Post by Johnkenn on Nov 8, 2019 14:33:15 GMT -6
I think I'm going to take Dave Wheeler up on helping me with this...but what causes this? Could it be a number of things and you just have to rule them out? I've got RF in my Upton...you can't hear it on playback, but it's annoying through the HPs
Post by EmRR on Nov 8, 2019 14:36:31 GMT -6
If it's not there on playback it's something in the monitor path.
Post by Johnkenn on Nov 8, 2019 19:30:56 GMT -6
If it's not there on playback it's something in the monitor path. The weird thing is it doesn’t happen with the Heiserman. I need to double check to see if you can hear it. I was thinking when hearing the playback all I heard was bleed
Post by drbill on Nov 9, 2019 9:55:41 GMT -6
hey John - before you get deep into disecting your mic - check this out, It was an annoying problem until I properly grounded my Gefell's. Could be something similar in the Upton. All it requires is a cable change / fix at the mic end. Might be complicated a touch due to it being a tube mic, but worth checking out. Get the ground on Pin 1 (not sure where ground is on the tube circuit) tied down to the Chassis of the plug. Simple, 100% effective, cheap. www.gearslutz.com/board/high-end/111893-gefell-owners-users-what-you-need-know.htmlSome good comments there too...
Post by johneppstein on Nov 11, 2019 15:08:20 GMT -6
hey John - before you get deep into disecting your mic - check this out, It was an annoying problem until I properly grounded my Gefell's. Could be something similar in the Upton. All it requires is a cable change / fix at the mic end. Might be complicated a touch due to it being a tube mic, but worth checking out. Get the ground on Pin 1 (not sure where ground is on the tube circuit) tied down to the Chassis of the plug. Simple, 100% effective, cheap. www.gearslutz.com/board/high-end/111893-gefell-owners-users-what-you-need-know.htmlSome good comments there too... Beat me to it! There's a similar thread over at PRW.
Post by Johnkenn on Apr 1, 2020 15:56:59 GMT -6
Think Faraday Tape could help? I actually bought the RFID fabric to try to put over the PS to see if it would work. I THOUGHT it did...but now I'm getting 99.7 pretty good again lol. Will this even work if I found the culprit? drbill I'm afraid that pin stuff is too smarts for me. Plus, I guess it could actually be the proprietary cable from the mic to the PS... www.amazon.com/TitanRF-Faraday-Tape-High-Shielding-Conductive/dp/B07DXDSCTF
Post by ericn on Apr 1, 2020 21:18:10 GMT -6
Think Faraday Tape could help? I actually bought the RFID fabric to try to put over the PS to see if it would work. I THOUGHT it did...but now I'm getting 99.7 pretty good again lol. Will this even work if I found the culprit? drbill I'm afraid that pin stuff is too smarts for me. Plus, I guess it could actually be the proprietary cable from the mic to the PS... www.amazon.com/TitanRF-Faraday-Tape-High-Shielding-Conductive/dp/B07DXDSCTFTry some of those ferrit beads, man I can’t count the times when those things made me look like genius!
Post by Johnkenn on Apr 1, 2020 21:36:41 GMT -6
Think Faraday Tape could help? I actually bought the RFID fabric to try to put over the PS to see if it would work. I THOUGHT it did...but now I'm getting 99.7 pretty good again lol. Will this even work if I found the culprit? drbill I'm afraid that pin stuff is too smarts for me. Plus, I guess it could actually be the proprietary cable from the mic to the PS... www.amazon.com/TitanRF-Faraday-Tape-High-Shielding-Conductive/dp/B07DXDSCTFTry some of those ferrit beads, man I can’t count the times when those things made me look like genius! Ohhh I’m gonna kiss you if this works!
Post by johneppstein on Apr 1, 2020 23:24:04 GMT -6
Post by svart on Apr 2, 2020 11:10:15 GMT -6
Since RF is what I do..
First, a faraday cage is simply a grounded metal mesh that's smaller than the fractional wavelengths of the signals you want to reject. The metal chassis, the metal screen over the capsule, etc are all faraday cages.
Secondly, you need a nonlinear junction (diode) and a large amount of amplification to demodulate radio down to audio. This means that somehow the RF is getting into the amplifiers in the mic.
Third, ferrites act as high impedance for higher frequencies, similar to how inductors work, but generally without coils.
4th, ferrites shouldn't be needed at all if the faraday system is working.
So all this together sounds like the ground in your mic is not working right. I'd bet the cable between the power supply and the mic has either the shield or the power wires unhooked or something, or the XLR shells are not grounded.
Does the radio bleed change if you touch the mic?
But then again, anything that you can hear through headphones should be on the recording. You're also saying that you're hearing radio but it's not actually being recorded? Or are you saying that you just have your headphones turned up so much you hear the radio through the mic but in the mix the radio is too low to matter?
Post by tskguy on Apr 2, 2020 12:16:25 GMT -6
What Svart said
Post by Johnkenn on Apr 2, 2020 12:35:54 GMT -6
Since RF is what I do.. First, a faraday cage is simply a grounded metal mesh that's smaller than the fractional wavelengths of the signals you want to reject. The metal chassis, the metal screen over the capsule, etc are all faraday cages. Secondly, you need a nonlinear junction (diode) and a large amount of amplification to demodulate radio down to audio. This means that somehow the RF is getting into the amplifiers in the mic. Third, ferrites act as high impedance for higher frequencies, similar to how inductors work, but generally without coils. 4th, ferrites shouldn't be needed at all if the faraday system is working. So all this together sounds like the ground in your mic is not working right. I'd bet the cable between the power supply and the mic has either the shield or the power wires unhooked or something, or the XLR shells are not grounded. Does the radio bleed change if you touch the mic? But then again, anything that you can hear through headphones should be on the recording. You're also saying that you're hearing radio but it's not actually being recorded? Or are you saying that you just have your headphones turned up so much you hear the radio through the mic but in the mix the radio is too low to matter? Thanks man!! I might have said before that it wasn’t in the recording but I was wrong. It’s there.
Post by Johnkenn on Apr 2, 2020 12:37:23 GMT -6
And since I is stupid when it comes to lectronics...how would I identify the ground wire in the mic?
Post by drbill on Apr 2, 2020 13:47:17 GMT -6
And since I is stupid when it comes to lectronics...how would I identify the ground wire in the mic? Check back to my previous post, and to the thread it references. Sometimes (don't know why) with certain mics, the XLR plug is not grounded to the chassis of the mic. Instead it's grounded to the audio of the mic thru pin 1 of the plug which (may) be isolated from the chassis. That sometimes seems to be problematic and not effective in certain RF high locations. For me it was intermittent, and it can even depend on the ANGLE of the mic or the placement of a mic in the room. Crazy times. I had all kinds of crazies with my Gefell's until I sorted it out with the pigtail cables I talked about in that thread. All this is really simple if you know how to solder and have had any experience making XLR cables. What gets dicey is that now you're dealing with a 7 pin tube mic cable that's carrying high voltages - and on those cables, I'm not sure which pin is ground. I'm sure this would be childs play for Dave, but before taking it to him, you might try getting one of those alligator clip leads and try grounding the XLR or PS to the body of the mic to see if that makes any difference. In the Gefell mics, the magic fix was when the CHASSIS of the XLR became grounded to the CHASSIS of the mic. Why? I'm not the right guy to ask, but it brought such joy into my life when I finally got it sorted - AND - it was super easy - and cost nothing other than the time, research and aggravation. Give Dave a call and see if he can experiment with taking the audio ground of the tube mic cable at the mic end, removing it from the audio ground and locating it to the chassis of the XLR on the mic end. Or maybe it will need to go both places - audio ground and chassis ground. For me, it was removing from audio ground, and attaching to chassis ground on the XLR plug. Good luck!!!
Post by johneppstein on Apr 2, 2020 13:48:36 GMT -6
And since I is stupid when it comes to lectronics...how would I identify the ground wire in the mic? In the Gefell mics the problem can be fixed with the cable. The recommendations for Gefell specify a certain type of Gotham Audio cable, dunno how important that is. I believe that the wiring part involves connecting the ground lug to the connector shell (which is usually not used) to ground. Dunno if the Gotham cable has a separate ground wire independent of the shield or not.
Post by drbill on Apr 2, 2020 13:54:59 GMT -6
And since I is stupid when it comes to lectronics...how would I identify the ground wire in the mic? In the Gefell mics the problem can be fixed with the cable. The recommendations for Gefell specify a certain type of Gotham Audio cable, dunno how important that is. I believe that the wiring part involves connecting the ground lug to the connector shell (which is usually not used) to ground. Dunno if the Gotham cable has a separate ground wire independent of the shield or not. Yes, that's exactly it. Remove the ground from pin 1 and attach to the shell of the XLR. Easy to do on Switchcraft style XLR's.
Post by svart on Apr 2, 2020 14:30:09 GMT -6
Personally I'd attach the XLR shell to pin 1 of the XLR and leave them both connected and see if that helps first. The shell of the mic might be electrically isolated at the mic and would remove the power ground if you moved pin 1 to the shell alone.
Post by ragan on Apr 2, 2020 15:29:20 GMT -6
I don’t have anything to add other than that on Monday I start “Fields and Waves” and though I am not relishing having to dust off that many multivariable calc brain cells, I’m really excited to learn more about this stuff. And I’d be lying if I said I wasn’t a tad bit excited about all the MV calculus. It’s pretty inherently amazing and useful stuff. But JK, if you just do what svart and EmRR tell you I’m sure you’ll get it squared away.
Post by Johnkenn on Apr 2, 2020 17:03:14 GMT -6
Calculus is fun? I’m not totally sure what all the shell stuff means...but I’m also dealing with a tube mic, so I thought I might open up the connector to see what I can find out. Maybe freshen up some solder points?
Post by Johnkenn on Apr 3, 2020 14:30:28 GMT -6
drbill...I might kiss you. I opened the mic and saw where it was grounded and pushed that around a little bit to make sure it wasn't touching anything else...and that seems to have worked. Gonna check it later too. Thanks!!
Post by drbill on Apr 3, 2020 15:12:06 GMT -6
drbill ...I might kiss you. I opened the mic and saw where it was grounded and pushed that around a little bit to make sure it wasn't touching anything else...and that seems to have worked. Gonna check it later too. Thanks!! Awesome!! Might?? haha! Should I PM you my address??
Post by ragan on Apr 3, 2020 15:13:34 GMT -6
SOCIAL DISTANCING, bros. The jubilant embrace will have to wait.
Post by drbill on Apr 3, 2020 15:14:29 GMT -6
PS - I know EXACTLY how you feel. After Jim Williams told me to either off my piece of junk Gefell's (7) to some unsuspecting Ebay buyer, or toss em in the trash, I was OVERJOYED when I figured out the fix. So glad you got it working!!
Post by chessparov on Apr 3, 2020 15:39:15 GMT -6
Grounding is good. For microphones and sometimes Teenagers! Chris
Post by svart on Apr 3, 2020 17:54:21 GMT -6
PS - I know EXACTLY how you feel. After Jim Williams told me to either off my piece of junk Gefell's (7) to some unsuspecting Ebay buyer, or toss em in the trash, I was OVERJOYED when I figured out the fix. So glad you got it working!! Jeeze. Jim has said some really outlandish stuff over the years, but damn, that almost takes the cake.
