Post by mrholmes on Jul 16, 2019 10:45:52 GMT -6
Crazy. I have new plug ins which pass the AU validation but they do not show up in Logic X.
Did try to erase Plist = NO. Did try to switch on and off the core audio button = NO. Hardware reset = NO P RAM RESET = NO
Any hint is welcome!
It is crazy becasue the validation passes without any problems or errors.
Cheers Holmes
Post by kcatthedog on Jul 16, 2019 10:56:15 GMT -6
did you rescan them in plug in manager ?
Post by mrholmes on Jul 16, 2019 11:05:22 GMT -6
I did. The issue is now more crazy.
I now have seen they only show up on stereo tracks not on mono tracks... But they are not stereo only.
Support has no clue either because they pass the validation.
Post by mrholmes on Jul 16, 2019 11:30:42 GMT -6
PROBLEM SOLVED!!!
Post by kcatthedog on Jul 16, 2019 12:54:20 GMT -6
And the fix was ?
Post by drbill on Jul 16, 2019 13:14:26 GMT -6
Post by mrholmes on Jul 16, 2019 17:37:06 GMT -6
Whaddaya need new plugins for??
Was for free...so I said yes I take them...
Post by mrholmes on Jul 16, 2019 17:38:24 GMT -6
And the fix was ?
Support and manual missed to let me know that some plugs are stereo only. " src="//storage.proboards.com/forum/images/smiley/superangry.png">
Post by sirthought on Jul 17, 2019 5:34:17 GMT -6
And the fix was ?
Support and manual missed to let me know that some plugs are stereo only. " src="//storage.proboards.com/forum/images/smiley/superangry.png"> This same thing has happened with me. I had even used the plugin several times, but that day I just forgot and was lost as to why I couldn't pull it up on a mono channel. Live and learn.
Post by kcatthedog on Jul 17, 2019 6:40:04 GMT -6
Logic: the great daw misnomer !!
Post by Martin John Butler on Jul 17, 2019 8:24:05 GMT -6
Well, it wasn't Logic's fault here was it?
Post by M57 on Jul 17, 2019 8:42:29 GMT -6
It's actually logical that some plugins don't work on a mono track. One possibly not-so-obvious reason is when you slap a stereo effect plug on a mono track chain and expect a stereo effect. It doesn't work with real gear, so why should it work with the virtual equivalents. The same thing has happened to me more than once, and as frustrating as it was to figure out why the first time - now I'm glad it does it because I instantly realize that what I was trying to do wasn't 'logical' in the first place.
Post by sirthought on Jul 17, 2019 9:14:32 GMT -6
No, not Logic's fault at all.... user error!
Post by mrholmes on Jul 17, 2019 13:51:29 GMT -6
Even if it would be Logics fault ....
I jet never have seen any daw without flaws from time to time.
I will never forget my first visit in a pro studio. The owner wanted to show me his PTHD system wroking with Logic.
In the same moment the whole system went nuts.
I asked him if its maybe wiser to use it with PT. Wrong question...
Post by Calvin on Jul 17, 2019 20:07:49 GMT -6
LOL, this has happened to me more than once. I'll sit there completely confused as to why I can't find a plug-in I KNOW was installed and working just the other day. WHERE IS IT?!?! Oops, that channel/aux is sitting in mono, for whatever reason, and it's a stereo plug-in.
