Post by Ward on May 9, 2020 8:56:26 GMT -6
Have you tried the wa412 Ward ? Yes. Enough for my needs. Thanks, next.
Post by ericn on May 9, 2020 10:22:49 GMT -6
Have you tried the wa412 Ward ? Yes. Enough for my needs. Thanks, next. Yeah for me the biggest problem with Warm is the Cheap Pots and Switches. Nothing worse than going cheap on the mechanical parts you actually use most of the time.
Post by sam on May 9, 2020 10:58:51 GMT -6
Yes. Enough for my needs. Thanks, next. Yeah for me the biggest problem with Warm is the Cheap Pots and Switches. Nothing worse than going cheap on the mechanical parts you actually use most of the time. I haven't found this to be a problem yet, in fact I love the knobs on the 412. Has anyone ever modded one of these? And I don't mean just op amps. Is there any truth to the Revive Audio mod of swapping caps? Like do they not use the same caps and resistors as CAPI stuff?
Post by Blackdawg on May 9, 2020 11:41:10 GMT -6
Can I ask why you'd need another power supply for some CAPI modules? You could just swap in the mic preamps to record and then swap in your other cards for mixing. Everything is already being used up by stuff I couldn't live without while tracking! I guess I could always get a bigger lunchbox and sell the one I currently own...but even then it would be quite a bit more expensive than getting the Warm, which would probably be used about twice a year ( I don't do that much remote drum tracking) . If you got vp28s you could use them for mixing too as line amps. A capi 11 slot rack is pretty darn affordable
Post by kcatthedog on May 9, 2020 12:17:54 GMT -6
Ward was just curious: that’s all.
Post by kcatthedog on May 9, 2020 12:30:42 GMT -6
To each their own, I have had 2 wa12s and didn’t think there was anything cheap about its feel or performance, quite the opposite I was also impressed with the heft due to the transformers.
I mostly used it on drums and was pleased with results.
I am more and more sensitive to the law of diminishing returns with gear. I can appreciate more expensive gear may be better: how much better vs it’s increased cost is what I wonder about.
If price sensitivity is high, then I guess you lean towards the Warm or something used or if greater cost doesn’t matter you have options there too.
Not in any way putting down Capi, as I have only heard great things about them.
Post by bricejchandler on May 9, 2020 12:35:58 GMT -6
Everything is already being used up by stuff I couldn't live without while tracking! I guess I could always get a bigger lunchbox and sell the one I currently own...but even then it would be quite a bit more expensive than getting the Warm, which would probably be used about twice a year ( I don't do that much remote drum tracking) . If you got vp28s you could use them for mixing too as line amps. A capi 11 slot rack is pretty darn affordable If money were no object I definitely would get VP28s... but unfortunately, even if I sold my rack, got a new Capi rack + 4 used VP26s, we're talking at least $1400 or so. I can get the Warm for half that.
Post by Ward on May 9, 2020 13:09:06 GMT -6
If you got vp28s you could use them for mixing too as line amps. A capi 11 slot rack is pretty darn affordable If money were no object I definitely would get VP28s... but unfortunately, even if I sold my rack, got a new Capi rack + 4 used VP26s, we're talking at least $1400 or so. I can get the Warm for half that. Sometimes your budget dictates your choices, or limits your options. More and more of us are feeling the pinch . . . so no shame in this being an important part of the decision making process.
Post by ericn on May 9, 2020 14:44:20 GMT -6
Yeah for me the biggest problem with Warm is the Cheap Pots and Switches. Nothing worse than going cheap on the mechanical parts you actually use most of the time. I haven't found this to be a problem yet, in fact I love the knobs on the 412. Has anyone ever modded one of these? And I don't mean just op amps. Is there any truth to the Revive Audio mod of swapping caps? Like do they not use the same caps and resistors as CAPI stuff? Knobs and pots are different, pots all have a rated life cycle, any pot will at sometime wear out no matter what, cheap ones faster than expensive ones. It becomes a real PITA down the road when a manufacturer discontinues a pot that is PCB mounted and has custom spaced pins. You can have custom pots made but a single one will cost more than a Warm.
Post by bricejchandler on May 9, 2020 15:03:56 GMT -6
If money were no object I definitely would get VP28s... but unfortunately, even if I sold my rack, got a new Capi rack + 4 used VP26s, we're talking at least $1400 or so. I can get the Warm for half that. Sometimes your budget dictates your choices, or limits your options. More and more of us are feeling the pinch . . . so no shame in this being an important part of the decision making process. Yeah I've had so much work cancelled that money is super tight. I'm almost thinking I might just stick to the Apogee preamps for drums for these couple projects and wait until I can get something better.
Post by Guitar on May 9, 2020 15:27:32 GMT -6
Just a left-field suggestion but I use Yamaha MLA8 for my drum preamps. They can easily be found under $300. Maybe if you're used to API preamps on drums, this would not be the same, but if you need something that "just works" this is my personal answer.
Yes, one day I will have all discrete pres for everything but in reality that could be a long way off.
Having great mics and a well-tuned drum set with good cymbals is 90% of the problem anyway. Not accounting for the drummer, of course. We will assume she's good.
Post by matt@IAA on May 9, 2020 16:10:58 GMT -6
Roll your own.
Post by Guitar on May 9, 2020 16:17:22 GMT -6
Roll your own. That is my plan! I was looking at the Whistle Rock PCB's. I could do a 6 channel in 1 RU of 312 circuits with my preferred transformers. Swap op amps if needed. Or just a whole bunch of dogears IA-N3 builds, we'll see how those go
Post by sozocaps on May 9, 2020 17:49:51 GMT -6
CAPI VP28 is like a Vintage API and a Vintage Neve in one... Super fast, punchy and open but larger then life and smooth like a Neve. It's my desert Island pre-amp I would absolutely sell everything and have a console of these.
John
Post by the other mark williams on May 9, 2020 21:27:33 GMT -6
Sometimes your budget dictates your choices, or limits your options. More and more of us are feeling the pinch . . . so no shame in this being an important part of the decision making process. Yeah I've had so much work cancelled that money is super tight. I'm almost thinking I might just stick to the Apogee preamps for drums for these couple projects and wait until I can get something better. Given what you’re saying, if you’re really able to get the 412 for 50% off, I’d really consider going that route. You could probably resell it at the end of the project without losing much of anything, and it’d probably be nicer than using the Ensemble pres for drums.
Post by plinker on May 10, 2020 8:55:23 GMT -6
Sometimes your budget dictates your choices, or limits your options. More and more of us are feeling the pinch . . . so no shame in this being an important part of the decision making process. Yeah I've had so much work cancelled that money is super tight. I'm almost thinking I might just stick to the Apogee preamps for drums for these couple projects and wait until I can get something better. In that case why not just buy used wa12 and sell them later if you wish. ‘Tis the beauty of buying preowned gear!
Post by Ward on May 10, 2020 8:55:32 GMT -6
CAPI VP28 is like a Vintage API and a Vintage Neve in one... Super fast, punchy and open but larger then life and smooth like a Neve. It's my desert Island pre-amp I would absolutely sell everything and have a console of these. John And sadly, out of stock every time I go to order . . . a great complaint to have if you're Jeff jsteiger!
Post by bricejchandler on May 10, 2020 9:46:04 GMT -6
Yeah I've had so much work cancelled that money is super tight. I'm almost thinking I might just stick to the Apogee preamps for drums for these couple projects and wait until I can get something better. In that case why not just buy used wa12 and sell them later if you wish. ‘Tis the beauty of buying preowned gear! I think that's exactly what I'm gonna do!
Post by jsteiger on May 10, 2020 13:46:45 GMT -6
CAPI VP28 is like a Vintage API and a Vintage Neve in one... Super fast, punchy and open but larger then life and smooth like a Neve. It's my desert Island pre-amp I would absolutely sell everything and have a console of these. John And sadly, out of stock every time I go to order . . . a great complaint to have if you're Jeff jsteiger ! Tryin to keep stuff in stock during this pandemic has been a chore. Supply chains have been tricky and our demand is way up. Saying I'm blessed is an understatement. We should have another batch of inputs in before the end of this coming week.
grantb
Junior Member
Post by grantb on May 10, 2020 14:20:55 GMT -6
Haha I am guilty of bird doggin the CAPI store all day for the kits I'm after. I snagged the last two VP28 litz the other day, 10 keyed in my cc# so fast like a veteran grocery checker lol. Shoulda grabbed the 312DIs when there was 20 of them, poof they're gone.
Post by Ward on May 11, 2020 11:43:32 GMT -6
And sadly, out of stock every time I go to order . . . a great complaint to have if you're Jeff jsteiger ! Tryin to keep stuff in stock during this pandemic has been a chore. Supply chains have been tricky and our demand is way up. Saying I'm blessed is an understatement. We should have another batch of inputs in before the end of this coming week. set two aside for me please, so that grantb fella doesn't hoard them all! I'm willing to bet he has his garage full of 50,000 rolls of butt wad, too!
grantb
Junior Member
Post by grantb on May 11, 2020 12:39:45 GMT -6
Tryin to keep stuff in stock during this pandemic has been a chore. Supply chains have been tricky and our demand is way up. Saying I'm blessed is an understatement. We should have another batch of inputs in before the end of this coming week. set two aside for me please, so that grantb fella doesn't hoard them all! I'm willing to bet he has his garage full of 50,000 rolls of butt wad, too! No way man, I spent all my money on 500 kits. I'm wiping with pink bubble wrap over here.
Post by Guitar on May 11, 2020 13:06:00 GMT -6
I hope there are some CAPI new op amps available on wednesday! Haha. I am planning an order.
Post by Ward on May 11, 2020 20:40:55 GMT -6
