Post by klauth on Jan 24, 2020 9:36:15 GMT -6
Looking for some perspective for my drum OH's:
A new pair of pultec EQP-1s for my existing coles 4038's
Or
A new pair of Royer SF-2's
Your thoughts please...
Post by Tbone81 on Jan 24, 2020 9:46:12 GMT -6
The Royers will deliver a whole different (equally beautiful) sound imho. I'd go that direction.
Post by spindrift on Jan 24, 2020 10:23:45 GMT -6
The answer is mics. ALWAYS MORE MICS!!! 😈
Post by Deleted on Jan 24, 2020 11:33:23 GMT -6
Which would provide you with more uses than just overheads? I think the coles are a standard for a reason. I freelance, so I don't need a lot of mics, but I would probably still roll with the Pultecs because you can track your coles with them, then use em again when you're mixing.
Post by jamiesego on Jan 24, 2020 11:50:00 GMT -6
I would do the Pultecs personally. Anything you can use in tracking, mixing, or master buss is worth the money to me.
Post by notneeson on Jan 24, 2020 12:03:24 GMT -6
Looking for some perspective for my drum OH's: A new pair of pultec EQP-1s for my existing coles 4038's Or A new pair of Royer SF-2's Your thoughts please... Really happy with SF-12 on OHs when I've used it. Kind of a treat to position since it's two ribbons in a single housing, but I could see going for the mono version x2.
Post by johneppstein on Jan 24, 2020 14:02:53 GMT -6
Er, BOTH???
Post by michaelcleary on Jan 24, 2020 14:09:33 GMT -6
mics. I rarely, if ever, use EQ outside the box.
Post by johneppstein on Jan 24, 2020 14:12:42 GMT -6
mics. I rarely, if ever, use EQ outside the box. Conversely, I almost never use EQ IN the box. But I also rarely use EQ that isn't built into my console, either.
