewhere that does work great…seems like something that could be easily made, open cell foam of a specific density etc etc But then again, maybe foam just degrades too easily.
Post by ericn on Nov 29, 2023 18:00:02 GMT -6
They state they are made of foam so probably not nearly as effective. I saw that after I posted and thought the same thing. Although I bet there’s a foam product out there somewhere that does work great…seems like something that could be easily made, open cell foam of a specific density etc etc But then again, maybe foam just degrades too easily. The problems with foam, first the LF absorbtion isn’t as good as Fiberglass, second you have to make sure they are using flame resistant foam.
