Post by kcatthedog on Feb 12, 2022 15:07:19 GMT -6
You cut super chunks by cutting 2x4 insulation in half, then cut each 2x2 piece diagonally, resulting in 4 triangular pieces all with the same dimensions and yes the long front face will be 24 inches.
You should do at least 2/3rds of height available, from the ceiling down, which will also help control the two tri-corners behind your monitors and monitoring position.
As you will have to support their weight , you might as well make them full height and for the sake of two extra triangular tops and bottoms, I ‘dcsuggest you make two per side and stack them.
Bottom one make 48 inches tall, second remaining height to ceiling. Consider if you wants them on wheels: just bottom one and that if you stack them, you will be able to just slide top one in place resting in bottom one and this will make them more mobile if you ever have to relocate.
In terms of fabric cover , I’d suggest you plan on using rigid insulation on front, fluffy behind . The rigid can be cut slightly oversized so you get a compression fit on inside of box and then you can use spray adhesive on back to keep fabric in place: easier than building a frame etc..
Adding the rigid on front also let’s you increase the depth in 1-3 inch dimensions and increase the absorption significantly, if you do this remember to add in the extra depth in the lengths of the two sides to the triangular frame you will need to build.
One other idea is, I just found a really good diy video fir building a diaghramic curved corner bass trap that also acts as a diffuser and uses sheet metal as face, insulation behind.
Let me know, if you’d like link to diy video.
Post by schmalzy on Feb 13, 2022 11:26:48 GMT -6
You cut super chunks by cutting 2x4 insulation in half, then cut each 2x2 piece diagonally, resulting in 4 triangular pieces all with the same dimensions and yes the long front face will be 24 inches. You should do at least 2/3rds of height available, from the ceiling down, which will also help control the two tri-corners behind your monitors and monitoring position. As you will have to support their weight , you might as well make them full height and for the sake of two extra triangular tops and bottoms, I ‘dcsuggest you make two per side and stack them. Bottom one make 48 inches tall, second remaining height to ceiling. Consider if you wants them on wheels: just bottom one and that if you stack them, you will be able to just slide top one in place resting in bottom one and this will make them more mobile if you ever have to relocate. In terms of fabric cover , I’d suggest you plan on using rigid insulation on front, fluffy behind . The rigid can be cut slightly oversized so you get a compression fit on inside of box and then you can use spray adhesive on back to keep fabric in place: easier than building a frame etc.. Adding the rigid on front also let’s you increase the depth in 1-3 inch dimensions and increase the absorption significantly, if you do this remember to add in the extra depth in the lengths of the two sides to the triangular frame you will need to build. One other idea is, I just found a really good diy video fir building a diaghramic curved corner bass trap that also acts as a diffuser and uses sheet metal as face, insulation behind. Let me know, if you’d like link to diy video. Hit me with that video! I'm intending on sorting out a better looking bunch of acoustic treatment this year. Thanks!
Post by kcatthedog on Feb 13, 2022 12:41:05 GMT -6
Post by kcatthedog on Feb 13, 2022 12:42:15 GMT -6
Link works, you just have to watch on YT.
Post by OtisGreying on Sept 23, 2022 2:49:53 GMT -6
Tube traps coming along.. 12 more to go
Post by OtisGreying on Sept 23, 2022 2:51:32 GMT -6
For anyone wondering I just wrapped the pipe insulation in some nice stretchy fabric and capped the ends with some 10 inch diameter wood discs off of Amazon. Liquid nails to glue. Simple and they look pretty darn good for 60$ a pop. They stack nicely
Post by RealNoob on Sept 25, 2022 14:53:16 GMT -6
Can someone link to this pipe insulation being used?
Post by stratboy on Sept 26, 2022 8:09:04 GMT -6
Occasionally my head is used for something other than a hat rack. That was my dad’s favorite saying. I heard it often. 😊
Post by OtisGreying on Oct 13, 2022 0:46:14 GMT -6
Can someone link to this pipe insulation being used? It's just standard owens corning pipe insulation.
I've finished 15 3ft traps - which ends up not giving that much real estate for an attack wall because I'm stacking them cause I don't have stands. Since I basically started in a brand new room with them, I can't say just how miraculous they are making everything sound. But in a fully untreated room apart from the traps I've placed around my monitors im in the -/+3 db range (roughly) for everything above like 200hz. And I spent one night in the room before they were there and I remember it sounding a whole lot splashier and confusing then it does now. I'm planning on making some 16"-18" diameter ones to fill the corners or fit into the attack wall style of what I've got to see how that helps with the peaks/nulls I've got in the sub 200 range.
I'd still probably splurge for some used ACS tube traps if I could find them at around 250-300$ each, just for the sake of having some that I don't have to worry about them getting worn down as I move them around and they look (a little) nicer, but retail - not worth it IMO unless funds aren't an issue. I'm just tracking alot so moving them around finding a good spot in my room is a thing so the stands and extra construction would be helpful in that regard, but these DIY ones are pretty sturdy nonetheless.
Post by Ward on Oct 14, 2022 4:07:52 GMT -6
Unless the monitoring choice is between actual monitors and two tin cans with string. I won't settle for anything less than Mogami string. The new Mogami Tim cans though…
Post by ericn on Oct 14, 2022 9:16:57 GMT -6
I won't settle for anything less than Mogami string. The new Mogami Tim cans though… I prefer the Canare far more flexible and keeps street noise down.
