Post by Ward on Jul 10, 2023 9:19:57 GMT -6
What kind/type/source?
How much?
Post by svart on Jul 10, 2023 12:17:25 GMT -6
Man that is such a hard question to answer. Completely depends on the genre, the guitar tone, lead/rhythm, etc.
Post by Ward on Jul 10, 2023 12:41:47 GMT -6
Man that is such a hard question to answer. Completely depends on the genre, the guitar tone, lead/rhythm, etc. Well pick one or three and give your thoughts on each scenario, please. I'm a lot like our fearless leader Johnkenn . . . I find what works and then get plagued by doubt, and ask questions! I kinda think that's a healthy mind at work!
Post by svart on Jul 10, 2023 13:01:57 GMT -6
Ok, so I think a bit of lush room might work best for most. Subtlety is key though. Not enough to be distracting, but enough to support the guitar in the mix. I think spring reverbs are a bit too much like fast delays and you always end up putting too much in a mix to make it noticeable.
Post by EmRR on Jul 10, 2023 14:22:42 GMT -6
If the spring is good, use it. Maybe dialed back some so there's room for a stereo reverb addition on top.
Post by Johnkenn on Jul 10, 2023 15:07:34 GMT -6
Man that is such a hard question to answer. Completely depends on the genre, the guitar tone, lead/rhythm, etc. Well pick one or three and give your thoughts on each scenario, please. I'm a lot like our fearless leader Johnkenn . . . I find what works and then get plagued by doubt, and ask questions! I kinda think that's a healthy mind at work! Yeah. Like Svart said. Just depends. On country tracks, I usually throw on the t-racks space echo or the audio thing space echo. Then I can add a little slap and some spring. Or do big spring on one side guitar and delay on the other.
Post by Johnkenn on Jul 10, 2023 15:08:29 GMT -6
If it’s an ethereal part, the guitar player will usually already have it dialed in.
Post by Tbone81 on Jul 10, 2023 18:43:06 GMT -6
I usually reach for a plate first, if it’s an electric guitar. Acoustic will get a room verb and a plate.
Never really mess with spring reverb, although maybe I should?
Post by EmRR on Jul 10, 2023 20:45:25 GMT -6
I mean shit, you ain't in 'MERICA if it ain't a Fender spring. Sayin'
Post by bgrotto on Jul 10, 2023 23:06:15 GMT -6
I like a bright chamber with a quick decay time. Or, just like, a real room mic.
Post by Blackdawg on Jul 10, 2023 23:42:36 GMT -6
My favorite is by far a chamber on Guitar. Nothing beats the depth feeling.
Layer in a shimmering plate too and delay to appease the rock gods when called for.
Post by theshea on Jul 11, 2023 0:23:08 GMT -6
if i want it i will always record it on the way in. mostly using the spring reverb on my fender amp. or alternatively i use the boss fender spring reverb pedal. a guitar player plays different with reverb so it gets recorded with. i don‘t use a amp room mic. that gets added later in the mix so i can make it fit with the other reverbs.
antbar
Junior Member
Post by antbar on Aug 21, 2023 21:52:38 GMT -6
I just blindly assumed we were talking electric guitar and with that in mind, I assumed spring! Usually it's pretty clear to me once a track is laid down if it needs reverb or not, or at least if it needs less than a lot! I've got a Vox AC15 and a Fender Princeton Reverb II... the reverbs between those two amps are impressively different from each other and so again, they kinda call the shots pretty immediately once guitar recording has begun.
Otherwise, no set preference about other types of reverb. It's a song by song decision...
Post by Ward on Aug 22, 2023 7:59:49 GMT -6
yes, I was primarily thinking of electric guitars. . .
when it comes to acoustic guitars? Whatever you're using on drums or your mix doesn't seem to glue together.
Here's a visual from 10-15 years ago: Unless you get the acoustics in the corset with the drums, they come out like a muffin top, or a dropped tube of pillsbury dough.
Post by thehightenor on Aug 22, 2023 12:58:36 GMT -6
I can't vote for multiple choices!
Who uses only one treatment :-)
Post by Ward on Aug 22, 2023 17:23:04 GMT -6
It was supposed to allow multiple votes. Grrrr
Post by bgrotto on Aug 22, 2023 19:44:52 GMT -6
Been playing with the "Brick Wall" setting in the 480 plug I have. I think it's the Relab one? Anywho, works great on a LOT of guitars across a surprising range of genres.
I also have a pretty rad preset I made for the Quantum reverb plug. That thing is exceptional, btw, for anyone who hasn't tried it. But it's a massive CPU hog.
Post by Ward on Aug 23, 2023 8:41:04 GMT -6
Been playing with the "Brick Wall" setting in the 480 plug I have. I think it's the Relab one? Anywho, works great on a LOT of guitars across a surprising range of genres. I also have a pretty rad preset I made for the Quantum reverb plug. That thing is exceptional, btw, for anyone who hasn't tried it. But it's a massive CPU hog. You had me at 'exceptional' but lost me at 'massive cpu hog'
Post by bgrotto on Aug 23, 2023 8:51:40 GMT -6
Been playing with the "Brick Wall" setting in the 480 plug I have. I think it's the Relab one? Anywho, works great on a LOT of guitars across a surprising range of genres. I also have a pretty rad preset I made for the Quantum reverb plug. That thing is exceptional, btw, for anyone who hasn't tried it. But it's a massive CPU hog. You had me at 'exceptional' but lost me at 'massive cpu hog' It's worth a demo, to be sure. My computer is generally happy running one instance per mix, and I work at 96k.
Post by Ward on Aug 23, 2023 8:57:02 GMT -6
You had me at 'exceptional' but lost me at 'massive cpu hog' It's worth a demo, to be sure. My computer is generally happy running one instance per mix, and I work at 96k. Good to know! Thanks, as always, Benny! It's great having you here.
Post by bgrotto on Aug 23, 2023 9:04:23 GMT -6
It's worth a demo, to be sure. My computer is generally happy running one instance per mix, and I work at 96k. Good to know! Thanks, as always, Benny! It's great having you here. My pleasure, that'll be $5 please 🤣 In all seriousness, yes, this community is worlds better than GS, because the collective (and varied) knowledge here is so exceptional. Which is my long winded way of saying, I appreciate you too, Ward!
Post by Deleted on Aug 24, 2023 21:31:58 GMT -6
Bloom
Post by kbsmoove on Aug 30, 2023 8:34:33 GMT -6
Amp spring on cleans is hard to beat. Pedal delay/verb in FX loop for leads (or in post if no loop) sometimes with some plate after to really put it in the cosmos. A sprinkle of short room (or room mics) to give a bit of realness to really upfront rhythms sometimes, if called for by the songs/mix/tones.
Post by theshea on Aug 31, 2023 13:07:46 GMT -6
the iso booths in the ik sunset sound reverb plugin are also very good for pushing a miked guitar amp a bit back in the mix and give it a nice hug with a subtle room reverb.
Post by copperx on Sept 1, 2023 11:31:07 GMT -6
For heavy guitar, I've had great luck with the Small Ambience preset on the Bricasti. It glues close-miked guitars to the rest of the track with no telltale signs of reverb.
