Post by sirthought on Jan 24, 2020 10:01:02 GMT -6
New Big Muff pedal that is also a guitar interface and there's a plugin for track inserts. Control in the DAW, run through the analog pedal. Can be used as a stand-alone pedal, with 10 presets that can be cycled through with a dedicated footswitch. Onboard screen shows which preset is active. Endless presets within the DAW.
Bunch of the new stuff from EHX, but this thing will track if you want it to.
