Post by Deleted on Sept 9, 2019 19:51:12 GMT -6
I look at it this way. How many recordings made though original Neve 1073’s were made without using the EQ? I would think very few. Therefore if you are looking to buy a 1073 because of its heritage/sound etc why would you buy 1073 without EQ? It kind of doesn’t make sense. Even more so in the case of a 1084. my take on it like this. i see where u coming from that all records had the EQ in it. im sure a lot more gear was used alongside the 73s. but my situation is a bit different, times are different. i need it for tracking and EQ is not needed cause i dont mix, and will have a pro do it. but unless by having a (bypassed) EQ inline the sound becomes "so desirable" that i will be missing out, otherwise its a waste. with Preamp version only, its kinda like neve 1290 right? from what im reading here is that its not necessarily better, but a bit different maybe cause all of the extra EQ circutory it goes through when when not engaged.. i guess i have to hear it myself to make that call.. i also thought about adding newer EQ after the preamp, like 551, or 5033, how it would effect the sound, improve or degrades by adding more stuff. i dont know.
Post by Deleted on Sept 9, 2019 19:51:32 GMT -6
Any comparison clips yet? Still would like to hear Sorry, I haven't gotten around to it yet. I've been busy with work and mixing, lately, and then also had to rearrange my rack to accomodate a new compressor (Kush Tweaker). Hopefully I'll be recording some more in the next few weeks and I can give it a try. I may also throw in a couple other preamps. I was also debating exactly how to do this. I want the same performance but also to use mics because running line signal through is not the same thing as using these as actual mic pres. I guess I'll use a looper to feed an amp. no worries, cant wait to hear. thank you
Post by drbill on Sept 9, 2019 20:00:29 GMT -6
but unless by having a EQ inline the sound becomes "so desirable" that i will be missing out, then ill think about it. with Preamp version only, its kinda like neve 1290 right? from what im reading here is that its not necessarily better, but a bit different. i guess i have to hear it myself to make that call.. A 1073 has an EQ. Period. And it does affect the sound. How much, how different non-EQ versions sound, etc. and how much of a difference it makes is up to you and your personal esthetic. But 1073's - real ones or legit clones - all have EQ's. It's a part of it's "thing". Yes, definitely listen for yourself!! You may not need the EQ! <thumbsup>
Post by Deleted on Sept 9, 2019 20:57:30 GMT -6
but unless by having a EQ inline the sound becomes "so desirable" that i will be missing out, then ill think about it. with Preamp version only, its kinda like neve 1290 right? from what im reading here is that its not necessarily better, but a bit different. i guess i have to hear it myself to make that call.. A 1073 has an EQ. Period. And it does affect the sound. How much, how different non-EQ versions sound, etc. and how much of a difference it makes is up to you and your personal esthetic. But 1073's - real ones or legit clones - all have EQ's. It's a part of it's "thing". Yes, definitely listen for yourself!! You may not need the EQ! <thumbsup> most definitely i AGREE, it maybe the sound i desire. its hard to make that call till i hear it. i may prefer one over the other.
Post by Deleted on Sept 10, 2019 9:07:54 GMT -6
but unless by having a EQ inline the sound becomes "so desirable" that i will be missing out, then ill think about it. with Preamp version only, its kinda like neve 1290 right? from what im reading here is that its not necessarily better, but a bit different. i guess i have to hear it myself to make that call.. A 1073 has an EQ. Period. And it does affect the sound. How much, how different non-EQ versions sound, etc. and how much of a difference it makes is up to you and your personal esthetic. But 1073's - real ones or legit clones - all have EQ's. It's a part of it's "thing". Yes, definitely listen for yourself!! You may not need the EQ! <thumbsup> And ur saying it still part of the sound even when EQ is in bypass mode/not engaged?
Post by drbill on Sept 10, 2019 9:12:10 GMT -6
A 1073 has an EQ. Period. And it does affect the sound. How much, how different non-EQ versions sound, etc. and how much of a difference it makes is up to you and your personal esthetic. But 1073's - real ones or legit clones - all have EQ's. It's a part of it's "thing". Yes, definitely listen for yourself!! You may not need the EQ! <thumbsup> And ur saying it still part of the sound even when EQ is in bypass mode/not engaged? Yes. That's what Colin @ AML and other people way smarter than me have told me.
Post by Deleted on Sept 10, 2019 10:03:22 GMT -6
And ur saying it still part of the sound even when EQ is in bypass mode/not engaged? Yes. That's what Colin @ AML and other people way smarter than me have told me. got you, i understand. thanks for the clarification. i guess i really want to hear it for myself now. there is one member here who has both, will be doing an A/B
Post by drbill on Sept 10, 2019 11:04:34 GMT -6
You may end up liking the "non-perfect" and "compromised" clone BETTER than the exact replica. Although we tend to view the original as "best", it may not always be so. For instance, tracking on a Neve 80 series console brings a lot of low mid mud into the equation that is not necessarily good. More modern Neve variants might actually be better after 20 overdubs than a true vintage replica. I know...heresy right?
Post by notneeson on Sept 10, 2019 12:25:58 GMT -6
Full on 1073 clone? Awesome, those are cool.
Great Neve style preamp into a 550A, quite often more useful in my world.
Post by matt@IAA on Sept 10, 2019 12:36:54 GMT -6
Yes. That's what Colin @ AML and other people way smarter than me have told me. got you, i understand. thanks for the clarification. i guess i really want to hear it for myself now. there is one member here who has both, will be doing an A/B I’d do an A/B and an out-of-phase digital sum. I’d be real curious what the dB level of the sum would be.
Post by drbill on Sept 10, 2019 13:00:05 GMT -6
Full on 1073 clone? Awesome, those are cool. Great Neve style preamp into a 550A, quite often more useful in my world. Sweet! Both major food groups!!
Post by Deleted on Sept 10, 2019 14:34:36 GMT -6
Full on 1073 clone? Awesome, those are cool. Great Neve style preamp into a 550A, quite often more useful in my world. I think the member here said the full topology one is more colored. In that case I may prefer the preamp only version. You can still push the transformers for more color. Well see, I'm speculating this maybe extremely subtle in sound, Can't wait. I mean even the clones sound different from each other
Post by Deleted on Sept 11, 2019 21:31:40 GMT -6
And ur saying it still part of the sound even when EQ is in bypass mode/not engaged? Yes. That's what Colin @ AML and other people way smarter than me have told me. hes not the only one, i heard this from few from quite a few other people. including this guy who owns a commercial recording studio.
Post by Deleted on Sept 11, 2019 21:39:03 GMT -6
Any comparison clips yet? Still would like to hear Sorry, I haven't gotten around to it yet. I've been busy with work and mixing, lately, and then also had to rearrange my rack to accomodate a new compressor (Kush Tweaker). Hopefully I'll be recording some more in the next few weeks and I can give it a try. I may also throw in a couple other preamps. I was also debating exactly how to do this. I want the same performance but also to use mics because running line signal through is not the same thing as using these as actual mic pres. I guess I'll use a looper to feed an amp. i know you said the EQ one and one without EQ sounds different. what built up my curiosity was when i read a gearslut post somewhere, where some guy claimed, when you run it through preamp versus running it through the EQ, (even eq bypass) you can still hear the circuit sweetens the sound and pushes it forward in a big 3D type way sounding more alive. this what im trying to find if there is any truth to this. now this was written for another clones such as heritage. would be great to hear with stam which you have both.
Post by Tbone81 on Sept 11, 2019 21:39:46 GMT -6
I think you’re over thinking it. A great preamp is a great preamp. Sure the 1073 will sound different with and without the eq, but remember that a stand alone Neve preamp isn’t going to sound like a console anyway. The console sound that so many of us are chasing is the sum of many parts. Preamp, line amps, summing amps, tape machine (or daw), back into the console and through a whole other set of line amps etc etc. So really neither version of the 1073 is the “whole” sound, just part of it...a very pleasing part of it.
I say get what pleases your aesthetic and try not to obsess...I know that’s easier said than done 😄
Post by Deleted on Sept 11, 2019 21:44:55 GMT -6
I think you’re over thinking it. A great preamp is a great preamp. Sure the 1073 will sound different with and without the eq, but remember that a stand alone Neve preamp isn’t going to sound like a console anyway. The console sound that so many of us are chasing is the sum of many parts. Preamp, line amps, summing amps, tape machine (or daw), back into the console and through a whole other set of line amps etc etc. So really neither version of the 1073 is the “whole” sound, just part of it...a very pleasing part of it. I say get what pleases your aesthetic and try not to obsess...I know that’s easier said than done 😄 i know im definitely overthinking this but i always been kinda weird like that . cant help it brother when i have serious musicians OCD haha. its easy to get caught up with gear. but on a flip side, its fun time to make music with great affordable options. i see your theory with everything working together, such as other gear in the chain. yea tapes kick like a mule, nobody has emulated that well enough. once that guy posts that clips, i will right way which one i would want. just trying to save some money by hearing it out first.
Post by Tbone81 on Sept 11, 2019 21:48:30 GMT -6
I think you’re over thinking it. A great preamp is a great preamp. Sure the 1073 will sound different with and without the eq, but remember that a stand alone Neve preamp isn’t going to sound like a console anyway. The console sound that so many of us are chasing is the sum of many parts. Preamp, line amps, summing amps, tape machine (or daw), back into the console and through a whole other set of line amps etc etc. So really neither version of the 1073 is the “whole” sound, just part of it...a very pleasing part of it. I say get what pleases your aesthetic and try not to obsess...I know that’s easier said than done 😄 i know im definitely overthinking this but i always been kinda weird like that . cant help it brother when i have serious musicians OCD haha. its easy to get caught up with gear. but on a flip side, its fun time to make music with great affordable options. i see your theory with everything working together, such as other gear in the chain. yea tapes kick like a mule, nobody has emulated that well enough. once that guy posts that clips, i know right way which one i would want. just trying to save some money by hearing it out first. Trust me I get it! I’ll study a piece of gear for 6 months before I purchase. Most of us got to make every penny count!
Post by Deleted on Sept 11, 2019 21:51:13 GMT -6
i know im definitely overthinking this but i always been kinda weird like that . cant help it brother when i have serious musicians OCD haha. its easy to get caught up with gear. but on a flip side, its fun time to make music with great affordable options. i see your theory with everything working together, such as other gear in the chain. yea tapes kick like a mule, nobody has emulated that well enough. once that guy posts that clips, i know right way which one i would want. just trying to save some money by hearing it out first. Trust me I get it! I’ll study a piece of gear for 6 months before I purchase. Most of us got to make every penny count! yes that's it. trying to save money, instead of getting one and find out later i liked the other better. i hate buying/selling. dont want to get caught up with that. but from clips, i pretty much trust my own ears, at that point i stop depending on opinions. yes studying before purchase, perfectly said.
Post by Deleted on Sept 12, 2019 17:15:08 GMT -6
Are these neves clones units based on neve 1290 topology.
Post by notneeson on Sept 12, 2019 17:53:40 GMT -6
Are these neves clones units based on neve 1290 topology. Which ones? Stam would be a yes, I believe.
Post by Deleted on Sept 12, 2019 19:28:04 GMT -6
Are these neves clones units based on neve 1290 topology. Which ones? Stam would be a yes, I believe. Nice, most definitely stam, that's my pick. Others too overpriced. I like the sowters.
