Post by howie on Sept 2, 2021 17:54:07 GMT -6
Compressors good for voice.
jits
Post by jits on Sept 2, 2021 18:11:43 GMT -6
Guys, Anyone have any suggestions or preferences for which companies you'd like to see make Mojo Modules for the third MOJO C slot? What kind of things would appeal to everyone? thanks, Brad So mojo blocks A and B have drive + attenuation while C has drive + mix (parallel processing). I guess C has a great potential to host compressor modules to do parallel compression. Would also love to have some big tube enhancer/saturation modules available in these slots. Is it possible to have tube based modules in all slots - A, B and C?
Also, how about some midside processors - encode, run through L and R (where L and R could be different modules to enable mid side), decode. (not sure if this makes it too complicated a box)
Companies - Locomotive, Audioscape, IAA, and anyone who can contribute one or more great modules I guess!
While we are at it, i wish we had a push button to place slot C before A and B - and have a compressor in C to gain stage into A/N modules.
Post by Guitar on Sept 2, 2021 19:14:55 GMT -6
Maybe you could get CAPI and Gary Barnett and or Scott Liebers to do an alternate 'vintage' API mojo? I like GAR op amps a lot and I also like the CAPI CA-0252 just as much.
Also like the IAA Helios or Quad Eight idea, matt is your man
Post by ericn on Sept 2, 2021 21:22:51 GMT -6
Maybe you could get CAPI and Gary Barnett and or Scott Liebers to do an alternate 'vintage' API mojo? I like GAR op amps a lot and I also like the CAPI CA-0252 just as much. Also like the IAA Helios or Quad Eight idea, matt is your man I will agree with that Matt could cook up something fun, but as far as more vintage API vibe, well just change the opamp if you want to try.
Post by sirthought on Sept 2, 2021 21:41:14 GMT -6
Are you able to use current Silver Bullet routing options for re-amping? It might be interesting to have a module that could help with re-amping or using pedals as insert effects. This might be a specialized op-amp or something that could help for that task. The track output to your guitar amp?
I know Radial has different DI boxes and re-amp boxes and some have transformers. Maybe the Silver Bullet could be adapted to cover some of that utility.
jits
Post by jits on Sept 3, 2021 9:02:54 GMT -6
Indeed, it sold out by 8:01!
Post by howie on Sept 3, 2021 9:06:23 GMT -6
Indeed, it sold out by 8:01! Yee Gawd! You're right...!
jits
Post by jits on Sept 3, 2021 9:09:08 GMT -6
Actually, i changed the browser from Firefox to Chrome and was able to complete the order! Yaay! JFYI...!
Post by howie on Sept 3, 2021 9:19:00 GMT -6
Actually, i changed the browser from Firefox to Chrome and was able to complete the order! Yaay! JFYI...! Yes, says sold out in Firefox...and also Safari... I don't use Chrome. However, it's already 8:18 AM.
Post by drbill on Sept 3, 2021 9:25:18 GMT -6
Guys, sold out in minutes. I won the LTL bet on when. . Seriously, there are a LOT more mk2's for everyone as soon as we get parts from a couple of vendors. We're excited to get these into everyones hands that wants one. Soon.....
Post by drbill on Sept 3, 2021 9:26:50 GMT -6
Are you able to use current Silver Bullet routing options for re-amping? Yes, of course. That's one of it's major work flow features. Track vs. Mix on the input selector and i/o. Check the manual for more integrated options in how to do this.
Post by Blackdawg on Sept 3, 2021 11:19:46 GMT -6
ha i was up all night editing. Didn't even attempt it. more will come I'm sure!
Post by BradM on Sept 3, 2021 12:03:22 GMT -6
Hi all,
The 2nd batch went very very quickly this morning. Thanks to everyone who placed an order! We hope to start shipping the 2nd batch in January. Please watch the website over the next few months as we make progress.
If you weren't able to score a unit this morning, please know that we will make more available as soon as we can secure some key parts that are still outstanding. We have lots of PCB's on hand to assemble units as soon as those couple parts trickle in over the next few months.
Thanks again for everyone's support and patience.
Brad
Post by BradM on Sept 9, 2021 13:50:11 GMT -6
Are you able to use current Silver Bullet routing options for re-amping? It might be interesting to have a module that could help with re-amping or using pedals as insert effects. This might be a specialized op-amp or something that could help for that task. The track output to your guitar amp? I know Radial has different DI boxes and re-amp boxes and some have transformers. Maybe the Silver Bullet could be adapted to cover some of that utility. Thanks for the question. All the SB outputs are low impedance (~50 ohms) so can easily feed a signal into a guitar amp or pedalboard. You just might have to attenuate a little in your DAW to get the signal level where the amp or pedal is expecting it to be. Each Mojo Amp will allow you to attenuate the signal 24 dB, if you start with the Gain knob at minimum. Beyond that there’s not really anything a Mojo module would do to help further, unless it provided some kind of compression or EQ feature that was potentially useful. Typically reamp boxes have transformers to give galvanic isolation, level matching, and impedance matching. The impedance of the SB’s inputs and outputs are fixed. cheers, Brad
Post by BradM on Sept 9, 2021 13:52:57 GMT -6
Maybe you could get CAPI and Gary Barnett and or Scott Liebers to do an alternate 'vintage' API mojo? I like GAR op amps a lot and I also like the CAPI CA-0252 just as much. Also like the IAA Helios or Quad Eight idea, matt is your man Hi, Thanks for the suggestion. Have you tried our Rogue Six op amp? It has more of a vintage flavor than our Rogue Five which is more open and modern. I believe Matt from Resistance Audio has done some comparisons with it against some of those other vintage inspired options. cheers, Brad
Post by Guitar on Sept 9, 2021 13:58:20 GMT -6
Maybe you could get CAPI and Gary Barnett and or Scott Liebers to do an alternate 'vintage' API mojo? I like GAR op amps a lot and I also like the CAPI CA-0252 just as much. Also like the IAA Helios or Quad Eight idea, matt is your man Hi, Thanks for the suggestion. Have you tried our Rogue Six op amp? It has more of a vintage flavor than our Rogue Five which is more open and modern. I believe Matt from Resistance Audio has done some comparisons with it against some of those other vintage inspired options. cheers, Brad Did not know about that one, very cool! I will check them out.
Post by BradM on Sept 9, 2021 14:00:08 GMT -6
Hi there, Mojo C was certainly created with future compressor modules in mind. That’s why we put a Gain Reduction indicator on the front panel by those controls. I’m totally with you on getting some tube modules into the box. While technically you can physically install tube based modules in all three slots, it’s not advised because it would potentially exceed the current capability of the power supply. I think that would have to be evaluated based on what the current draw of each tube module is. Having some creative limitations can be a good thing, so the routing architecture will always be C after A and N. I really like the way that I can use much less compression after I’ve already done some transient shaving with the A and N Mojo Amps. So that’s part of the reason why C comes last and not first. cheers, Brad
Post by BradM on Sept 24, 2021 15:25:23 GMT -6
Hi all,
Just a quick note to say we’ve opened up more pre-orders. I think folks will find our new process less stressful.
Cheers, Brad
Post by Blackdawg on Sept 24, 2021 20:14:55 GMT -6
Hi all, Just a quick note to say we’ve opened up more pre-orders. I think folks will find our new process less stressful. Cheers, Brad Nice. That seems quite do able. Hopefully it doesn't get overwhelmed! I know people in the offroad truck world that build custom parts like this. Just add people to the list. Go 5-10 at a time and if you have the money, congrats! If you don't. bottom of the list. Works quite well actually.
Post by earthtoclinton on Sept 25, 2021 5:36:02 GMT -6
Try some HRK modules in mojo C... They have some killer ones. The LA-4 compressor module is a beast!
Post by notneeson on Sept 25, 2021 9:33:52 GMT -6
I need to vent a little:
Referring to line level signal processing as “re-amping” gives me hives. I blame the internet.
And I’m usually a pretty chill guy.
That is all. Except to say I really want a SB MK2.
Post by drbill on Sept 25, 2021 10:57:25 GMT -6
I need to vent a little: Referring to line level signal processing as “re-amping” gives me hives. I blame the internet. And I’m usually a pretty chill guy. That is all. Except to say I really want a SB MK2. I'll add to that - calling any signal exiting your DAW as "stems". LOL. Crazy!!!
Post by jeremygillespie on Sept 25, 2021 20:39:04 GMT -6
I need to vent a little: Referring to line level signal processing as “re-amping” gives me hives. I blame the internet. And I’m usually a pretty chill guy. That is all. Except to say I really want a SB MK2. I'll add to that - calling any signal exiting your DAW as "stems". LOL. Crazy!!! I just had a full body shake as I read that.
Post by schmalzy on Sept 26, 2021 14:40:09 GMT -6
I'll add to that - calling any signal exiting your DAW as "stems". LOL. Crazy!!! I just had a full body shake as I read that. Guys. Chill. I'm going to go reamp a set of vocal stems through an EQ plugin. When I come back you'd all better be cool, ok?
Post by jhsmastering on Oct 21, 2021 18:35:14 GMT -6
Try some HRK modules in mojo C... They have some killer ones. The LA-4 compressor module is a beast! I was just about to suggest this about a month later lol. Bart also has a VCA comp module, I read someone asking for something like that. The tube idea is what interests me. Not just a Colour module like Pentode or one of Bart's modules, but something that has a regular-sized tube or two in it, if that's possible.
