Post by Johnkenn on Nov 18, 2019 10:57:11 GMT -6
Is back...probably going to pick up the 4 for $399. Capital Chambers, 176 pair...maybe the API. I used the API stuff on some guitars and wasn’t really able to replicate the tone with much of anything else. To me, these plugs are still cream of the crop.
Post by sirthought on Nov 19, 2019 2:20:17 GMT -6
There are several I want, but cash is nil right now. Distressor, Massive Passive, 33609
I have the API Vision channel strip. It depends on the song/source, but I like it a lot on kick and snare for tracking. It certainly adds character.
Post by Guitar on Nov 19, 2019 8:30:19 GMT -6
I have the API EQ's, not the Vision channel strip. Lovely EQ's.
Post by jcoutu1 on Nov 19, 2019 8:41:27 GMT -6
I really wish they could make this system portable. Either a smaller form factor, bus powered octo card, or just full on native with a USB stick.
I'd love to use some of these plugs, but I'm just on the go too much.
Post by Guitar on Nov 19, 2019 8:53:11 GMT -6
I really wish they could make this system portable. Either a smaller form factor, bus powered octo card, or just full on native with a USB stick. I'd love to use some of these plugs, but I'm just on the go too much. Is the USB3 Satellite not close enough for you? Those are windows only not mac. I was thinking of upgrading to one of those from my firewire satellite.
Post by jcoutu1 on Nov 19, 2019 10:08:31 GMT -6
I really wish they could make this system portable. Either a smaller form factor, bus powered octo card, or just full on native with a USB stick. I'd love to use some of these plugs, but I'm just on the go too much. Is the USB3 Satellite not close enough for you? Those are windows only not mac. I was thinking of upgrading to one of those from my firewire satellite. I'm a Mac guy. Just seems like too much to be hauling around and setting up. Needing to find power, etc. MacBook Pro, ilok, Apogee Groove, and headphones gets the job done.
Post by Deleted on Nov 19, 2019 10:35:43 GMT -6
I have the API EQ's, not the Vision channel strip. Lovely EQ's. I love the 560. Use it a ton. I don't reach for the 550a all that often for whatever reason. I typically go to the 1081 for general purpose stuff. I've been meaning to try doing a mix where I only use 550's on everything though.... just to see how it goes.
Post by Guitar on Nov 19, 2019 11:40:36 GMT -6
I have the API EQ's, not the Vision channel strip. Lovely EQ's. I love the 560. Use it a ton. I don't reach for the 550a all that often for whatever reason. I typically go to the 1081 for general purpose stuff. I've been meaning to try doing a mix where I only use 550's on everything though.... just to see how it goes. The 550 is sort of magic/probably-not-secret special on electric guitars to me for some reason. I am pretty frequently pulling up 550 for electric guitars when I want them to cut through. 560 I pull up on bass pretty often, it seems perfect to get bass to sit in the exact right place. Drums tend to be more SSL strips and Neve strips for whatever reason. Just to sort of go along with what you were saying.
Post by Johnkenn on Nov 20, 2019 8:48:32 GMT -6
I really like the 560 (or 550) on EG’s. Like more than other EQ plugs or versions. Not sure what it does, but it’s easy to make them sound good with these.
Post by wiz on Nov 20, 2019 17:44:30 GMT -6
I always wanted a real 560....
Post by Johnkenn on Nov 20, 2019 17:56:38 GMT -6
I always wanted a real 560.... cheers Wiz Not sure I’d want the real thing because there’s no recall with the sliders...but jsteiger’s LC25 and 40 -“are somewhat based off of it and the bomb.
Post by jsteiger on Nov 20, 2019 18:18:06 GMT -6
I always wanted a real 560.... cheers Wiz Not sure I’d want the real thing because there’s no recall with the sliders...but jsteiger ’s LC25 and 40 -“are somewhat based off of it and the bomb.
Post by Johnkenn on Nov 20, 2019 18:19:49 GMT -6
Not sure I’d want the real thing because there’s no recall with the sliders...but jsteiger ’s LC25 and 40 -“are somewhat based off of it and the bomb. Ha...that wasn’t an intentional “ lol. Looks like a snarky “somewhat based off of.”
Post by Johnkenn on Nov 20, 2019 18:21:01 GMT -6
Btw - after hearing the API 550 and CAPI BT50, there’s no way I’m buying an API.
Post by jeremygillespie on Nov 20, 2019 18:24:05 GMT -6
I always wanted a real 560.... cheers Wiz Not sure I’d want the real thing because there’s no recall with the sliders...but jsteiger’s LC25 and 40 -“are somewhat based off of it and the bomb. The sliders are the absolute WORST to try and recall. Even running tone through them at the selected frequency you can’t even get close to what you had. I eventually moved to telling engineers they were broken when they would want to patch them in on a mix years ago so I wouldn’t have to deal with the headaches.
Post by sean on Nov 21, 2019 7:08:15 GMT -6
I had a 560 for a long time, a favorite for kick drum in particular, and the UA does a good job of replicating it. If I dialed in a sound I liked with hardware I could match it with the plug in really well, although the slider placements didn’t look similar.
Post by Johnkenn on Nov 21, 2019 16:31:41 GMT -6
I had a 560 for a long time, a favorite for kick drum in particular, and the UA does a good job of replicating it. If I dialed in a sound I liked with hardware I could match it with the plug in really well, although the slider placements didn’t look similar. The boosts add volume, so maybe that is accounting for why I think the plug sounds so good.
Post by Deleted on Nov 22, 2019 10:12:36 GMT -6
Anyone use the Vari Mu plugin? Been thinking about getting that for a bit and just saw that I can now get it 50% off. I remember Tape Op reviewing it very favorably a while back.
Post by Johnkenn on Nov 22, 2019 11:53:16 GMT -6
Anyone use the Vari Mu plugin? Been thinking about getting that for a bit and just saw that I can now get it 50% off. I remember Tape Op reviewing it very favorably a while back. I used it on my master in M/S for every mix. Adds a nice sheen and you can add stereo width in m/s
Post by sirthought on Nov 22, 2019 23:07:03 GMT -6
Anyone use the Vari Mu plugin? Been thinking about getting that for a bit and just saw that I can now get it 50% off. I remember Tape Op reviewing it very favorably a while back. I am using it on my mix bus. I don't know if I have too much comparison, other than trying some options like Ozone. I think the Vari Mu sounds pretty good, so I've stuck with that.
Post by Deleted on Dec 3, 2019 17:46:30 GMT -6
Anyone use the Vari Mu plugin? Been thinking about getting that for a bit and just saw that I can now get it 50% off. I remember Tape Op reviewing it very favorably a while back. I am using it on my mix bus. I don't know if I have too much comparison, other than trying some options like Ozone. I think the Vari Mu sounds pretty good, so I've stuck with that. I got it. It's pretty impressive. It's a rare occasion that I actually notice the "analog vibe" of an emulation by simply turning it on, but despite having never used a real one, I hear it doing a thing. The input gain seems to have a sweet-spot. I'm not sure if I'll ever fuck with the M/S stuff, but so far I'm digging it on drums and mix buss. Right now I have it on the master, after my TK BC501. Polar opposite action on those.
Post by kcatthedog on Dec 3, 2019 18:42:40 GMT -6
Vari mu was one of my ua fav’s. I do think about going back but would only be interested in 10-15 plugs, but even with the free sat deal, you still have to re buy the plugs : doable but hard to make the jump back.
